So I have two burnt crystalyte hs30 motors from mehtods prebuy. I want to rewind them as one larger motor.
These motors were 10*6 before, and hit 110 km/h at 100v on a 26 inch rim. I would like to keep or expand the top speed, so keeping relatively the same kv or slightly higher is the goal. I'm planning on running at least 120v with a 144v Kelly.
Here you can see the magnet rings, and the flange I will need to machine down on the inside edge so as to have the magnets form one ring.
- magnet rings.jpg (146.71 KiB) Viewed 1226 times
- magnet rings outside.jpg (131.35 KiB) Viewed 1226 times
And here you can see the two stators, one stripped. They also have a flange I will need to machine down after pressing out the axles.
- stators.jpg (146.24 KiB) Viewed 1226 times
I am using the ev and stator calcs to test a 4 turn 10 strand wind; this is what I get. I don't know the kv but figure it at about 10 due to doubling stator and almost halving turns.
- (245.23 KiB) Downloaded 3 times
And finally, here is a photo of 18 gauge wire in the stator. I can fit 40 turns, maybe 42 for 3*7 but that's it, and the insulation paper takes away .04 of a mm which i dont knave yet.
- statorwith40wire.jpg (129.12 KiB) Viewed 1226 times
I have never done anything like this before, so I will be relying on the community to correct me when I err. Any advice at all would be appreciated. If I am missing something please tell me.
If you are in Ontario or Quebec and you have a lathe and some time, let me know; I need to find someone to lathe down my stator and rings, and to manufacture an axle.
