Project Thread: Morphine Prototype
Re: Project Thread: Morphine Prototype
Postby SHiFT » Sun Jan 15, 2012 11:32 am
Ok that's good to hear. Makes me feel a LOT better. The batteries are up at 49.xxx volts right now. I am using a Meanwell, the small one, and input is 29.xx amps according to the hyperion menu. The menu says the batteries are only at about 87% charge.
Amps are set to 10.0a, it is what the menu had set as the default for a 10,000mah 12s battery.
Thanks,
SHiFT
SHiFT
Postby sn0wchyld » Wed Jan 25, 2012 5:50 pm
SHiFT wrote:Yes, 5000mAh is nothing, I basically got 4 test runs in today, and decided not to run the battery out too much. This relates to the "almost" dying part - but I touched the soldering gun, the soldering clamps annnnnd... both leads of the other LIPO battery. Yes, it sparked in my face. Yes, it instantly melted the contact points on the soldering clamp and the leads of the battery. Yes, I felt like I almost died. And no, I'm not touching that battery again. I am a noob with anything related to this, and even more so with LIPOs. I'm not taking the chance using a battery that might have sustained damage and just ordering another one. In the meantime, I'm running on one.
To be honest mate I think the battery would probably be fine, so long as the short was for a brief moment. do you have a lipo charger that can check the IR of the pack? How long did the flash last? do you recall if the pack got warm at all?
I, and quite a few others from what Ive read have on occasion shorted out lipos for brief periods. And yea, its one way to get the adrenalin pumping!!! In my case I had decided to test my connectors, before sliping the cover on 'em.... just plain stupid. luckily the flash was only for a moment, and apart from a bullet connector with a gaping chasm down one side there was no harm done. the discharge wires and pack didnt even get slightly warm, and it didnt change their IR or capacity at all. And I've been using it for months since with no issues.
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby recumpence » Wed Jan 25, 2012 9:13 pm
Your pack is fine. The wire blew as a fuse would. The pack is fine.
I actually plugged two packs together once. WOW was that freakin CRAZY!!!!
Both packs were fine. The wires exploded, but the packs were fine.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby sn0wchyld » Wed Jan 25, 2012 9:45 pm
lol. new marketing ploy... 'lipo packs, now with built in 4mm fuses!!' :twisted:
My builds:
sn0wchyld
Postby SHiFT » Fri Jan 27, 2012 12:23 am
Haha. K, thanks for the info. It's good to know in case I ever do that again.
SHiFT
Postby Gordo » Fri Jan 27, 2012 1:12 am
I did not see anyone tell you to not bolt through a tube, ever. It will just crush the tube unless you weld a small piece of pipe in the frame where you are clamping. And welding on Al is no good.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Postby SHiFT » Sun Jan 29, 2012 7:07 pm
That's great advice, never thought of that. I did the PVC route this time, but now I know for the future.
Thanks.
SHiFT
SHiFT
Re: Project Thread: Morphine Prototype (Finished pic)
Postby SHiFT » Wed Jun 06, 2012 9:06 am
I finally finished my bike. It's not elaborate, but it's done for the most part. Thanks so much for all the advice and assistance, I'd never have even started this project were it not for the information and expertise available here.
SHiFT
SHiFT
Previous
Users browsing this forum: elpq35, emcee and 4 guests
