Have a shed load of Power Poles on their way, and we be collecting 8-5s1p Lipos over the next couple of days, I am privvied to be able to cherry pick from a warehouse full of lipos to ensure no DOA's or low cells..
All the best.
Tony
Tench wrote:Hi Tony, its nice to see another uk e-bike builder on the scene. Thats a decent looking frame for the job, the swing arm looks good and strong.
I would be interested to know where you source your lipo, i wasnt aware we had a warehouse full of stock in this country, what make lipo is it?
Cheers Simon.
smudger1956 wrote:Tench wrote:Hi Tony, its nice to see another uk e-bike builder on the scene. Thats a decent looking frame for the job, the swing arm looks good and strong.
Cheers Simon.
Hi Simon, I get my Lipo's from http://robotbirds.com, the guy who owns it is a mate, the lipo's I will be using are 'PolyPower' (RobotBirds re-badged, same as the ones from H-King....) I will be using the 5s1p 5000mah 20C packs, I have been using the PolyPower 6S1p 5000mah 30C packs in my RC Models, I pull around 35amps 'cruising' and 105amps WOT for extreme aerobatics, can't fault them, they are performing as good as any ThunderPower pack I have owned.
All the best.
Tony
M1k3 wrote:Great looking bike and in the uk,have you decided where the batterys will go
rui_fujino wrote:great to see UK ebikers! I have still not met one yet tho....:p
By the looks of the price it might be cheaper to get batteries from HK?
what are the charging method ur thinking of?
Racer_X wrote:Looking good smudger1956, I have similar photos of my 18mo old daughter, I also believe in the front mounted child seat. My daughter loves it too! She sees me going for my helmet and she start to look for hers.
Quick question how did you manage to cut that flat channel PVC pipe at an angle and get such a clean cut?
I tried cutting some flat channel PVC pipe with a hacksaw and the result was uneven and in some instances it even cracked the PVC.
rui_fujino wrote:great build but looks like your front suspension and your battery case might be little too close?
I think If you jump off somewhere high your tire might touch the battery case...
At bloody last……………….finished……………….
kudos wrote:Smudger,
What mount method are you using to mount the APM centrally on your bars, I can't quite see from the pictures...?
Cheers,
Kudos
Users browsing this forum: Bing [Bot], Cargo_Tom, ggc, JamesDub and 10 guests
