Conclusion: The Leaf doesn’t begin to pencil out unless we drive over 72 miles/day. That seems a bit extreme for the casual commuter. REdiculous, I concede to your point. The annual miles are an eye-opener.
liveforphysics wrote:Its kinda fighting the enevitable to not go electric. We are just one big battery chemistry improvement from it making sense for ~98% of the vehicle use model for ~98% of Americans.
One battery chemistry improvement could be real big without being enough. If you have a 5 mile trip an electric scooter can work out great right now, if you can ride. I don't expect to see this 98/98 you're talking about in my lifetime.
Right now I'd settle for the LiPo performance without the pyrotechnic potential.
REdiculous wrote:One battery chemistry improvement could be real big without being enough. If you have a 5 mile trip an electric scooter can work out great right now, if you can ride. I don't expect to see this 98/98 you're talking about in my lifetime.
Yup...
Even if the capacity doubled for the same weight/size/cost, it still wouldn't be enough. Rather than "100 miles" in a Leaf you could do as much as 200 miles. woop-de-freakin-do; that's a 3 hour drive at 65mph and you're done.
This doesn't really matter for anything, but my truck needs an oil change every month just based on the miles it's been seeing -- easily averaging 100mi/day.![]()
Fireworks are cool, they just need to be cheaper and more widely available! Right now I'd settle for lipo performance at half the cost. Physical size and weight could double for all I care - I want performance on the cheap.
Arlo1 wrote:3 hours in my gas burning car and im done too the GAS tank is empty. They have charging stations set up for the leaf to fast charge they get 80% charge in 28 minutes. And someone set a world record with a leaf up the I5 it is 1200km in 24 hours! So dont tell me you can't use it for long trips!
REdiculous wrote:Arlo1 wrote:3 hours in my gas burning car and im done too the GAS tank is empty. They have charging stations set up for the leaf to fast charge they get 80% charge in 28 minutes. And someone set a world record with a leaf up the I5 it is 1200km in 24 hours! So dont tell me you can't use it for long trips!
What do you drive?...I think most cars will do 6 hours on a tank, on the freeway, and still have some range to go hunting for the cheap gas.![]()
745 miles in 24 hours is pathetic. That should take 12 hours if you drive the speed limit, but that's only allowing 40 minutes of down-time for potty breaks, refueling, etc.
Arlo1 wrote:REdiculous wrote:Arlo1 wrote:3 hours in my gas burning car and im done too the GAS tank is empty. They have charging stations set up for the leaf to fast charge they get 80% charge in 28 minutes. And someone set a world record with a leaf up the I5 it is 1200km in 24 hours! So dont tell me you can't use it for long trips!
Srt4 and the most i seem to fit is 42 litres when the fuel light is flashing. I get 3-4 hours a tank 375-500 km most the comuting i do althought driving 95-100 km i have got 600 on a tank once. All im saying is you are looking at long travels way to much. I drive 70km a day and a leaf would be great for me!
liveforphysics wrote:If you need to regularly travel 200miles at a time (and delivering things isn't your occupation), you have chosen an extremely wasteful of your life/time and resources lifestyle.
I drive 0.8miles to work. I used to drive 1.1miles to work. It's not by chance, it's because I choose to not give that portion of my life to sitting in a car rather than doing awesome things.
If a 200mile EV can't satisfy 98% of your vehicle needs, it's really time to look into improving the way you live IMHO.
REdiculous wrote:A Leaf probably would work really well for you. Your commute is in the butter-zone; not too much but not too little. If it's worth the cost of entry, I dunno. You can work some numbers for yourself, but I still think I'd get something like the Versa if I had to buy new, or I'd look for a decent used car for around $5k.![]()
ProDigit wrote:..... and all of a sudden you have a bike that travels 70miles, at 35MPH. If that bike would require no license, or insurance, all of a sudden everyone would be wanting one of those!
hybrids are the worst of both worlds.
ProDigit wrote:hybrids are the worst of both worlds.
I would not say that! There are electric vehicles that are powered by a ~4hp (or was it 4kW?) engine/generator. Those things have quite some torq, but also have amazing MPG ratings (like in the hundreds of MPG's).
The small lawnmower like engine drives a generator to provide a constant source of power. The electrical engine is selected in such a way when the car is driving below ~50-60mph, the energy it uses is about the energy the generator generates. If used faster it will use direct drive to aid the electric motors. When accelerating mostly battery power will be used. When slowing down or standing at a stop light, the battery gets recharged.
That way you keep noise levels down, consume only low amounts of gasoline, and when you need it, have the torq from the batteries. Also, the direct drive helps since it gets the energy straight from the tiny engine instead of having part of it lost in a conversion process (converting from movement to energy, back to movement).
I think some hybrids are very well designed, but not many.
Kurt wrote:
Yes I know the concept behind hybrids and the advantages on paper but really the other than range a can see no reason to go down that road. Big battery and big electric motor all electric is the answer. Can you imagine a hybrid ebikewhat a nightmare it would be with no real advantage.
Kurt
Return to E-Vehicles General Discussion
