Dual rotor axial flux motor design
Re: Dual rotor axial flux motor design
Postby Miles » Wed Apr 04, 2012 3:37 am
Miles wrote:Accepting some imbalance, I'm leaning towards increasing the number of turns from 4 to 6 and missing out the first half turn from the first module of each phase. Might as well gain the advantage of losing an endturn, too :D
Reasonable compromise?
I kept the endturn for the sake of uniformity :)
It makes for a neat connection.
Miles
Postby Miles » Wed Apr 04, 2012 5:28 am
Data for the 6t wind:
Kv 100 rpm/V (estimated)
Kt 0.0955 Nm/A (estimated)
Rm 8.8 milliohms (calculated)
Nominal speed 4000 rpm
Flux frequency at nominal speed 533 Hz
Core volume 8.5222E4 cubic mm (calculated)
Core mass 0.672 kg (calculated)
Voltage @ nominal speed 40V
Total parasitic losses @ nominal speed (Arnolds thin gauge GO 0.15mm @ 1.5T) 40 Watts (estimated)
No load amps @ 40V 1amp (estimated)
Miles
Postby Miles » Wed Apr 04, 2012 6:33 am
Above data in Drive Calc:
Miles
Postby Miles » Fri Apr 06, 2012 12:00 pm
Finished designing the stator (for now...)
Miles
Postby Miles » Sun Apr 08, 2012 4:30 am
Comparison with Astro 3220 7t which weighs the same as my 'motor' and has the same torque constant. Not fair to compare theoretical against empirical but interesting nevertheless...
Miles
Postby fechter » Sun Apr 08, 2012 10:40 am
8X less loss at the current limit would be nice. If you can come anywhere close to predicted it will be great.
fechter
Postby Miles » Mon Apr 09, 2012 3:25 pm
Just because I like rendering... :)
Miles
Postby TylerDurden » Mon Apr 09, 2012 6:45 pm
Bling! :mrgreen:
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Postby Miles » Tue Apr 10, 2012 6:27 am
TylerDurden wrote:Bling! :mrgreen:
Miles
Postby fechter » Tue Apr 10, 2012 8:21 am
Solid gold windings should have less resistance than copper. :wink:
fechter
Postby Miles » Tue Apr 10, 2012 8:41 am
fechter wrote:Solid gold windings should have less resistance than copper. :wink:
You'd think so but apparently not, which is why they are gold plated silver :wink:
Ref: http://www.thecarpcstore.com/cms/index. ... &Itemid=68
Miles
Postby TylerDurden » Tue Apr 10, 2012 8:57 am
And the stator lams?
Have a Nice Day,
TD
TylerDurden
Postby Miles » Tue Apr 10, 2012 9:04 am
TylerDurden wrote:And the stator lams?
Platinum plated Cobalt alloy :P
Miles
Postby Arlo1 » Tue Apr 10, 2012 9:36 am
Sounds like a cheep build so lets get to production.
And Dave who has some good deals on STUFF Incl. Mosfets, Current sensors and Nomex paper.
Arlo1
Postby Kingfish » Tue Apr 10, 2012 11:58 am
Plating: I believe that to assuage intermetalics between layers that it needs to be Copper-Nickel-Gold. 8)
Quick, place it under glass so it won't get dirty...
A jewel to behold in any Keep! KF
* My 2WD Garden Wall
* Current ride: 2WD Disc EBikeKit (9C 2806-equivalent) / Dual Lyen 12FET / 15S6P LiPo when commuting.
* Going to California: 2011: Trip completed 8)
* Club Member: 40-mph & 101. 10k-Club: 9683 miles-to-date, 4193 as 2WD.
Kingfish
1.21 GW
1.21 GW
Postby TylerDurden » Wed Apr 11, 2012 1:49 am
But of course... pure platinum is too heavy!!
Have a Nice Day,
TD
TylerDurden
Postby Philistine » Wed Apr 11, 2012 1:55 am
Did P Diddy get a DUI?
Philistine
Postby Miles » Wed Apr 11, 2012 2:15 am
Philistine wrote:Did P Diddy get a DUI?
No. He's upgrading the motors on his Segway.....
Miles
Postby fechter » Wed Apr 11, 2012 8:10 am
I stand corrected :oops:
We'll just have to wait until we can get graphene sheets.
fechter
Postby Arlo1 » Wed Apr 11, 2012 8:21 am
I have a feeling it will be sprayed on or polished on. I have graphite sheets for conducting heat and power out of my fets... All you need to do is coat something with a smothe thin layer of it then coat it with somehting to stop it from rubbing off.
Arlo1
Previous
Return to Motor Technology
