Another RG250 with Colossus Motor
Re: Another RG250 with Colossus Motor
Postby voicecoils » Sat Dec 17, 2011 11:37 pm
I think it's looking sweet Tony!
I like the battery holder shape as well, it gives a bit of style instead of just a honkin' big box.
Will you keep the bike's full fairings or will the battery's be visible?
voicecoils
Postby Arlo1 » Sat Dec 17, 2011 11:37 pm
More video!
And Dave who has some good deals on STUFF Incl. Mosfets, Current sensors and Nomex paper.
Arlo1
Postby AussieJester » Sun Dec 18, 2011 12:18 am
I agree with voicecoils its looking sweet mate!
KiM
AussieJester
Postby SplinterOz » Sun Dec 18, 2011 1:20 am
voicecoils, AussieJester, Arlo1. Thanks guys I am really happy with the work so far.
voicecoils I am getting all the fairings painted and most of the time the bike will have them all on. However the side and bellypan fairings are really easy to drop off and I will be doing that often or "show and tell"
Arlo1 I might do a video describing the pack in the bike and my options for the other components no more riding videos until I get all this stuff mounted properly.
SplinterOz
In the Capital of Australia
http://rgelectric.wordpress.com
SplinterOz
Postby Arlo1 » Sun Dec 18, 2011 1:38 am
SplinterOz wrote:Arlo1 I might do a video describing the pack in the bike and my options for the other components no more riding videos until I get all this stuff mounted properly.
Come on come on come on. You and me are the only ones working on making something out of colossus!
Arlo1
Postby SplinterOz » Sun Dec 18, 2011 2:14 am
Arlo1 you sound like black board from an old kids show over here.
"Hurry up... Hurry up"
SplinterOz
SplinterOz
Postby SplinterOz » Sun Dec 18, 2011 3:02 am
Arlo1 just for you...
I realized that you guys have not seen these two videos...
Friend on board for the first time
Just a little ride down the street.
SplinterOz
SplinterOz
Postby SplinterOz » Thu Jan 19, 2012 3:33 am
Ok so I have the connectors designed and the outer plates slightly modified to fit better. I will be using 3mm Aluminum for the battery connectors and they will be all laser cut. This should all be ready for me by Wed next week ready for a long weekend.
You will see I have increased the gap between the plates...
Battery Holder Designs by Splinter, on Flickr
Note the green highlight is the outer battery holder plates.
SplinterOz
SplinterOz
Postby Dreddydave » Thu Jan 19, 2012 6:03 am
This is the first time I've seen it and I'm very impressed! I'll keep an eye on this one; great job!
Dreddydave
Postby SplinterOz » Sun Jan 22, 2012 2:11 am
Next week is Australia Day. This year it falls on a Thursday and in the tradition of all hard working Australians I plan to take Friday off as flex time. This gives me 4 days straight to get a huge amount done on the bike.
The next major task is to build the final battery pack 72 volts and 50 amp hours of Headway batteries. Luke and I have designed the layout and holders for these and we got the first try a month ago. We needed to make some minor adjustments to the outer plates and also design the electrical connectors. I made a small video on the battery layout so you can see how it all goes.
My CAD work (Cardboard Aided Design) was put into a real CAD system by Luke and everything looks sweet.
This weekend I cleaned up the frame, pulled out the motor that was in the way and charged the batteries (man did that take some time).
Here is the bike ready for major work next weekend. I am hoping to complete the following:
  • battery pack constructed and fitted to bike
  • all battery sense wires connected to the battery pack
  • fuses mounted
  • contactors mounted
  • BMS placed in a case and plugs wired
  • BMS mounted
This would then only leave the following tasks:
  • Controller mounted
  • Water cooling plumbing and mounting
  • 12 volt fuse and battery setup
  • 12 volt wiring
  • All panel work complete
I can see the end of the tunnel.
SplinterOz
SplinterOz
Postby SplinterOz » Mon Feb 06, 2012 6:09 am
Ok so the plates have only just arrived (don't ask) and not all of them yet (don't ask again).
However we have enough to test assemble the pack outside the bike and get all the measurements for all the spacer rods etc.
Battery test construction by Splinter, on Flickr
Last one shows the spacing between the 3mm aluminum plate and the plastic.
SplinterOz
SplinterOz
Postby markobetti » Mon Feb 06, 2012 7:26 am
Beautifull! beautifull , i like it very much. The design is great and it will fit like a charm on the bike
markobetti
Postby SplinterOz » Sun Feb 12, 2012 3:29 am
I will be putting the full pack into the bike next weekend however.. I have had some small progress this week. Between putting in about 60hours each week for the last two weeks and sleeping I have done very little.
However I did get into LiPo! No I am not replacing my nice Headway pack... but I needed a battery pack to start building all my wiring. So three 6S RC packs and some wiring, some sparks and some swearing I have a pack with enough volts to drive all I need for testing.
Test Lipo Pack by Splinter, on Flickr
That has allowed me to test a switch/light combo for the controller turn on. I picked up a pushbutton switch a while back with a illuminated green ring. The ring is just a LED with no load resisters so it runs straight out of the Kelly. 4 Wires pack positive to NO switch to controller on and the two for the LED.
Controller Switch - Off by Splinter, on Flickr
Controller Switch - On by Splinter, on Flickr
I plan to complete my turn on circuit and testing it this week. Next week the last of the battery plates and spacers arrive so I should have the full pack and enough wiring to safely turn it on and off and go for a ride :)
SplinterOz
SplinterOz
Postby jonescg » Sun Feb 12, 2012 4:02 am
Must be so frustrating being so close yet still can't get it to turn a wheel! So the LiPo was just to make sure the Kelly fires up and turns the motor, while testing all the 12 V stuff?
I highly recommend a fuse box from Eastern Beaver (if you haven't already got one from there). And never ground the low voltage wiring. One stray wire and your BMS transistors tend to pop when anything over 4 V hits them.
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby SplinterOz » Sun Feb 12, 2012 4:21 am
Yep got the beaver fuse box. Not really to spin the motor but to do all the DC/DC setup, turn on circuit and the control lights out of the controller. Although these batteries would turn the wheel :).
Yep the frame has neither pack or 12 volt earthed. That is the other thing to get the wiring loom complete.
SplinterOz
SplinterOz
Postby jonescg » Wed Feb 15, 2012 3:37 am
You cracked 10000 views mate! Better finish it up soon! ;)
VoltronII 8)
jonescg
Postby SplinterOz » Wed Feb 15, 2012 4:23 am
jonescg wrote:You cracked 10000 views mate! Better finish it up soon! ;)
It's only a 1000 views because I have taken so long... :mrgreen:
However Dan just sent me my new Sprocket... 64 teeth and 500g. Compared to the old 54 teeth and 1kg.
Old Sprocket by Splinter, on Flickr
New Sprocket by Splinter, on Flickr
SplinterOz
SplinterOz
Battery mounting day!!!
Postby SplinterOz » Sun Feb 19, 2012 1:28 am
So with the help of my good friend [url="http://www.mabula.net/"]Paul[/url] I have got the battery mounted in the bike! I have some photos here of the process and how much "fun" it was.
Firstly I have to construct the centre pack and tighten it all up.
This is all easily done outside the bike on the "comfort" of the garage floor.
Centre batteries and mounting plates together. Yes the hammer (rubber) and wood are used to encourage a snug fit
Close up of a spacer made of aluminum and threaded.
Spacer bolted into place.
Central pack assembled.
Next part was to get the central pack into the bike and bolted to the engine mounts on the frame. High tensile 10mm bolts and nylock nuts.
Central pack mounted on the bike. Note the front mount to the frame uses the original engine mounting points.
Closer shot showing the centre electrical plates resting on the grub screws.
Now the first of the double width batteries go in and I get the centre electrical plates and BMS wires in place... now this was just fiddly and required a contortionists arm.
One side of the double width pack.
The centre electrical plates and the cells screwing together.
Keeping the BMS sense wires out of the way to avoid pinching.
Two man four hand job just to get the cells to line up.
The other side of the batteries are placed in and screwed tight against the plates and other batteries.
Other side of the cells being placed in to hold the electrical plates in place.
Last task today place the outer plates on and "encourage" them to fit snugly over the batteries.
Sizing up the outer mounting plate.
Gently placing the plate over the batteries and making them snug.
Outer mounting plate in place and sitting pretty.
The right hand plate does not sit quite right due to some old mounting points for the air box. I will get them off tomorrow and finish the mounting during the week.
Continues....
SplinterOz
SplinterOz
Battery in Place
Postby SplinterOz » Sun Feb 19, 2012 1:30 am
SplinterOz
SplinterOz
Postby jonescg » Sun Feb 19, 2012 3:31 am
Probably a bit late to suggest it, but should the chassis or the plates be covered in some kind of insulating substance? It gets close in some points.
Otherwise it's looking very neat! Hope you don't have to pull cells out too often.
VoltronII 8)
jonescg
Postby SplinterOz » Sun Feb 19, 2012 4:01 am
jonescg wrote:Probably a bit late to suggest it, but should the chassis or the plates be covered in some kind of insulating substance? It gets close in some points.
Not too late... I had some thick but flexible plastic covering the pates as I was mounting the battery, however it was not good enough for a permanent solution. I am going to get some really thing polycarbonate (or similar) and mount that over all the battery ends. So yes it will all be insulated.
If I have to pull out cells I will probably reshape the outer plates so they don't have the "shoulder" in them so the batteries can just slide out. Inner batteries however will require complete disassembley. I should not be pushing these batteries too hard (not like the race bikes) so I hope they will hold together.
SplinterOz
SplinterOz
Postby jonescg » Sat Feb 25, 2012 1:08 am
5 O'clock Canberra time - surely you have the bike ready by now? :P Can't wait to see the first videos :)
Did you work out if you are required to put some kind of protective housing around the outrunner in order to pass the pits? I was thinking this would probably reduce it's self-cooling capacity.
VoltronII 8)
jonescg
Postby SplinterOz » Sat Feb 25, 2012 3:08 am
That would assume that I didn't mow the lawn, clean out the shed, go to the dump and collapse.
Also I have 4 electrical plates yet to come... sigh... they will be here next week and I will have the pack done and the BMS on. Then I will charge up the battery and mount the motor.
At that point I will have the first visit from the engineer. Just hope he likes the construction :)
SplinterOz
SplinterOz
Postby Bluefang » Sat Feb 25, 2012 10:01 am
most likely the engineer with have NFI what you have done or created :) Good luck with getting it certified, should be pretty easy as you should be able to get it done under a engine swap mod plate
viewtopic.php?f=10&t=49912 Current build, Electric flat tracker
Bluefang
Postby SplinterOz » Sat Feb 25, 2012 4:38 pm
Bluefang wrote:most likely the engineer with have NFI what you have done or created :) Good luck with getting it certified, should be pretty easy as you should be able to get it done under a engine swap mod plate
I am getting the Engineer that the fabrication company I have been working with use all the time. Hopefully that will make things go easier. I heard that you guys up in Qld were just getting the engine swap checked and little or none of the electronics and electrics certified.
SplinterOz
SplinterOz
PreviousNext
Return to E-Scooter and Motorcycle General Discussion
Users browsing this forum: Kent and 2 guests
