DALBYNATOR wrote:Kepler wrote:...it's worth noting that the importer here in Aust has spare gears in stock but is yet to sell a set.![]()
Hi Kepler, I'm down here in Adelaide and just wondering who your supplier for the BPM motors are? And whether I could get one shipped down here?
Cheers, Tom.
Kepler wrote:This because I am keeping them all for myself![]()
Send a PM to Ben Moore http://www.endless-sphere.com/forums/memberlist.php?mode=viewprofile&u=12004 He should be able to help you out.
Cowardlyduck wrote:I live on the first floor of an apartment and have a small flight of stairs to carry mine up.
Hyena wrote:Get a run up and nail it - you're not trying hard enough![]()
Stairs can be a bit of a challenge but I usually manage to power up them OK. Try lifting the front so it's in the air and power the bike up the stairs with it vertical. Just don't lose your balance or it'll end in tears!
Hyena wrote:Failing that lifting by the seat post rather than the seat frame is probably better
Cowardlyduck wrote:Hyena wrote:Get a run up and nail it - you're not trying hard enough![]()
I would, but I'd have to either get the run up in about 1 meter, or do the run up over 2 large steps then a door barely wide enough for the handle bars before I hit the flight of stairs. Trust me it's not really doable unless you want to break something.
Might try the front up trick. I also have to consider the noise made since I have neighbours.
Bit awkward to hold, since I've got a light, hydration pack and mud guard all hanging off there, but I'll try that one too.
Cheers
voicecoils wrote:Can you build a ramp?
full-throttle wrote:Wow, that bottom bracket is so high up
Justtoby wrote:I notice you have gone for triple crown forks when this is mainly a road bike, I prefer the look but surely normal forks would have given more turning circle for town riding plus even less weight?
Kurt wrote:Looking good and at 2000w there is room for another 1000w burst power without any issues.
Just over 60kmh is good. I bet it rides like a regular bike. I found the freewheel loosens up the more you use it. The combo would be great for bursts of power then coasting. and the low gear and light weigh would make it good on a technical section . Keen to see the consumption data I think you will be happy with it.
Video would be great![]()
Nice build.
Users browsing this forum: chroot, deffx, Kepler, mushymelon, TreksterJim, wineboyrider, zombiess and 8 guests
