Upgrade From Ampedbike Kit To YescomUSA 48 Volt 1000 Watt
Postby cruiserbikeman » Sun Mar 18, 2012 12:16 pm
Right now I'm using an Ampedbike Kit (36v 750 Watts) with a Ping 48 Volt 15ah battery. While I like the ampedbike kit, I've noticed the controller heats up a lot in warm weather. So I wanted to go with a true 48 volt controller with an increase in wattage YescomUSA Kit (48v 1000 Watts) instead. I do want to order it this week. However, I wanted to get some advice from some board members before I make the purchase.
EW-88 Electric Trike
Schwinn Clairmont Cruiser 26 inch
Ampedbike 36-60 volt controller 750 Watt Front DD Motor
60 volt, 48 volt(sold), and 36 volt(sold) Ping Lifepo4 Batteries
cruiserbikeman
Re: Upgrade From Ampedbike Kit To YescomUSA 48 Volt 1000 Wat
Postby dogman » Sun Mar 18, 2012 1:00 pm
In my opinion, performance will be relatively similar. With that battery, you are about at the top for wattage, but you could perhaps bump to a 12 fet controller that might run cooler, but have it set to no more than 25 amps.
You are aware, that very likely you see 1200w momentarily on your current setup?
To keep the controller cooler, run WOT more. :twisted:
dogman
Postby cruiserbikeman » Sun Mar 18, 2012 1:40 pm
I do ride with wide open throttle in conjunction with using the seventh gear when pedaling uphill. In addition, I have a electric tricycle with a 450 watt direct drive front hub and a 48 volt controller. Its connector is only designed to work with a SLA battery. When I hooked it up the ampedbike controller to the tricycle hub it actually works! So, I'll just go ahead and put that kit on to the tricycle and buy a new kit for the cruiser.
cruiserbikeman
Postby wesnewell » Sun Mar 18, 2012 6:02 pm
I've bought 3 yescomusa kits and all 3 have come with 30A controllers. The 48v 500w kits come with a 12 fet controller and the 48v 1000w kit came with a 15 fet controller. All have had 63V caps and 68v fets. I replaced the controller on the 1000W motor with a 72v 40A controller with 100V caps and fets for $35.
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Postby ez-Ebike » Mon Mar 19, 2012 12:19 am
It'll be tough to order this week because the 48V 1000W rear kit is out of stock! I emailed them to see when the new shipment will come in, I'll update you if you are interested.
ez-Ebike
Postby dogman » Mon Mar 19, 2012 8:40 am
That would be an upgrade then, to a 30 amp controller. You got a battery that can handle that? If not, you better upgrade batteries too.
I don't recomend a 15 ah ping for a controller over 25 amps.
30 amps x 48v = 1440 watts. And I predict a CA would see real world 1600w since "48v" runs at around 58v hot off the charger.
dogman
Postby cruiserbikeman » Mon Mar 19, 2012 2:47 pm
Thanks for the input. I will most likely buy a front wheel kit since I have the battery on a rear rack in a hard plastic case.
cruiserbikeman
Postby cruiserbikeman » Mon Mar 19, 2012 2:50 pm
dogman wrote:That would be an upgrade then, to a 30 amp controller. You got a battery that can handle that? If not, you better upgrade batteries too.
What'll happen? Will the battery drain too fast or will the BMS constantly shut off?
cruiserbikeman
Postby dogman » Tue Mar 20, 2012 7:29 am
A battery should be used within it's c rate. so a 40 amp controller would be able to discharge your 2c ping battery at nearly 3c.
I tend to recomend 25 amps max for 15 ah ping, so you won't pull even 2c continuous up a hill into the wind some day.
The general rule of thumb is batteries last longer if you use them closer to half the c rate. For a 15 ah ping, 15-20 amps continuous is good for them. 30 amps continous is not.
Hammer a battery hard and nothing happens if all 48 cells are perfect. But nobody has 48 perfect cells. What happens in reality if you hammer your ping is that one cell wears out much quicker than the others, and you get a 500 cycle battery instead of a 1000 cycle battery. The weak cell gets damaged, and when it dies, you now have 1/3 less capacity because of just one cell that died.
Same thing that makes cheap ebay batteries that way, right out of the box.
dogman
Postby ez-Ebike » Tue Mar 20, 2012 3:27 pm
Are you sure you want a FWD 1kw kit? That seems like a lot of power for a front fork. Just concerned about safety after seeing some of the threads on here.
ez-Ebike
Postby cruiserbikeman » Thu Mar 22, 2012 6:39 pm
I understand now. I don't want to ruin a battery pack that I had for a little over two months. I'll stick with what I have now since I had this current kit for less than six months. After this kit runs its course, I'll then look towards stepping up to a faster kit and a bigger battery.
cruiserbikeman
Postby cruiserbikeman » Thu Mar 22, 2012 6:41 pm
ez-Ebike wrote:Are you sure you want a FWD 1kw kit? That seems like a lot of power for a front fork. Just concerned about safety after seeing some of the threads on here.
I have a steel fork and frame. I decided to hold off and keep using my Ampedbike kit at least for the rest of this year.
cruiserbikeman
Postby motomech » Thu Mar 22, 2012 7:49 pm
I see YESCOM USA rear kits on US Ebay.
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Users browsing this forum: Jesse853 and 14 guests
