Agni 95R mounting plate
Looking for something? Need a special part, but can't find it online anywhere? Post what you need, maybe others will have it to sell. Guest may post replies to topics already here. All topics here will expire after 60 days of inactivity.
Postby Ypedal » Thu Mar 22, 2012 9:32 am
Yes i know.. i can cut and drill one out from sheet steel.. but i'm looking for a nice pre-fab plate if possible....
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Re: Agni 95R mounting plate
Postby Jozzer » Thu Mar 22, 2012 10:53 am
8mm-10mm aluminium plate is our favorite for the job..
What is it to fit too (vehicle)?
Jozz
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h Turnigy pack.
www.Jozztek.com
Jozzer
Postby BlackArrow » Thu Mar 22, 2012 10:57 am
HI Jozzer,
I think, that he will use this motor on his new trike but i'm not sure :wink:
Good day!
Black Arrow
BlackArrow
Postby Ypedal » Thu Mar 22, 2012 11:06 am
well, 2 possibilities.. one is a Honda XR200r , the other is a KMX trike ( not my new cobra on the way, but a 2nd one i am about to pick up.. ) :o
Ypedal
Postby Jozzer » Thu Mar 22, 2012 11:27 am
Well, we could make one up to a pattern for you, but I bet you'll find someone local with a milling machine and some free time. An offer of a very scary ride on a 30hp KMX should be worth an hour of milling:D
Jozz
www.Jozztek.com
Jozzer
Postby Ypedal » Thu Mar 22, 2012 11:39 am
Hmm.. agreed.
I am surprised however that there are no vendors selling pre-stamped plates for this motor.. i googled a number of times with no success, i'm either searching the wrong thing.. or people just make their own every time.. odd.
Ypedal
Postby Jozzer » Thu Mar 22, 2012 11:50 am
Problem is the mountings for the vehicle need to be cut into the plate too. The plate size/shape can vary greatly. We must have made over 30 mounting plates for Agni's and no 2 were the same. I've actually had 3 completely different mounts on the same Aprilia over the years..
There used to be a vendor selling a simple star shaped mount for the etek - but it was years ago when I saw it and I can't remember where..
Steve
www.Jozztek.com
Jozzer
Postby Ypedal » Thu Mar 22, 2012 1:38 pm
makes sense...
So , a question then, the agni site says it's ok to mount the motor on only one face and using one of the 2 diameter faces.. Do you guys bolt down the motor front and back regardless?
Ypedal
Postby Jozzer » Thu Mar 22, 2012 3:13 pm
No, we prefer to use the outer ring of M6 holes with at least 4 bolts. No need to bolt the back end (in fact, new motors don't even have holes on the backplate). Best to make as large a hole as possible around the shaft (ie. nearly the full diameter of the motor) to allow air to enter the ring of holes near the circumference on the endplates.
Using the centre mounts often fouls the shaft/sprocket area - as well as blocking the intake vents.
I think sensibly you should build the motorbike - but I want you to build a drift trike:D
Steve
www.Jozztek.com
Jozzer
Postby Doctorbass » Thu Mar 22, 2012 3:41 pm
Maybe Ypedal you could go on the new TTXGP forum and ask directly to cedric tonight.. he will be live! for asking questions! :wink:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Ypedal » Thu Mar 22, 2012 3:48 pm
Cool !,. i have to check that out....
no sense in wasting his time with my simple problems, i'm sure he's got more important people to deal with ! :P
Ypedal
Postby grindz145 » Thu Mar 22, 2012 3:59 pm
haha an Agni powered KMX.... That would be something :)
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby Doctorbass » Thu Mar 22, 2012 4:01 pm
I think that the agni you got from Black arrow would be awsome on the KMX ! :D
I know what performances i get with the X5 at full power so with like 2x more power :shock: :shock:
Would be awsome!
Ther is plenty of room on the back of the seat for teh motor anc controller and you could place the battery right under your legs on the T junction of the frame wich i found really improoving stability!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby E-racer » Thu Mar 22, 2012 4:11 pm
sorry this is completely OT but Jozzer do you have pics of your Miata with rc lipo? I have to see that thing.
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Postby Jozzer » Fri Mar 23, 2012 4:37 am
E-racer wrote:sorry this is completely OT but Jozzer do you have pics of your Miata with rc lipo? I have to see that thing.
I'm just heading abroad for a few days, but I'll try to take some snaps and start a thread when I get back. It wasn't a big deal, nice big open boxes to work with - only took a day to assemble the largest pack.
Jozz
www.Jozztek.com
Jozzer
Postby jonescg » Fri Mar 23, 2012 4:48 am
Gaston, I suggest you get them laser cut from 8 mm aluminium. I got mine done that way, then had them TIG welded in place on a precision jig. The laser cutting and materials came to $108
Me just dicking around with the plates:
The end result:
I have way too many bolts on them - just one on the centre ring and 6 around the outer ring is all that's needed.
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby Ypedal » Fri Mar 23, 2012 7:56 am
Daaaamn.. now that's a sight ! :shock:
I gave the motor to my neighbor last night, he's going to drop in at a local metal shop today and see what's what, should find out later today....
And i've made up my mind about the honda vs KMX.... i should be getting a total $$$ for shipping the KMX shortly !! :twisted:
the honda would be restricted to off-road.. the KMX i can slap on a " 200w " sticker and use on the streets ! :P
Ypedal
Postby regmeister » Mon Apr 02, 2012 3:30 pm
Mr ypedal,
you could have emachineshop do a plate for you fairly cheap.
If you go with a relatively universal design, let me know and perhaps we could have two made up at the same time. Myself, I'm looking for something like this:
regmeister
Postby Ypedal » Mon Apr 02, 2012 4:44 pm
I been messing with that emachineshop app, not too hard to figure out, only thing i canot find is material thickness.... searching help...
Jozz or anyone else , if you happen to have a cad file or whatever format water jet guys use, a good friend of mine is friends with a guy who owns a big waterjet and said if i can provide a file he can get me a quick quote..
one other shop in town here for 3/8 aluminum, was talking 280 canadian $$$ !!.. :shock: .. i'm sure i can do better than that.. but i admit .. this is new ground and i'm not familiar with what these things cost. so .. :)
Ypedal
Postby Jozzer » Mon Apr 02, 2012 6:28 pm
I bet Miles or one of the other CAD guru's would knock you up a file.. In fact, I bet I could get Agni to have a batch produced if it proves popular.
I'd suggest 8mm Aluminium minimum - 10mm optimum, but you probably won't be going for full power very often - the KMX will bend before an 8mm mounting..
$280 just for the ally? I'd expect less than $60 (based on UK prices).
www.Jozztek.com
Jozzer
Postby regmeister » Mon Apr 02, 2012 6:33 pm
re: material thickness, it is 3d so in general - the Z-axis is the thickness. you don't see it, unlessyou have something selected.
to play with, here is a mount I was last mucking around with. You can save it as an xml file and load it into emachineshop. Please be aware, there may be real design errors, not just the obvious logical ones...
<?xml version="1.0"?>
<eMachineShop3DObjects VersionId="1.0">
<View Type="Top">
<Region BaseHeight="3.175" RelHeight="-3.275" WallAngle="90" BottomType="Drill">
<Machine Id="41" Name="Auto"/>
<Contour>
<Circle Center="101.548174,4.547434" Radius="3.05"/>
</Contour>
</Region>
<Contour>
<Circle Center="4.547954,101.547654" Radius="3.05"/>
</Contour>
</Region>
<Contour>
<Circle Center="73.137467,73.136947" Radius="3.05"/>
</Contour>
</Region>
<Contour>
<Circle Center="4.547954,-92.452785" Radius="3.05"/>
</Contour>
</Region>
<Contour>
<Circle Center="-64.041559,-64.042079" Radius="3.05"/>
</Contour>
</Region>
<Contour>
<Circle Center="-92.452265,4.547434" Radius="3.05"/>
</Contour>
</Region>
<Contour>
<Circle Center="-64.041559,73.136947" Radius="3.05"/>
</Contour>
</Region>
<Contour>
<Circle Center="73.137467,-64.042079" Radius="3.05"/>
</Contour>
</Region>
<Region BaseHeight="3.175" RelHeight="-3.275" WallAngle="90" >
<Contour>
<Circle Center="4.547954,4.547434" Radius="88"/>
</Contour>
</Region>
<Contour>
<Arc Center="101.207895,72.229454" Radius="4.05" StartAngle="215" IncAngle="180"/>
<Arc Center="4.547954,4.547434" Radius="122.05" StartAngle="35" IncAngle="10"/>
<Arc Center="87.986554,87.986034" Radius="4.05" StartAngle="45" IncAngle="180"/>
<Arc Center="4.547954,4.547434" Radius="113.95" StartAngle="45" IncAngle="-10"/>
</Contour>
</Region>
<Contour>
<Arc Center="4.547954,4.547434" Radius="113.95" StartAngle="325" IncAngle="-10"/>
<Arc Center="87.986554,-78.891166" Radius="4.05" StartAngle="135" IncAngle="180"/>
<Arc Center="4.547954,4.547434" Radius="122.05" StartAngle="315" IncAngle="10"/>
<Arc Center="101.207895,-63.134585" Radius="4.05" StartAngle="325" IncAngle="180"/>
</Contour>
</Region>
<Contour>
<Circle Center="114.547954,4.547434" Radius="6"/>
</Contour>
</Region>
<Region BaseHeight="0" RelHeight="3.175" WallAngle="90" >
<Contour>
<Arc Center="4.547954,4.547434" Radius="130.00052" StartAngle="125.374913" IncAngle="109.250335"/>
<Straight P1="-70.712196,-101.452778" P2="79.807505,-101.452566"/>
<Arc Center="4.547954,4.547434" Radius="130" StartAngle="305.37459" IncAngle="109.250819"/>
<Straight P1="79.807505,110.547434" P2="-70.712495,110.547434"/>
</Contour>
</Region>
<Contour>
<Circle Center="-105.452343,4.547434" Radius="6"/>
</Contour>
</Region>
<Contour>
<Arc Center="-92.111987,72.229454" Radius="4.05" StartAngle="145" IncAngle="180"/>
<Arc Center="4.547657,4.547434" Radius="113.94979" StartAngle="144.999914" IncAngle="-10.000016"/>
<Arc Center="-78.890646,87.986034" Radius="4.05" StartAngle="315" IncAngle="180"/>
<Arc Center="4.547657,4.547434" Radius="122.04979" StartAngle="134.999898" IncAngle="10.000022"/>
</Contour>
</Region>
<Contour>
<Arc Center="4.547954,4.547434" Radius="122.05" StartAngle="215" IncAngle="10"/>
<Arc Center="-78.890646,-78.891166" Radius="4.05" StartAngle="225" IncAngle="180"/>
<Arc Center="4.547954,4.547434" Radius="113.95" StartAngle="225" IncAngle="-10"/>
<Arc Center="-92.111987,-63.134585" Radius="4.05" StartAngle="35" IncAngle="180"/>
</Contour>
</Region>
</View>
</eMachineShop3DObjects>
regmeister
Return to Items Wanted
