the motor was modified by Farfle. In order to accomodate the larger wires, he must have drilled out too much from the axle and made it too weak..
Just a warning not to overdo it...
Farfle wrote:No, the X5's are not the same size as the hx axles but yes, they can be pressed out. They are not a splined shaft, you use a linear knurling tool with coarse teeth, I bought this one: http://www.grizzly.com/products/2-pc-Kn ... -Set/H5936
and it held up for about a month until it wore out, but it's 1/10th the cost of a good one.
NeilP wrote:I have been considering a torque plate with a 'metalastic' type fitting, you know what I mean? something to still prevent axle rotation but with enough give in it to take out these shock loadings that are probably a contributing factor on these failures..or just thicker axles I suppose
miro13car wrote:Wondering what would be the cost of such rebuilding of HS/HT motor presuming you don't pay for drawings, charging US$50 labour rate and and material easy US$ 1000 I would say but I think much more maybe 1500.
Only taking such motor apart with Chinese using thread locker compond is a challange and time consuming and their choice of Philips screws for cover is complete ignorance , because standard screw for such application is Allen bolts , well but they cost cents each more.
Machining new axle is only beginning of mods, reboring and replacing bearings is another mod, next replacing halls with quality ones, after that what else
China manufacturing is obssesed with cost savings?
Such modified HT/HS is not exactely cheap anymore,
miro13car wrote:you forgot cooling system with liquid weights also , right?
There something wrong with hub motor needing cooling at even 2000W.
There is something wrong with the motor which simply needs to draw so much power, to much power to reach say 35mph comparing with other motors .
So the question should be why it needs to draw so much to produce?
Users browsing this forum: chisixer6, Danny Mayes, neithermovingnorstill and 11 guests
