Another DH Project
Re: Another DH Project
Postby kfong » Thu Dec 15, 2011 10:10 am
Wow, what process did you use to drill all those holes. The fact that it ran the length of the can was really impressive machining.
kfong
Postby motomoto » Fri Dec 16, 2011 12:24 am
I'm with you on limiting the fun . I assume you have a CA-RC and thats how you are limiting your current. If so didnt you get the supplied 2 little shunts? My understanding of going over a shunts current range means it becomes hot and starts to act like a fuse?
I got the shunts but I can't find them. I used the molded shunt. I need to redo the wires and such.
I love the idea of the shunt being a fuse, that would be awesome. Have them easily replaceable. I just wonder when they are in a partial state of meltdown, how that will effect
the voltage reading that supplies the CA. But who cares, the important thing is that your expensive electrics are not frying.
Wow, what process did the use to drill all those holes. The fact that it ran the length of the can was really impressive machining.
When drilling the 3220 case the holes are about 2.15" long. I drill half the hole from each side and it takes about 10 minutes to drill the 60 holes on each end. They meet in
the middle and they overlap so even if they don't meet exactly there is little upset in flow.
motomoto
Postby motomoto » Fri Dec 16, 2011 12:40 am
Time to uprade to a 3220, piss the gears off and start pulling power monos
You are right. It's about time I grew a sack and got a 3220 4t. That would be sick. Anyone that has one they
want to sell, send me a PM. I will have that thing on there tomorrow, with a proper shunt and some Nano-tech
batteries. I want to make up some skinny tire wheels and see what kind of top speed I could reach also.
motomoto
Postby lostrack » Sun Jan 01, 2012 2:00 pm
What's the latest yo? Any more news...?
lostrack
Postby recumpence » Sun Jan 01, 2012 3:54 pm
Well, I know what he is doing about a bigger motor. :wink:
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby Whiplash » Sun Jan 01, 2012 4:37 pm
Uh oh! Big boy motor time!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby motomoto » Mon Jan 02, 2012 2:40 am
I think Astro Flight will send me a 3220 4t towards the end of the week, thanks to Matt.
By that time I will have the shunts and new wiring done and some nano techs. I want to do
a new 'run through the gears' video with the bigger motor and the amps turned up.
motomoto
Postby lostrack » Mon Jan 02, 2012 4:49 am
motomoto wrote:I think Astro Flight will send me a 3220 4t towards the end of the week, thanks to Matt.
What drivetrain are you using? High end or cheap and replaceable? Hopefully all at power isn't eating up your chains and kit...
lostrack
Postby motomoto » Mon Jan 02, 2012 12:34 pm
It's really just one sprocket pulling another sprocket. I changed the gear ratio for the unit early on when
I had a problem with the chain pulling so hard on the smaller rear sprockets that the chain would jump
a tooth and break. Now the whole system spins faster because I went from a 20 tooth pulley on the motor
to a 32. The largest rear sprocket has a top speed now of 22 mph. You can't help the motor by pedaling
because you would have to spin the cranks at 200+ RPM. When you are pushing 5+ horsepower the pedaling
is negligible anyway. I know I am in a minority, but I like the derailleur system. You can always just spin
everything faster if you want to transmit more power. I am considering making some larger diameter
cassette gears because that is what is really needed. The derailleur I am using is a XTR.
motomoto
Postby lostrack » Wed Jan 18, 2012 10:15 am
Any word on that video? Loved the sound of your old one. Reminded me of an F1... (slightly...!)
How's the new astro? I am on track to give mine (direct drive setup) the first launch this weekend.
T
lostrack
Postby motomoto » Thu Jan 19, 2012 2:29 am
I just got home a few minutes ago and there was a FedEx sticker on my door. It is for my 3220 4t from Astro Flight.
I should have things running this weekend and do a video. All I have ever run are 3210s. The 3220
should be double the power. It will be amazing if it is. I'm like a little kid and it's Christmas.
motomoto
Postby lostrack » Thu Jan 19, 2012 4:36 am
motomoto wrote:I just got home a few minutes ago and there was a FedEx sticker on my door. It is for my 3220 4t from Astro Flight.
Dude, I am super stoked for you! Free horsepower! Let me know what it's like!!!
I am preparing for the maiden voyage of the beast this weekend too
Subscribed
lostrack
Postby recumpence » Thu Jan 19, 2012 7:14 pm
Actually, you will feel a bit more than twice the power because there is a larger percentage of winding that is creating power and less end termination versus the overall stack height on the 3220 than the 3210.
Your bike will be nearly uncontrollable! You will definately need to dial the clutch down to tame the beast. :twisted:
Matt
recumpence
10 GW
10 GW
Postby farmkid4 » Fri Jan 20, 2012 9:43 am
cant wait to see a vid of it in action :twisted:
Do you have the ability to read?
Do you use it to increase your understanding?
9C Buildlog: http://endless-sphere.com/forums/viewtopic.php?f=6&t=47608&p=698343#p698343
farmkid4
Postby Enpro » Fri Jan 20, 2012 10:54 am
I'm so jealous right now.... :shock:
This bike is close to the perfect E bike..
A strong back wheel , perfect weight distribution, Very light weight, awesome power,9? speed transmission so climbs like a maniac yet smooth low reving motor at high speeds, FOX 8) long travel suspension, being able to actually paddle without resistance, I could go on for a while.
I think its way better than a stealth bomber or anything with a hubmotor..
Enpro
Postby motomoto » Mon Jan 23, 2012 4:04 am
Thanks for the strokes Enpro.
I have the 3220 but I am doing some work to get things ready for more power.
One of the things I have been meaning to do is make a third bearing support
for the 250 chain drive sprocket. As you can see it has a spud sticking out for
a bearing.
It is threaded into a 1/2" shaft but is just dangling out there without support,
so I made this support with a 6 mm bearing pressed into it.
I also have had an issue with the power pole arming switch melting down. They
are good in that when they make contact and spark, that is not the surfaces that
make contact when they are completely plugged in. The contact area when they
are plugged in is not very large and it creates a source of resistance and gets hot
and melts. the biggest size wire you can use to slid in the connector is 14 gauge.
I think that is pretty wimpy so my solution is to use 2 switches in parallel.
I am also trying to clean up the wiring and use 10 gauge and not put the final
flow of power through a deans connector but a high capacity connector. I chose
a CC 8 mm barrel connector because I think I can solder 3 wires into one connector.
There is enough room. Haven't tried it yet, but I did get the shunt and extra capacitor
thing handled.
I still need to make all the solder connections to plug to the CA. That and cut the motor
shaft to size and add connector to the motor and install and that is about it. Getting close. :D
motomoto
Postby Whiplash » Mon Jan 23, 2012 8:54 am
Super clean as usual!
Whiplash
Postby lostrack » Tue Jan 24, 2012 8:52 am
Eagerly awaiting news motomoto. Your build is inspiring!!
I'm very interested to see if the 3220 works, power-wise, through the drivetrain. If so, I'll consider switching over - to save a bit of weight, and for that awesome gears-f1-whine! Right now I'm (almost) driving straight to the back wheel with the disc-to-sprocket adapter.
Tom
lostrack
Postby motomoto » Sun Feb 05, 2012 1:29 am
I got the 3220 4 turn wired in delta. Thanks Matt and thanks to Justin at Astro Flight for giving the
proper wiring instructions. The 3 wires that are terminated together in the motor are pretty short.
One of them stuck out from the edge of the can about 3/8 of an inch. Not much to work with there.
The 3 grouped wires were all soldered together so when separated they were all tinned and ready to
go. I decided to take these 3 new wires and put a male 4 mm Castle Creations bullet on them. They
are rated at 75 amps. I put heat shrink on to cover the wire and bullet, and trimmed to expose only the male
part, then I put 2 more layers of heat shrink on just the wires and not the bullet. I did this because
I didn't use grommets for the 3 new 1/4" holes I drilled in the cover. I used 12 gauge wire to extend
the short wires into a 5.5 mm Castle Creations bullet along with the appropriate wire according to
Justin. So I put 2 wires into 1 solder pot 3 times for the 3 connectors. Tricky but doable.
The motor is amazing. So much power. It starts to taper off about 12k as the back-EMF starts to
nullify the voltage from the battery. From about 5k to 10k the thing pulls REALLY STRONG. It
is pretty bitchin. I have the CA set at 160 amps maximum.
I can feel where my 10 turn 3210 would go flat and make heat, this motor turns the amperage
into thrust. It's like going from a 250 cubic inch engine to a 500 cubic inch engine, and the 500
cubic inch engine is more fuel efficient, has twice the power and revs more. It has really made
my setup into something fantastic.
The fun part is that I spent the day at the Folsom, Ca. dirt jump park today with my two grandsons.
I had the electric bike there one time before but it just felt dangerous. This time I had the CA
and set it at 20 amps. It was great. Just thumb the throttle and you get a nice smooth push.
So, there is a couple of double jumps that you have to have some serious speed and skill to make
on a BMX bike. I have only seen one kid do it. I am no where close to having the speed or the skill
to make those jumps, and I have a sweet 26" Cannondale jump bike. Well, I was hitting it at my usual
speed on the electric and realized how forgiving the downhill bike is on the jumps with 8 and 10 inches
of suspension front and rear. If I could just use the throttle on the downhill and get up enough speed
I could make the double and the one after. The problem is, I am 54 years old and my testicles started
to tuck up inside like ovaries at about 50. Well, I am not quite bright, so I went to the car and
got my cell phone. I told my oldest grandson Evan, 10, that he might have to drive home. He just looked
blankly at me. He still doesn't get my sense of humor. Anyway, I told him that he might have to use my phone
and call Grandma if I crash.
Well, after a couple of 'not this time' last second abandon mission runs, I finally held the throttle on to just
before the jump and flew off... but not far enough. The front wheel made it, but that just made the
jump a perfect wedge to split the forks off from the rest of the bike. Man I am glad they make those
downhill bikes strong because a normal bike would have broken in two.
Well, I decided, I will just put the amps up to 30 and that will give me enough speed to clear it. On the
next run I kind of cleared it, but the rear caught the top pretty good and the suspension saved me. So I set
the amps at 40 and took another run. this time I cleared it and when I came around the bowl turn after
the jumps the grandsons had there fists in the air cheering.
It was great, but I spent the rest of the day on the jump bike doing my usual runs with smaller jumps.
I ran out of bravery for the day. I rode pretty awesome the rest of the day. The bad thing is, is that I am
getting pretty good and am ready to jump the 2 gap jumps at the end of my favorite run that I have
been avoiding. So I will have to sack up again. Oh brother.
motomoto
Postby motomoto » Sun Feb 05, 2012 1:40 am
I took some video today before we went dirt jumping but I left the camera in the truck at work.
Tomorrow we are going to the beach with the grandkids, so Sunday night or Monday I will have video
and pictures.
motomoto
Postby Kepler » Sun Feb 05, 2012 2:45 am
Much respect Moto. I am 51 and get nervous launching off a road curb let alone a double at a BMX park. Well done, you and your bike have set new standards within the ebike seen.
Current Rides
Carbon Super Commuter: ON ROAD http://endless-sphere.com/forums/viewtopic.php?f=6&t=47139
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
75 Volt 2.5 kW Stealth Fighter: OFF ROAD http://www.stealthelectricbikes.com/
Kepler
Postby lostrack » Sun Feb 05, 2012 3:32 am
Haha!! This brings back the memories!
Enjoyed the story. We all remember our huge back-wheel case jumps...they're character building! If you get really good the idea is to jettison the bike mid-flight...not sure how good that's going to be on even a "light" ebike, however.
Nice work!
Look forward to the video & hearing the Astro in delta. I thought you said it was going to cause problems with the CC controller though?
Tom
lostrack
Postby motomoto » Mon Feb 06, 2012 12:10 pm
motomoto
Postby lostrack » Mon Feb 06, 2012 12:25 pm
Awesome mate. Loads of fun! Get him a helmet though. sorry...
What amps were you running your RC CA on for this?
Your setup is so slick!! Gears ahhhhhhhh.... maybe a little envious at the moment:)
Our setups are so similar now, all that's changed are the frame & drivetrain. We should do some Delta vs. Wye testing when I get my RC/CA.
Would love to see that jump by the way:)
lostrack
Postby motomoto » Tue Feb 07, 2012 1:49 am
I set the CA at 160 amps max, because I don't want to be the one to find out the
limit and have to send the controller back to CC. It has plenty of power that I
have to learn to deal with.
I am kind of proud of the fact that I saw the CA read 46+ mph on the end of the second leg
of the street run and I did have a full face helmet on for that.
I think I will put some other wheels and tires on and do a top speed run. I am
guessing at 55 mph. We will see. There will be video.
There also will be video of the jump when I store up another bag of courage.
Possibly Wednesday.
Also, I have been looking forward to the April 7th Grange race on a go kart track.
I haven't raced anything in a while, and never on pavement. I am sure there will be guys
there with a lot more motor and a lot more battery. Maybe a top 5 spot I hope?
Here is a picture of the wiring. The original holes have the grommets.
one and six, two and three, four and five for delta according to Justin at AF
"A pile of aluminum scrap I have to walk around at work".
motomoto
PreviousNext
Users browsing this forum: Mechdude, rearengine and 8 guests
