MattyCiii wrote:Yes the chainrings are 130mm BCD
ATS says the chainring is 110mm, have you got a 130mm installed in yours?
http://ats-speeddrive.com/tpl/all_sd_item.html
Quajochem wrote:But the chainring and chainguard are both standard 5 hole items, so there's no need to order them from ATS
melodious wrote:This may be of interest for a chainguard. I saw it at my local bike store on folding bikes (Dahon). Its a plastic coil conduit with a split in the middle. Looks cool in person.
http://www.chainrunner.de/index_en.html
Went and surfed around for it and it may lack any real durability factor. Who knows. But it definitely adheres to the "simple looks" of this thread.
gensem wrote:MattyCiii wrote:Yes the chainrings are 130mm BCD
gensem wrote:Where can I find chain ring and cranks?
ATS itself does no reply to emails.
Quajochem wrote:I have a Nuvinci rear hub, and I am also worried about the chainline, if it isn't straight enough I'll need some spacers!
Accountant wrote:Those crank arms also look very standard to me!
WRONG.
I was looking for apropriate crankarms for a few months.
Did not found them, and at the end bought from Schlumpf directly.
Very hard too find crancks that will work well with shifting buttons.
MattyCiii wrote:Quajochem wrote:I have a Nuvinci rear hub, and I am also worried about the chainline, if it isn't straight enough I'll need some spacers!
My setups are the same... I'm retrofitting one bike that already has a NuVinci with an ATS drive, and building a second bike up from the frame to use both the ATS and NuVinci. I have 2mm and 4mm spacers on the way just to give me options. I'll post pix when I get the parts in.
Users browsing this forum: Bing [Bot] and 12 guests
