shock wrote:Balance is very important on 2 wheels, and critical on one wheel! Newbs tend to forget about the rear brakes in a unwanted wheelie situation. Seen it a hundred times.
oatnet wrote:One could reduce torque by going to a larger diameter wheel - like the 26"/700c accountant envisioned for the 9kv wind - but then one can't buy tires rated for the speeds it could achieve.
MadRhino wrote:oatnet wrote:One could reduce torque by going to a larger diameter wheel - like the 26"/700c accountant envisioned for the 9kv wind - but then one can't buy tires rated for the speeds it could achieve.
It does wheelie easily in a 26" wheel, all my motors and even the lightweight H motor can lift the front at 20 Mph on all my bikes.
Good 26" tires to speed 70 Mph are available if you don't mind DH racing knobs.
Only limiting power, or altering geometry, can keep the front wheel down.
gensem wrote:Oatnet i ll not deny that having less torque would help. It sure would, but having better throttle modulation is what changes the game. And you ll probably be able to have a progressive (adaptive) throttle with CA v3 soon.
Still the 3 turn hub motor sounds like the best option for the enthusiasts in ES.
Once again I vote for a cromotor that's about the same size of a magic pie having magnets as thick as is this one, with three turns of cooper in an aluminium stator weighting 13kg total.
Game?
John in CR wrote:gensem wrote:Oatnet i ll not deny that having less torque would help. It sure would, but having better throttle modulation is what changes the game. And you ll probably be able to have a progressive (adaptive) throttle with CA v3 soon.
Game?
3 turns is too much. Hubmonster, my motor with a 50mm wide 265mm diameter stator is 1.5 turns, and it has a Kv of about 15. My 40mm X 200mm motors are 2 turn and have a Kv of 16. Wider stator with same turns reduces Kv.
gensem wrote:Once again I vote for a cromotor that's about the same size of a magic pie having magnets as thick as is this one, with three turns of cooper in an aluminium stator weighting 13kg total.
Game?
fabiograssi wrote:Gensen, any improvements on throttle response?
gensem wrote:Dual front brakes arrived, they look good (not as good as gators) and are very light. I hoping to get the frame soon so I can test it.
Im having a hard time taking picture now because my cell phone broke.
oatnet wrote:gensem wrote:Dual front brakes arrived, they look good (not as good as gators) and are very light. I hoping to get the frame soon so I can test it.
Great, I was thinking about these for a while, and I am really looking forward to your feedback on how they work out for you.
-JD
Rodney64 wrote:Gensem, Still happy with with your fast track frame. Thinking of buying one for my Son
shorza wrote:Gensem, do you mind showing me how you made your Pelican case removable?
Users browsing this forum: Bing [Bot], chroot, dnmun, jeohearn, ken1645 and 18 guests
