BATFINK wrote:Nice build Tony. Nightmare with the tyres. I have 2 of the big apples sitting waiting to go on the right bike but I was a little disappointed with how thin the sidewalls of those tyres are. Maybe you should invest in some sort of seat suspension. I have been recommended one of those suspension seat posts by cloud 9. maybe that would do the trick for you.
What is your battery setup and weight if batteries?
How will you hide the cables from your controller and make it waterproof?
Sent using Endless-Sphere Mobile app
I have a Brooks B17 Flyer that is sprung and actually works quite well for butt fatigue. Forearm fatigue relief was what I was hoping to get from the Big Apples.
The controller has been painted black and will bolt to the silver straps that secure the rear rack to the frame.
The wires from the controller go through the opening in the rear frame stay to the battery and points forward. Not much shows. As for waterproofing, the rear fender protects the electronics from spray.
The motor control harness that comes out of the axle was nicked and now the insulation is completely cut. I will have to mark the wire locations for the five-way plug that goes to the controller, remove the clip and slide a section of heat-shrink tubing down over the harness to the axle to protect the wires. The inside edges of that axle are SHARP. I'll see what I can do to de-burr them before applying the heat-shrink.
Oh yeah, battery is an 11.5Ah A123 52V (57V HOC) from cell_man in a frame bag. Motor, batteries and controller add about 18 lbs. to the bike. The Muirwoods is really light for a steel bike. All said and done, bike, electrics, fenders, lights and racks should be about 50 lbs. all told.
