t44florida wrote:wineboyrider wrote:My only concern t4florida is the controller will get too hot eventually???? It needs to breathe.![]()
Am thinking on that... just trying to geter done for time being. Aluminum heat sink plate beneath? PC fan in box cool it enough? Perhaps vent in box with PC fan?
t44florida wrote:Yes sam... it floats up and down at the seat arms.
veloman wrote:No rear torque arms on an alum frame with Magic Pie?
sangesf wrote:As usual.. Pretty sweet..
How much would the average Joe have to invest in all that?
Below or above $2000?
jpgey wrote:Very nice !
How did you manage throttle ? One throttle connected in parallel to both controller ? And did you manage power balancing front/rear ?
jpgey wrote:Thank's, and do you have already technical spec for MP3 pre-release motors ?
hillzofvalp wrote:How did u regen 45A?
Golden Motor Canada wrote:hillzofvalp wrote:How did u regen 45A?
I have both motors on 100 percent regen as their are still no usb cables available to turn it down. So when rolling along full steam and you just touch the brake levers that what you get.
Gary
Ossielocal wrote:Hi guys , this is my second build and on this one i used a Ezee 400watt kit with a ping 48v 10ah Battery .
Mainly use this bike for work ..Still needs a on off switch .And i'm not sure about the range on the battery ..but it should be good for 14ks .
Users browsing this forum: Brute, Cowardlyduck, Craftair, loco13, Observator and 9 guests
