Sparks shot out and blew a hole in the paniers.
When I retrieved my keys I found 2 of them were arch-welded to each other.
Ypedal wrote:Damn.. 56 to 4 to far !!!...
mdd0127 wrote:I did the same thing! We built an Isuzu pickup with six Cerwin Vega Stroker 12's and six custom, one off linear power 2500 watt monoblock amps. I can't remember how many yellow tops we had in there but we used 1" X 1" aluminum bar for the buss bars and after tightening the last battery, the wrench slipped out of my hand. It instantly vaporized in the middle and I swatted the molten metal off of the top of the battery before it did any damage. We had to bolt a chunk of 2" x 4" solid aluminum from between the seats to the top middle of the windshield frame to keep the 3/4" lexan windshield from blowing it's rivets out! That truck was hitting 174.9db......in 1996!
The most recent battery short was while demonstrating the coolness of my lipo parallel blocks to someone. As I was saying, "I designed these so that the batteries can only be plugged in correctly.", I touched the lipo bullets to the parallel block in reverse polarity causing a giant spark and the instantaneous vaporization of the two 75A castle bullets that connected the pack to the controller. My ego has a scar from that one...didn't burn my fingers though! While it was impossible to actually plug the battery packs in backwards, it sure wasn't impossible to touch the terminals together!
Doctorbass wrote:mdd0127 wrote:I did the same thing! We built an Isuzu pickup with six Cerwin Vega Stroker 12's and six custom, one off linear power 2500 watt monoblock amps. I can't remember how many yellow tops we had in there but we used 1" X 1" aluminum bar for the buss bars and after tightening the last battery, the wrench slipped out of my hand. It instantly vaporized in the middle and I swatted the molten metal off of the top of the battery before it did any damage. We had to bolt a chunk of 2" x 4" solid aluminum from between the seats to the top middle of the windshield frame to keep the 3/4" lexan windshield from blowing it's rivets out! That truck was hitting 174.9db......in 1996!
Are you sure of your 174.9dB score you mentionned?.. because the loudest SPL that waas made in 1998 it was John Henry with the 12x 12inch woofer and the Mmats amp that had 174.7dB back in 1998.... i think no one ever beated that score BEFORE 98 ?
Doc
Ypedal wrote:Heh Heh.... i hates bullets.....
Andersons all the way.( no matter how many people try to convince me otherwise )
Ypedal wrote:Yes, i've tried bullets on a few builds, after messing with them for a couple weeks i took them off after making sparks ( shielded bullets.. still managed to get sparks.. )
mdd0127 wrote:Ypedal wrote:Heh Heh.... i hates bullets.....
The 75A bullets actually acted like a 150A fuse! I'm glad they melted! Running Andersens on anything powerful is just asking for problems. They barely handle their rated current and don't make good enough connections IMHO.
