Phoebus wrote:QMS,
How did you get those 888 lowers black?
Hey Phoebus. They are specialy supplied to Stealth Bikes in black instead of white!!!!!!!
Phoebus wrote:QMS,
Rix wrote:
Kepler how much PSI is the rear shock rated for? I had a 2010 specialized enduro with a simliar rear fox shock (Fox RP2?), I ran 265 PSI in that and it never blew on me. That shock didn't have the external reservoir though. I am sure the shock stroke ratio was different and my fighter has just a little over twice the weight as the specialized enduro. Taking your advise, I will start out at 200 PSI and tune from there. Any suggestions for starting point on the front RST One?
Maybe they can handle more then 200 psi but this is what John at Stealth told me. Not a lot of info on these shocks as they seem to marketed towards the OEM's rather then the general public. I dont know on the RST's as I havant owned a set but that shouldn't be too hard to find out
Rix
QMS wrote:Here is a few pics of my bomber side covers before i get them powder coated, i will post more pics once they are painted![]()
Rix wrote: Any suggestions for starting point on the front RST One?
Rix
Justtoby wrote:Took a ride out today that ended with a 35mph Fighter going through a fence, it really was a full speed accident. Bike held up really well but Whizzkid looks very second hand at the moment, lots of blood and then fingers pointing in the wrong direction until popped back in!
Kepler wrote:QMS wrote:Here is a few pics of my bomber side covers before i get them powder coated, i will post more pics once they are painted![]()
QMS, I like it. Nice work. Looking forward to seeing how it looks once powder coated. How does the Stealth logo look on the lefthand side of the bike? I presume the "S" will be backwards. I imagine it will look more like an "electric shock" then an "S" on that side.
I like the smoother look with the controller covered. Also I think the controller will still get plenty of cooling with the way you have it vented.
Phoebus wrote:QMS,
QuietRush wrote:Justtoby wrote:Took a ride out today that ended with a 35mph Fighter going through a fence, it really was a full speed accident. Bike held up really well but Whizzkid looks very second hand at the moment, lots of blood and then fingers pointing in the wrong direction until popped back in!
Ouch..Just how old is Whizzkid? The point is well made though that the bikes have the potential to carry you a hell of a lot faster than a MTB, along with an associated risk profile, as whizz kid has just discovered. ATGATT applies here - All The Gear, All The Time. I'd be inclining more towards dirt bike style PPE than MTB if you're going to be riding WOT, just to cope with the speeds at which you're going to find yourself falling off at. Hope there's no permanent damage, lesson learnt applies to all of us.
Rix wrote:Justtoby,
Crashing sucks. I have an artificial radial head and several titanium screws holding my left elbow together. I ride Dirt Bikes and MTN bikes. The worst injury I ever ahd was on my MTN Bike hence the elbow injury. I thinks its because I wear so much more PPE when riding my dirt bike. Get well quick.
Rix
Rix wrote:Lipo Questions. I have been told with a standard 3.7 volts that max voltage charge can never exceed 4.3 volts and never discharge below 2.7 volts. So if I multiply 4.3 V by 18 I get 77.4 Volts and if I multiply 2.7 volts by 18 I get 50.4 volts. With this information, if I build me a lipo pack using 6 Desire Power 6sp 22.2 Volts 8300 mAH wired in series of 3 by 2 for median voltage 66.6 Volts x 16600 mAH, does this mean my operating ranges would be from 77.4 volts peak charge to 50.4 maximum discharge? If this is the case for the extremes would be safe to set the CA not to drop below say 53 draw volts and my balence charger not to exceed 76 volts for safety margins? I have only used Lipos in RC cars and my ESC shuts off when the current gets to low. I use a balence smart charger that handles the peak charge. Also, If I quick charge my rc batteries at 4c and higher, they don't last nearly as long as charging at 1c. I am talking both performance and cycle life of the lipos. I have never kept track, but I would be willing to bet that I'm getting 3 times the cycle life or more out of my RC batteries charging at 1c for 60-70 minutes over quick charging at 4-5c for 10 to 15 minutes. So am I correct with the peak charge and disharge numbers? What about maximum watt discharge? If I multiply the 77.4 volts by 16600 mAH I get about 1,285 watts or 1.285 KW. Using the 10-20% dischaging rule of thumb, I should not drop below 200 watts approx 17-18% of total capicity. Or should I base the total watts on 66.6 volts for 1,105 watt or 1,105 KW and not drop below 180 watts? Or, am I totally way off?
Rix
Paul_G wrote:Kepler wrote:I am thinking a sprung shock rather then an air shock. Something like this. http://www.dnmshock.com/bicycle-wheelchair-shocks/burner-rcp.html. I will do a bit more searching. Hyena has a different shock then standard on his fighter. Not sure what it is.
Speaking of rear shocks I would like to find a lighter spring to replace the the Bomber spring as I do 95% street riding. If any one knows what is stock and where to find lighter please let me know.
Mr Lowbank wrote:Paul_G wrote:Kepler wrote:I am thinking a sprung shock rather then an air shock. Something like this. http://www.dnmshock.com/bicycle-wheelchair-shocks/burner-rcp.html. I will do a bit more searching. Hyena has a different shock then standard on his fighter. Not sure what it is.
I got the orange bomber been riding and too knackered to do much elseHaven't done a photos shoot yet, hope to get to that before I scratch it up to much. I also am wondering about the rear shock spring. The compression dampening was wound right out when I got it but still seems to hit hard in the ass end. I am wondering if a lighter spring with a bit more compression dampening might be the way to go. Also the back tire hits the shock reservoir pretty hard when landing with the razorbacks. has anybody noticed this? I put some white tape on the reservoir before gong for ride. And the tape has been marked
The chain is stretching every ride so when the wheel get back a bit it may miss? I would like to see the action with no spring.
The work stand
http://www.box.com/s/37b2cae280c3b5314513
he weight of back wheel 17kg
Rix wrote:Snowchyld,
I took this from Desire Power web site. I have never charged my RC car lipos at 10c, but Desire Power says its possible depending on time constraints. I never had any thermal breakdown on my lipos charging at 4+C. I have stopped a charging cycle before because they were really warm to the touch. Looks like I am off on the useful voltage range though. However, I got that info from another forum on this site: they quoted "lipo rules, never above 4.3 and never below 2.7". Apparently that info is incorrect which is why I asked here. As you pointed out, there are a many other forums to go to for my inquiry, however the information can be wrong there. Kepler and Hyena have both done lipoly conversions with great success which is why I posted my querry here. I believe this forum will point me in the right direction with sound advice. I can do the math and come up with a more accurate voltage range as long as the info provided is correct. BTW, Watts can be measured in current draw output and also in capacity of a storage devise. Stealth Bikes lists the capacity of their batteries in watts on their website. Bomber's battery capacity is 1.5 KW (probably 72+ volts 20 Ah) and the fighters battery capacity is 1.1 KW (probably 55 peak volts at 20 Ah) not to be confused with the bomber's output up to 4.5 KW (probably 60-65 Ah @ 72+ volts) and the fighter up to 3 KW (probably 50 Ah @ 55 volts). I think your max discharge rate example for a 10 Ah battery being discharged at 8Ah max tells me that you are referring to a battery rated for 1c continues discharge. The lipos I am looking at rate anywhere from 35c continues up 65c with short burst that doubles these numbers. Having said all of this, I am not very knowlegible about Lipos, I use them in my RC car and my RC Helicopter with out any problems. They are 11.1 volts and 7.4 volts respectively. For me it is litteraly plug and play and my smart chargers balence and charge the batteries. Anyways thankyou for taking the time to answer my questions and for providing the information about voltage ranges for lipo cells.
Kepler wrote:Now that your pictures are coming up, I can see you have the shock spring fully wound off. I run my spring at full tension. Ride is still quite plush.
sn0wchyld wrote:just to be clear, im not suggesting you should shy away from a lipo conversion, meerly pointing out that the simplicity of a stock stealth is quite desireable, and is what I'd choose initially if I could afford one!
Rix wrote: "lipo rules, never above 4.3 and never below 2.7". Apparently that info is incorrect which is why I asked here.
Users browsing this forum: steeeve and 4 guests
