Dual rotor axial flux motor design
Re: Dual rotor axial flux motor design
Postby Miles » Tue Jan 31, 2012 1:49 am
Hi Ken,
I'm not sure what you mean. The laminations run in the direction of the flux path.
Even the best powdered core material wouldn't give as high a performance as decent laminations (unless there's a significant advantage to a non-planar flux distribution).
With a laminated core, would there be any advantage to having a proportionally greater face area, per lamination, if the main part of the core is uniform? The flux at entry is confined within that lamination.
The windings exit on the outside, through the case, and will be joined there.
The idea is to engineer it so that the pre-wound stator modules can be inserted through case, so they could also be replaced that way, too.
Miles
Postby Arlo1 » Tue Jan 31, 2012 2:06 am
I like it I plan to build something like it but multi layered one day.
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Lebowski » Tue Jan 31, 2012 2:06 am
I don't know what you mean with laminations, is that the laminated iron core of the coils ?
The motor I built myself is also an axial flux, I have no iron in it which makes it possible to spin
this motor using only 30 milli-Watts.
I've thought about adding iron, what I would do is get plastic coated iron wire (like they sell at the garden center
for tying up beanstalks). I would wind this (soaked in epoxy) to the desired shape / diameter. I think this
would be a very good design for having low eddy currents, there is no continues loop except within a
sideways cross section of the wire. But because it's wire the sideways cross section would be very
shallow...
A mayor disadvantage of iron core (and the reason why I don't have it) is that the two magnet
plates in my design would attract each other with a lot of force making it almost inpossible
to take it apart again. Currently (with the 7 mm airgap) the force is about 100 kg, taking it
apart requires a bearing puller type tool but is still possible...
About airflow to cool it, with mine there is a detectable flow of air being sucked in the core
and flying out inbetween the magnet plates and coils (flow due to centrifugal force).
I already got the magnets and a second coil plate prepared for a dual layer design but at the moment
I'm concentrating on getting my controller IC finished....
Lebowski
Postby Miles » Tue Jan 31, 2012 4:01 am
Lebowski wrote:I don't know what you mean with laminations, is that the laminated iron core of the coils ?
this motor using only 30 milli-Watts. ....
Yes, the core laminations.
You can get a greater specific torque with an iron core. That's what is needed for the Challenge.
Yes, the attractive force is a big problem. Maintaining a balance between the two airgaps..... The rotors are only 80mm in diameter, though - it's quite a small motor, compared to yours.
Miles
Postby Lebowski » Tue Jan 31, 2012 4:17 am
Miles wrote:You can get a greater specific torque with an iron core. That's what is needed for the Challenge.
I looked at it from a different angle... In my opinion you need to convert
electrical power efficiently into mechanical power, independent of whether
you want to race uphill or just ride around on the flat. Core laminations help
with efficiency but only in a certain rpm range (too low rpm -> cogging,
too high rpm -> eddy current losses). No iron core gives a lower specific
torque but this can be solved by chosing a different gear ratio so I wouldn't
say this is a disadvantage of having no iron core.
For me in the end the efficiency with no core was good enough, the disadvantages
of the iron core outweighed its advantages.
Lebowski
Postby Miles » Tue Jan 31, 2012 4:26 am
I can see that your motor would be more versatile (more efficient over a wider range of torque outputs) but mine is being designed specifically for this: viewtopic.php?f=30&t=14484 In practice, I'll be using mine with a 2 speed gearbox - they are designed as a pair.
Miles
Postby Miles » Tue Jan 31, 2012 8:03 am
This looks to be a useful resource: http://www.emetor.com/ :D
As well as the revamped: http://www.powerditto.de/bewicklungsrechner.html
Miles
Postby markobetti » Tue Jan 31, 2012 8:33 am
Dear Miles, the gearbox isnt published at ES ? Its okay if its a secret , but if not please post link since i havent been able to locate it. i remember you and hal discussion about retro direct drive ....but thats not it right ?
markobetti
Postby markobetti » Tue Jan 31, 2012 8:36 am
Maybe you can try your calculations in trial version if they have it :
http://www.infolytica.com/en/products/
http://www.infolytica.com/en/applications/ex0072/
markobetti
Postby Miles » Tue Jan 31, 2012 8:42 am
markobetti wrote:Dear Miles, the gearbox isnt published at ES ? Its okay if its a secret , but if not please post link since i havent been able to locate it. i remember you and hal discussion about retro direct drive ....but thats not it right ?
Hi Marko,
No I haven't published anything about it here. I will but not just yet. It is a retro-direct as Hal and I were discussing then but I've spent ages exploring all the possible options and going through numerous iterations of design.
Miles
Postby Miles » Tue Jan 31, 2012 8:45 am
markobetti wrote:Maybe you can try your calculations in trial version if they have it :
Thanks! They didn't do a trial version before - now they do.
Miles
Postby kenkad » Tue Jan 31, 2012 8:56 am
miles
This is what I meant by vertical laminations, bent into a 'C', stacked, to produce a trapezoidal end. It seems to me that the flux path out the end is now distributed. I used different colors for the lam layers to better see the result. I have never seen a sim of this, but have always wondered why this is not done. My preference would have been to do this as a powdered core so that the center could also be trapezoidal, providing a better motor fill with a split copper strip winding like Shane did in one of his motor experiments. I hope this explains my question to everyone. As to why the more than one 3-phase group question. That is because starting torque requirements to get a vehicle moving are greater than running torque requirements at a speed, so I would op to turn off a 3-phase group to reduce motor power consumption since I do not believe the cogging would be noticeable at speed, momemtum effects.
kenkad
(32.87 KiB) Downloaded 3 times
kenkad
Postby markobetti » Tue Jan 31, 2012 9:08 am
Glad to be a service to you. You helped me alot, for example with freewheel . Finally made indestructible freewheel with two bearings inside al 7005 mat. and more pawls than any freewheel on the market i can think of. http://img217.imageshack.us/img217/326/heavymetalx.jpg . Logo is covered with white color due to my project that is in state not intended to be shown right now under the name. Anyways , thank you MILES :)
markobetti
Postby Miles » Tue Jan 31, 2012 9:15 am
kenkad wrote:miles
Ken,
I don't think this would work. You would get serious eddy currents on the end face. The laminations need to restrict flow perpendicular to the direction of the rotor. Also, there will be a strong reluctance between the face laminations, I think.
Miles
Postby Miles » Tue Jan 31, 2012 9:22 am
markobetti wrote:Glad to be a service to you. You helped me alot, for example with freewheel . Finally made indestructible freewheel with two bearings inside al 7005 mat. and more pawls than any freewheel on the market i can think of. http://img217.imageshack.us/img217/326/heavymetalx.jpg . Logo is covered with white color due to my project that is in state not intended to be shown right now under the name. Anyways , thank you MILES :)
Wow! That's nice Marko. Look forward to seeing what it's intended for....
Miles
Postby rhitee05 » Tue Jan 31, 2012 9:37 am
kenkad wrote:This is what I meant by vertical laminations, bent into a 'C', stacked, to produce a trapezoidal end. It seems to me that the flux path out the end is now distributed. I used different colors for the lam layers to better see the result. I have never seen a sim of this, but have always wondered why this is not done. My preference would have been to do this as a powdered core so that the center could also be trapezoidal, providing a better motor fill with a split copper strip winding like Shane did in one of his motor experiments. I hope this explains my question to everyone. As to why the more than one 3-phase group question. That is because starting torque requirements to get a vehicle moving are greater than running torque requirements at a speed, so I would op to turn off a 3-phase group to reduce motor power consumption since I do not believe the cogging would be noticeable at speed, momemtum effects.
There's a few separate issues we can break down. First, lamination direction: vertical/radial vs. horizontal/tangential. Eddy currents are due to the induced EMF, whose direction is given by v x B (vector cross product). For an axial-flux motor, this gives an induced EMF in the radial direction (v is tangential, B is axial, thus EMF is radial). Thus, eddy currents in the radial direction will be created in any conductive material present. By laminating the cores in a horizontal fashion, we keep the conductive distance in the radial direction short and thus limit the eddy currents which can flow.
Second, the shape of the teeth at the end of the cores. I agree with you that it would probably be beneficial to make the ends wider than the center - the proper tradeoff between iron and copper can be determined through simulation later. Looking in towards the center, this would give the cores a sort of dog-bone shape. You're also talking about making face of the tooth wedge-shaped, rather than rectangular (looking axially). I brought that up a little while ago as well. That would be relatively hard to do with this lamination direction, and I'm not certain it would really give significant benefit. On the other hand, leaving the ends rectangular will I think give the BEMF more of a sinusoidal shape, which might actually be a plus.
Third, Miles is correct that electrical steel is a better material than a powdered core. Harder to work with and more expensive, but better magnetic properties.
Lebowski wrote:I looked at it from a different angle... In my opinion you need to convert
Again, a couple of separate issues. Miles is correct that an iron core gives more torque. Specifically, because you can achieve higher flux densities, the motor has a higher power/torque density (obviously you could make a large ironless motor with more torque than a small iron-core motor).
Second, efficiency. I disagree that cogging represents an efficiency loss. Cogging is both positive and negative torque, so the net energy contribution is basically zero. It increases the torque ripple, but since Miles is gearing his motor down I think torque ripple will be much less noticeable than with direct-drive (higher frequency, lower amplitude).
There's probably a study out there to prove this one way or the other, but I would tend to think that ironless is not inherently more efficient than an iron core. You do avoid most of the eddy losses, but in exchange you need more current to achieve the same torque with lower flux density, so the copper losses will be higher. I suspect that eddy vs copper losses would be a pretty even tradeoff in a motor with a high-quality core (thin lams of high-grade electrical steel). For our practical purposes, however, I think ironless is attractive because it's easier to build a good DIY motor this way even if there is a torque density tradeoff. You could also probably say that ironless has more advantages at high RPMs and iron core has more at low RPMs.
Eric
Trek FX 7.3 hybrid - Cyclone 650W setup in process! Still...
rhitee05
Postby kenkad » Tue Jan 31, 2012 9:56 am
rhitee05, miles
I am not a motor designer. If a wedge shape core end is not beneficial, why should wedge shaped magnets be used on the rotor instead of rectangular shaped magnets. It has been quite a while since I spoke with people involved in powdered cores, but, it seems I recall that there is an orientation process in making cores like this. I dropped the whole design issue because in talking with companies and universities about sim software, I was told the software was not sophisticated enough to deal wtih these questions. That was more than two years ago and I have not checked if there are any improvements. This is why I am now asking the question.
kenkad
kenkad
Postby rhitee05 » Tue Jan 31, 2012 4:52 pm
kenkad wrote:I am not a motor designer. If a wedge shape core end is not beneficial, why should wedge shaped magnets be used on the rotor instead of rectangular shaped magnets. It has been quite a while since I spoke with people involved in powdered cores, but, it seems I recall that there is an orientation process in making cores like this. I dropped the whole design issue because in talking with companies and universities about sim software, I was told the software was not sophisticated enough to deal wtih these questions. That was more than two years ago and I have not checked if there are any improvements. This is why I am now asking the question.
I can't really answer your questions, which are getting much further down into the details of motor design than I'm familiar with. A lot of these parameters are design trade-offs, though, rather than distinct A is better than B scenarios. For example, you might get a little more power out of wedge-shaped magnets (I think), but the rectangular magnets would I think give more sinusoidal BEMF and probably lower cogging. That's more of a design choice.
If it were me in Miles' shoes, I would be most interested in the easier-to-build tradeoffs even if the resulting motor was a little sub-optimal. :-)
Eric
rhitee05
Postby Miles » Tue Jan 31, 2012 5:21 pm
As far as my decision process goes:
A completely wedge shaped core is out because 30 different sized laminations would be a PIA.
This leaves the possibility of trimming the teeth (top and bottom of the I shape) of an oversized core module after assembly.
So, the choice is between increasing the overall area of the core at the gap, even though it all ends up in a uniform section in the middle or, sacrificing the extra area for a BEMF which is closer to sinusoidal and is likely to behave better with a sine controller.
With an SMC core, a wedge shape makes more sense, because the flux is automatically distributed uniformly.
Miles
Postby Miles » Wed Feb 01, 2012 3:06 am
I guess I could try machining the complete wedge from each block of bonded laminations.... That way I could start with simple square lamination blanks and avoid the punching step altogether.... I'd have to be careful to avoid introducing any bridging between the laminations, though.
Miles
Postby Miles » Wed Feb 01, 2012 3:15 am
Next decisions:
How many slots? 18, as modelled or I could possibly reduce it to 15? without increasing the lead in/out angle across the laminations too greatly...
How many poles?
Miles
Postby Lebowski » Wed Feb 01, 2012 3:17 am
Miles wrote:Next decisions:
How many poles?
These choises have no effect on efficiency... just make sure the motor is physically big and has lots of copper in it.
Lebowski
Postby Miles » Wed Feb 01, 2012 3:26 am
Lebowski wrote:These choises have no effect on efficiency... just make sure the motor is physically big and has lots of copper in it.
But they will affect the amount of copper in the links between coils... If I used 15 slots and 14 or 16 poles, most of the coils could be linked to their adjacent partner, I think. As I'm intending to use rectangular copper strip and the connections are outside of the case this would be an advantage...
Need to find out the trade-offs WRT the winding factor?
Miles
Postby bearing » Wed Feb 01, 2012 4:22 am
I don't think a stator with 15 teeth is going to work well. With 14 or 16 poles, windings will, as you say, be put in groups of 1/3 of the diameter. Every time a phase pair is energized it will "bend" the rotor(s) and shaft. See the summary at the bottom of this page: http://powerditto.de/15N14P.html
It might work better with an axial design with small diameter, but I would personally avoid it.
From a mathematical perspective, it looks like you end up with a solution like this (windings in groups of 1/3 of diameter) every time the number of stator teeth is 3 * prime number, and at the same time use a pole count as close as possible to number of teeth. (3*5 and 14/16 in this case.) It will, however, give a very good winding factor. To solve this "imbalance", use twice as many teeth, which will put windings in two groups, on opposite sides of the centre. 18t (2*3*3) 18p/20p are twice as many teeth as the "imbalanced" 9t (3*3)p 8p/10p. Following this logic, 30t (2*3*5) with 28p/32p would be a good solution, or 42t (2*3*7) with 40p/44p. This can be confirmed with http://powerditto.de/bewicklungsrechner.html
The famous 12t (2*3*2) with 10p/14p also follows this logic/design of 2*3*prime number and then the closes possible number of poles.
bearing
Postby Lebowski » Wed Feb 01, 2012 4:26 am
What is a winding factor ?
I thought about using copper strips as well, an idea which I had with this respect that you may find usefull:
at farnell they sell (quite cheaply) heatshrink tube in all diameters and up to 5 meters in length (5 meter for 4 euro
for the thinner stuff). You can sheeth your copper strip with heatshrink tube before winding it to isolate it....
Another thing I thought about at the time was a tripple stator design with one phase per stator. You can
wind the strip in a cloverleaf design... disadvantage is the big piece of iron (a.k.a. axle) going through
the middle of your coils :(
Also usefull, think Lorentz force, not magnetic attraction / repulsion.
Lebowski
PreviousNext
Return to Motor Technology
