Mitch wrote:What are the chances of you coming up with a solution? Maybe an additional optional support bearing for your Eno FW's?
Miles wrote:Fine. I'm not keen on "exclusive" parts, though.....
Miles wrote:In case the design I was proposing wasn't clear:...
Which is exclusive to him.MitchJi wrote:Jim proposed having White make a FW with two bearings. Which isn't more exclusive than his current solution.
No, anyone is free to copy itMitchJi wrote:Another design using "exclusive" parts![]()
(sorry, I couldn't resist
Sounds promising....boostjuice wrote:I've just recieved one of the Recently released ACS 'Crossfire' series freewheels in 22T to try out next in place of the failed Dicta. Being CNC mill/laser cut, they are a HUGE step up in quality from the old largely stamped Dicta and ACS 'Claws' line (another i was considering). They feature a quality finish, 3 synchronously engaging pawls just like the ENO, offer very low overrunning resistance, are reasonably quiet, and feature twin angular contact bearings with minuscule lateral freeplay. If the ratchets are rotary/laser cut like an ENO, rather than being broach stamped such as in the 'Claws' line (and all Dicta's I might add), then there is a good chance that the parent metallurgy is stronger as it can be of a harder material before broaching and subsequent case hardening.
Miles wrote:Have you come to a final verdict on the 'Crossfires', bj?
Miles wrote:'Museum of freewheel'.
Thanks!
markobetti wrote:Wow , Boostjuice , what is your opinion since you have the museum:) ; the best long lasting choice ?
boostjuice wrote:You can all decide for yourselves.....amongst other choices![]()
amberwolf wrote:By chance, I happened to save all those when I saw them, as I am considering modifying some existing freewheels with certain features I saw on those (which I expect to fail but still may try).
Attached below, not necessarily in the same order they used to be:
fizzit wrote:Cost estimate? Or if I have to ask...
Users browsing this forum: Kabbage, kunting, Majestic-12 [Bot] and 3 guests
