neptronix wrote:Depends entirely on your current draw and amp hours, which will determine whether you need it or not.
Arlo1 wrote:You should add the 4s hard case pacs to the spread sheet.
texaspyro wrote:A lot of people around here have been having AWFUL luck with the latest NanoTech cells... to the point of tossing them and swearing to never buy them again. The first batches were great. The current ones seem to puff and die after a very few cycles. These are people that are very well skilled in proper lipo management that I trust to know what they are doing (been flying jets and helicopters since day one). YMMV...
bane77087 wrote:I've looked for stats on the cycle life and calender life for the nano techs and have seen other ppl ask too, never seen an answer though, well other than a vague "double the cycle life over standard li-poly". Double what exactly the 200 something the regular turnigys are supposed to get or double something else. If it is really double the cycles of their standard cells then you come out ahead money for cycles plus you have another AH per pack.
It would be really nice for some1 to post the cycle info for the nanotechs I don't think its on here anywhere
neptronix wrote:Luke; what's the reason? bad cell rate getting up there with the Non-nano, or worse? higher IR?
liveforphysics wrote:neptronix wrote:Luke; what's the reason? bad cell rate getting up there with the Non-nano, or worse? higher IR?
Failure rate used to be very low, now it's poor. Cycle life used to be very good, now it's poor. They used to very very rarely puff or self-discharge, the recent batches seem to frequently puff or self-discharge.
They used to be the best of the RC LiPo, now they still have killer performance, but I've seen poor reliability and cycle life, where as the early ones would last for years of hard abuse.
zombiess wrote:Not what I like to hear considering I just purchased 10 6s 6AH packs. I don't think I'll make it to the abuse category though since the most I'll ever draw from my 30S2P pack will probably be 150-200A for a 15 second burst if I can keep the front end down on the bike (working on that now).
neptronix wrote:zombiess wrote:Not what I like to hear considering I just purchased 10 6s 6AH packs. I don't think I'll make it to the abuse category though since the most I'll ever draw from my 30S2P pack will probably be 150-200A for a 15 second burst if I can keep the front end down on the bike (working on that now).
I'm repeating myself again here, but a discharge with a balancing charger is going to help you sort out the duds and prevent problems down the line. Since there is a 10% dud cell rate with non-nanotech, you most likely have at least one pack with a funky cell in it that should be set aside.
zombiess wrote:
I've purchased 21 new packs from 3 separate orders several months apart of 20C 6S, one pack came puffed, other 20 were fine, they refunded me the dud pack and let me keep it which I then fixed with a replacement cell, probably one I got from you.
None the less I always check my packs, especially new ones for the first few cycles.
As long as Hobby King will give you credit or a refund for a defective pack without you having to pay shipping to send it back then I guess the "dud" issue is not that big of a deal. About two years ago I tried their 100A current controllers with the 80-100 outrunners and they failed soon after I hooked them up. I did have to send the controllers back to get store credit, which was no big expense because of the small size and minimal weight. The long wait in receiving credit was the real bummer. What are their current return/exchange policies for defective batteries shipped from the USA warehouse? Is it now standard that they don't require battery returns for credit?
Martin
Users browsing this forum: docnjoj, ingesa, mushymelon and 6 guests
