low budget pocket rocket
Postby nonlineartom » Thu Mar 15, 2012 6:52 pm
I picked up an 8T mac in a 20" wheel dirt cheap off a forum member, so I had to think of something good to do with it.
So I picked up a beat up BMX for £10, I've never ridden a BMX before so decided to use it as a regular pedal bike for a week or 2 running errands and I'm really pleasantly surprised, it accelerates like a bullet and with such low rolling resistance even with one gear It's way way more fun than my XC MTB bike.
I also picked up a 1500W Hua Tong controller for £15 off a forum member bringing the total cost minus batteries to under £70. I plan to run on 18S of lipo and run this motor into the ground.
I opened up the motor and all looks good inside, hardend gears and lots of grease, perhaps I will drill the casing for ventilation (stupid idea right?)
Phase wires are now 10AWG using these block connectors for testing purposes
I spent a whole evening wiring up connectors to the motor and controller (I REALLY suck at soldering but I'm persistent) and decided to film my first attempt at getting the gears turning, I could have deleted the clip but I thought it was worth sharing my magnificent fail
You can almost hear the cogs turning in my brain as it dawns on me the epic fail I just achieved. :/
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
nonlineartom
Re: low budget pocket rocket
Postby Farfle » Thu Mar 15, 2012 7:16 pm
DOH!! :lol: :lol: :lol:
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby nonlineartom » Thu Mar 15, 2012 7:22 pm
DOH indeed, or as we say in England ... "hmmm" apparently
So, at the risk of sounding like the perpetual n00b. Whats the easiest way to get this going the correct direction?
nonlineartom
Postby www.recumbents.com » Thu Mar 15, 2012 7:39 pm
Try flipping around two of the phase wires.
www.recumbents.com
Postby gwhy! » Thu Mar 15, 2012 8:07 pm
play around with phase and hall wire combo's. I found with the hub motors that i have played around with even if the motor turns the correct way this do not always mean that the correct combo has been found, I always use a current meter and a tacho, sometimes the wheel will run faster than expected and draw nearly 2 times the current ( not good for your controller or the motor )
gwhy!
Postby liveforphysics » Thu Mar 15, 2012 8:42 pm
gwhy! wrote:play around with phase and hall wire combo's. I found with the hub motors that i have played around with even if the motor turns the correct way this do not always mean that the correct combo has been found, I always use a current meter and a tacho, sometimes the wheel will run faster than expected and draw nearly 2 times the current ( not good for your controller or the motor )
Yup. That's what we call a "false positive". There are 2 false postives for each 1 correct combo.
On sensorless, you can simply swap any 2 phase leads and it reverses direction. With sensored, you need to swap both a pair of halls and a pair of phase leads. Knowing which ones requires an O-scope and some skills. However, you can simply trial-and-error your way to finding the correct combo.
liveforphysics
Postby Beachcruzer » Fri Mar 16, 2012 12:03 am
Bike is gonna be badass though. 70 quid well spent.
Looking forward to video of your triumphant return.
Beachcruzer
Postby nonlineartom » Fri Mar 16, 2012 3:04 am
Thanks for all the replies. I presumed the colour coding was standard as I use an almost identical Cell_man 12fet with the mac on my commuter so figured the colour coding would be just the same.
I wish the pins on the hall connector weren't so monumentally fiddly to remove and swap around. Nothing is ever easy.
Video update this weekend
nonlineartom
Postby Philistine » Fri Mar 16, 2012 3:56 am
Can't wait to see it going. I was in the process of putting a 20inch 2805 on a 20inch Haro 1980s BMX I picked up, which I wanted to run on 20S. In the end I had a friend who had a more practical use for the motor, and the project never materialised. I can't say I wasn't a little bit worried about how I might die on it, I imagine it will be a lot of fun though.
When you ran the cell_man controller was the colour combo Blue matching on phase and halls, and yellow and green swapped on phase and halls? If not give that combo a try. That is the combo that works on my Lyen infeneon and a BMC (I would have thought the BMC and Mac would be same colour combos.
Philistine
Postby nonlineartom » Fri Mar 16, 2012 5:10 am
This is brilliant, so far 3 different people have suggested 3 entirely different colour combinations for the phase wires!
I'm going to try David Silva (neptronix) solution first as posted on the ES FB group which is to swap blue and yellow. His logic being cell_mans infienon controller which looks like the lyen, has yellow and blue shrink wrap covering the yellow and blue phase wires to make them appear the opposite colours. Logic would suggest that swapping these 2 phase wires over on the Lyen will make it behave, which of course means swapping the hall wires too, which will involve a lot of swearing trying to release the tiny barbs on the connector pins to free them.
On a side note, will I need a torque arm with this? The axle is a VERY tight fit in the deep horizontal slot, it's flat aluminium plate and quite thick. It looks stronger and thicker than the universal torque arm I was going to add?
Ride video this weekend
nonlineartom
Postby nonlineartom » Fri Mar 16, 2012 4:21 pm
Neptronix wins!!!! blue and yellow phase wires needed reversing and now it spins in the right direction.
So all sorted yeah?
PAH like hell it is... video on the way.
At least I'm providing some comedy with this thread
nonlineartom
Postby nonlineartom » Fri Mar 16, 2012 4:26 pm
It's mocking me now. The only thing I can think of is that the one way clutch bearing is back to front, even though this is a new motor and I haven't taken the clutch out at any point.
Anyone got any wisdom to share?
nonlineartom
Postby nonlineartom » Fri Mar 16, 2012 4:41 pm
Just dawned on me..... Is the wire supposed to exit on the drive side? this is the non disc version of the mac motor. Have I put the freewheel on the wrong dam side of the motor and put the whole thing back to front?
nonlineartom
Postby Philistine » Fri Mar 16, 2012 5:49 pm
On my BMC the wires come out the disc side (ie NOT the chain side). How did you get the free wheel on the disc side?
Philistine
Postby nonlineartom » Fri Mar 16, 2012 6:01 pm
SO the phase wires were right first time, and I've put the freewheel on the wrong side, sometimes my stupidity amazes even me. The disc side is threaded, with the same thread as a freewheel I'm guessing!
kinda wish I had a freewheel removal tool now...
nonlineartom
Postby Philistine » Fri Mar 16, 2012 6:54 pm
If you don't have the proper ebike freewheel removal tool (with the larger opening), you can just get a standard bike shop removal tool, and use a dremel with a carbide bit to widen the opening, that is what I did, took 5 minutes to do.
Philistine
Postby veloman » Tue Mar 20, 2012 12:20 pm
I got a kick out of these videos. I think I did something similar before.
Yup, time to flip the wheel around... and go back to original wiring.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby nonlineartom » Tue Mar 20, 2012 4:13 pm
Done, getting a big of rub on the frame, need to put a washer in there to stop it grinding, but I can only stretch the dropouts using a scissor jack, removing the jack makes it return to it's original width (aluminium) and I don't want to over stretch and break the frame. I can't seem to widen the frame enough to fit it in with the washer and get the wheel in at the same time.
On the upside it looks absolutely bad ass.
nonlineartom
Postby knoxie » Fri Mar 23, 2012 5:48 pm
You will need a torque arm if that frame is ally, trust me :P My BMX still works 6 years now since I did this video, it was breaking spanners and shredding metal, if you dont it will snap your drops if they are ally, the one way bearings can go but they can be replaced but yes and ahem you had this the wrong way around :twisted: but yes fit torque arms, you can see what it does on my video, crikey this is an old one!!
[googlevid]1721490376015071704[/googlevid]
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby nonlineartom » Sat Mar 24, 2012 10:50 am
Yeah they are ally dropouts, really quite thick beefy bits of metal though (side loading axle) and a very tight fit but I'll fit a Lyen universal torque arm for now and then mig weld one of Docs torque arms in the future, I've already had the freewheel go in my 10T mac motor on my commuter.
All I'm missing now is a 14mm axle nut and I'll give it a test, should probably fit some functioning brakes too. What did you do for battery on yours?
nonlineartom
Postby nonlineartom » Sun Mar 25, 2012 3:16 pm
This thing is terrifying. Noisy as well, sounds like a formula one car in a box. Goes like a rocket. Taped everything up for a test ride today and it launches better than my X5 motor.
Next up I will put this motor on the trike and test it at 4kw. Has anyone ever drilled ventilation holes in a mac motor? or is that just stupid
photo 2.JPG (185.58 KiB) Viewed 976 times
nonlineartom
Postby nonlineartom » Sun Mar 25, 2012 3:30 pm
note the complete lack of brakes at the end resulting in the good ole foot brake method. I need to make this thing a lot more refined before actually riding it properly.
nonlineartom
Postby nonlineartom » Sun Mar 25, 2012 5:14 pm
Mike has found a name for this machine. Its now called:
I.N.N.U....
I need new underpants
nonlineartom
Users browsing this forum: Drunkskunk, rusty67, warrah and 11 guests
