A123 AMP20M1HD-A Battery pack kit
Re: A123 AMP20M1HD-A Battery pack kit
Postby agniusm » Wed Apr 25, 2012 11:26 am
docnjoj wrote:They look great but I have a question. What kind of connectors are they and are they compatable with the regular JST-XH types that are used for balance charging?
otherDoc
Female connector and corresponding number of pins are included in the kit. Most BMS comes with JST on one end and bare wires on the other. This is why i did it this way. All included :)
They are 3.96mm NSK, NSG connectors. JST are smaller, harder to work with for novice users and not locking. These are larger, clips in securely easy peasy job :)
agniusm
Postby agniusm » Wed Apr 25, 2012 11:36 am
TheWizard wrote:
agniusm wrote:Got some nice stuff to build my test rig for lots of current. 6 x 1000W light bulbs at 24V. Hock them up in parallel and we have 6kW.
...so if my math is right i should be pulling 275amps. Will see the tops
East German bulbs?! You definitely need to give that rig a good James Bond-style bad-guy superweapon name.
Will do ;)
agniusm
Postby docnjoj » Wed Apr 25, 2012 2:42 pm
otherDoc
That is way cool! Thanks again agniusm. It is clear that you really thought this through in every detail. Great.
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby Spacey » Wed Apr 25, 2012 2:55 pm
What sort of Amps do you think could be pulled through the kits....300Amps?
Spacey
Postby agniusm » Wed Apr 25, 2012 3:05 pm
Hi, thanks for the question. This is in series kit for bicycles and i doubt that someone will be pulling 300amps on a bike. I am developing parallel kit as well by request here and my calculation are that it will be able to hold 374 amps. The kit is highly scalable, lots of configurations possible. When finished, it will be available in any series or parallel configuration but will aim to most popular ones. The kit is not cheap i know, but it is hassle free and easy maintainable diffidently from A123 packs with laser welds etc.
I will be offering different terminals for higher current i think to go up to 1000A to use with sort of zilla or netgain controllers and warps..
Cheers
agniusm
Postby cassschr1 » Wed Apr 25, 2012 5:55 pm
how long do the tabs need to be to work with these boards? Will 5/8 inch work?
cassschr1
Postby The Mighty Volt » Wed Apr 25, 2012 7:27 pm
Sorry, I may have missed this, but how much are these units, say, for 24s? Thanks.
The Mighty Volt
Postby agniusm » Thu Apr 26, 2012 12:49 am
the tabs has to be roughly 8mm long from teflon insulation even 7mm should do.
Estimated price for 24S kit is 136.85USD +shipping and 1$packaging.
Cheers
You can check shipping cost here: http://www.post.lt There is english version button top right corner.
Check the conversion rates here: https://ib.swedbank.lt/private/d2d/payments/rates/currency
agniusm
Postby gensem » Thu Apr 26, 2012 7:56 am
Agniusm could you make 7s modules?
I know it sounds like an odd number but im thinking about using 28s A123 wich would end up being 100.8v (same as 24s lipo)
I would also like to know the dimension of a mounted 7s battery kit.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
gensem
Postby The Mighty Volt » Thu Apr 26, 2012 9:35 am
agniusm wrote:the tabs has to be roughly 8mm long from teflon insulation even 7mm should do.
Cheers
Thank you agniusm , you are very fair. :D
The Mighty Volt
Postby agniusm » Thu Apr 26, 2012 10:27 am
gensem wrote:Agniusm could you make 7s modules?
Well 28S you can get combining 24S kit with 4S kit. At the moment i am stuck with block fabricators. No one seems to want to make them. A full headache..
agniusm
Postby deVries » Thu Apr 26, 2012 10:39 am
agniusm wrote:I was looking to calculate exactly but it is too complicated. I guess if 20x6.3mm (126mm^2) copper bar is good for 320amps, if i would use 6mm round bar, meaning A=pi r^2=28.26mm^2, i would think that it would be good for 40amps brass or 70amps copper. I might be wrong but then again i am looking more at the clamping of the cells in to the pack and Builder should decide which way to terminate the pack. It is just not viable to design something to individual needs. I need to check current draw in my setup, and i use 14AWG on terminals, BMS and controller are rated at 30A.
These are continuous loads (see above).
What about peak amps & for about how many seconds? :?: Just for estimate purposes. :D
deVries
Postby gensem » Thu Apr 26, 2012 10:47 am
I see... but I would still like the 7s blocks, so I charge using a regular rc charger and use either 21s or 28s depending on my hub motor kv and controller mosfets.
gensem
Postby agniusm » Thu Apr 26, 2012 12:37 pm
I have made my test rig that goes in 45 increments up to 270amps, when i get rest of the stuff made i field test it with temps and timing. I see little point in theoretical estimate as in true life it could be far different.
agniusm
Postby agniusm » Thu Apr 26, 2012 2:21 pm
Here is the 6kW tester for end terminals i knocked up today. Possible testing at 45A; 90A; 135A; 180A; 225A; 270A:
agniusm
Postby ambroseliao » Thu Apr 26, 2012 2:36 pm
Be sure to have your welder's mask on! Or at a minimum, some serious sunglasses! :shock: :lol:
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby Doctorbass » Thu Apr 26, 2012 3:29 pm
What purpose are these bulbs made for ?.. 1000W at 24V seem requiring really high current and i can't find wich purpose are for 1000W at 24V.. and 45A !!
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby CamLight » Thu Apr 26, 2012 4:35 pm
agniusm wrote:Here is the 6kW tester for end terminals i knocked up today. Possible testing at 45A; 90A; 135A; 180A; 225A; 270A:
Awesome. :D
I'm worried about the base plate, and whatever surface the rig is placed on, overheating but testing will show if that's a problem pretty quickly. Have you tested what the initial current surge is for these bulbs? It's typically 5 to 10 times the rated current but I was curious since I've never seen these bulbs before.
John M.
Owner
CamLight Systems
CamLight
Postby deVries » Thu Apr 26, 2012 7:01 pm
Thank you! 8) for taking the time to do this. Looking for the James Bond naming when you fire it up. :twisted: :lol:
deVries
Postby agniusm » Fri Apr 27, 2012 12:17 am
Doctorbass wrote:What purpose are these bulbs made for ?.. 1000W at 24V seem requiring really high current and i can't find wich purpose are for 1000W at 24V.. and 45A !!
Doc
As i will be selling my kit, i have to include information on how much current end terminals will hold. This is the main purpose of the rig. It will draw nearly rated constant current of A123 cells.
EDIT: Miss read the first pars. These were old bulbs for stage lights.
CamLight wrote:Awesome.
I made it from 2mm aluminium sheet so hopefully it will dissipate some heat. I will start at 45amps and probably wont go higher than 130% on calculated theoretical end terminal throughput.
agniusm
Postby 999zip999 » Fri Apr 27, 2012 8:58 pm
Sorry Docjoj, I couldn't log in for day's. But I didn't know the real cut-off of the headway bms at bmsbattery. But I wouldn't know. I think Dumm said 3.9v or 3.85v for the headway ? Looking for my 48v 10 fet singalab. from Ping ? Still looking ? I think I will go with 2-36v packs if they fit ? As I would like to get something in hand before I make final choice. Still waiting on John
999zip999
Postby agniusm » Sat Apr 28, 2012 4:38 am
Hi. There is a delay with kit as no one seems to be capable to manufacture blocks at reasonable price. This is due the fact that there is a lot of perimeter routing and working with brass is difficult. I cannot use aluminium or copper as they are too soft for the threads and you need that bit of extra nip to get the tabs clamped properly. Whats left is plasma cutting but few firms i rang do not deal with small quantities like mine. Will be looking further in solution to get this issue solved but in the mean time i must apologize for delays and high hopes and just to suggest looking for another solution as i cannot meet my deadlines. I will be posting news her if something real comes up.
agniusm
Postby docnjoj » Sat Apr 28, 2012 7:34 am
Hey agniusm
Is the only problem area the brass blocks? If so do you already have the brass in hand? Thanks for your effort and please let me know if I can help. Would you consider selling the kits and materials for the blocks without machine work on the blocks?
otherDoc
docnjoj
10 GW
10 GW
Postby agniusm » Sat Apr 28, 2012 8:10 am
Hi. I was just of the phone taking about manufacturing blocks. The man from the firm was kind and was trying to help with solution. They cant rout the perimeter and he contacted third parties for water jet cut them in to the block. He will get a quote on Wednesday. I have asked him to rout the holes and i will do the tapping manually on this one. Will see how this turns out. Will have to think about the whole thing from different prospective as it is not viable financially to produce this way. I have bought the sheets of material and there is no easy way to cut them within 1mm tolerance. I will try my best to get this done ASAP. All parts are sorted into the kits, connectors soldered, shipping boxes and bags bought, only blocks are missing and i don't want to ship incomplete kits as this will put me in "half job done" supplier position.
I was just informing people who considered purchasing the kit from me that there is a problem and i cannot guarantee speedy completion.
Thanks docnjoj for the offer but i cannot except help, this is my problem to solve;)
Anyway, it does not stop here, there are few designs started for lager applications with kits, some excitement as me and my brother are getting VW Scirocco MKII for conversion next week.
Other thing is even thou people are exited about modules from A123, there might be a slight problem, first on getting them from Chinese vendor and after if something goes wrong with cells inside swapping them with new ones and there will be my kit which will make life easier and still be ok to use with cells from module.
Good day to everyone
agniusm
Postby docnjoj » Sat Apr 28, 2012 9:23 am
Thanks for hanging in there agniusm. Let us know if we can help.
otherDoc
docnjoj
10 GW
10 GW
PreviousNext
Return to Battery Technology
Users browsing this forum: Bing [Bot], docnjoj, DrkAngel, wesnewell and 12 guests
