Hyperion EOS 1420i NET3 14s Balance Charger...
Re: Hyperion EOS 1420i NET3 14s Balance Charger...
Postby mistercrash » Mon Apr 23, 2012 9:37 am
I have a 14S battery and I put two 7S balance tabs on it so the 1420i recognizes the battery as being two 7S packs plugged in series and it balance charges the 14 cells with no problems.
Is it ready yet?
mistercrash
Postby visuthdy » Fri Apr 27, 2012 4:38 pm
For those that purchased Hyperion with 1420i ttpack lvc board kit. Does any know if I can cut this board in half? I would like to cut it so I can put the batteries in the hammond case. I'm planning to do 12S2P. thanks.
visuthdy
Postby cwah » Sat Apr 28, 2012 8:17 pm
I'm using the hyperion for the first time and set the charge to 75% full charge. I connected to the log view and I have this:
It seems that the more it charge, the less balanced is my pack??? And how come at 19.7V I'm only at 45% battery charge level?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby psycholist » Sat Apr 28, 2012 9:21 pm
Need more info. What size packs are you charging? Lipo? Are these new packs?
psycholist
Postby cwah » Sat Apr 28, 2012 9:33 pm
Yeah, I'm charging 5s8AH zippy lipo. New pack (although almost 5 month old) because I only have few cycles on it.
cwah
Postby psycholist » Sat Apr 28, 2012 10:56 pm
First off, I don't know how high the cell voltage will terminate at TCS 75%. What I do know though, is that at 40% TCS, the cell voltages terminate at ~3.85-3.86v.
So at TCS 75% your probably looking at a significantly higher termination voltage.
Disregard the % capacity values computed by the wacky hyperion algorythm. It is not accurate. You have to experiment to find your desired termination point. Your cell gap looks to be around .1v with possibly a few runt cells and this is why the cell gap gets greater as the charge progresses. It will continue to do so until the balance mode kicks in. What I would do at this point is run the charger in the passive balance mode (not charging) and once balanced, cycle the pack a few times (while closely monitoring), to determine if you do indeed have some runts (lower capacity cells).
psycholist
Postby neptronix » Sat Apr 28, 2012 11:34 pm
Some packs charge like that. Either it is imbalanced, or you are looking at a dud pack, one with cells that are not evenly matched at manufacture.
You are not balancing at that point, the pack is doing that naturally.
One out of 10 turnigy packs i ordered does this. The purple cell you see charges way too fast. It will not work for a bulk charge, since if i set all the other cells to charge to 4.18v average, this one hits 4.21v. It also dies sooner.
Another zippy pack ( out of a total of 17 purchased ) does this. One cell is low on capacity.
About 12% of the packs i have received have had a cell that would cause problems during bulk charging, or would have unevenly worn other cells hooked up in parallel over a long period of time.
This is another reason why i strongly recommend cycling your packs as soon as you get them, to weed out the duds from the studs :lol:
neptronix
Postby psycholist » Sat Apr 28, 2012 11:52 pm
Neptronix, Do you find that these dud cells diminish in capacity faster (compared to a healthy cell) over time?
psycholist
Postby neptronix » Sun Apr 29, 2012 12:04 am
I do not use them, so i do not have personal experience.
However, think of it this way. Even if you are taking care to keep a dud pack balanced, and cut off early, you are putting more cycles on that cell than the others. If you are repeatedly taking it down to 10-20% capacity but all the other cells are only down to 30-40% capacity, the dud cell is working far harder in relation to how many amp hours it can provide.
This is fine if you are OK with cutting off your pack early and losing amp hours because the weakest cell dictates how much capacity you can use.
If you are not, like me, then forget those. Then you have to be paranoid about keeping your pack in balance etc.
neptronix
Postby cwah » Sun Apr 29, 2012 12:31 am
Thanks for the answer guys,
How do I set rhe passive balance mode? I only have the solo charge, discharge, storage and cycle mode. Is it hidden somewhere?
And is the standard cycle mode (for NI-MH) that should be used to spot bad cells? And if bad cell is spotted, can you ask hobbyking for an exchange? Lol
cwah
Postby psycholist » Sun Apr 29, 2012 12:44 am
I see your logic neptronix. Thanx
psycholist
Postby psycholist » Sun Apr 29, 2012 1:16 am
cwah, Sorry, It isn't literally called "passive mode". Press the mode button until you reach "Balancer Mode"
Just charge/discharge in lipo mode and monitor closely. Doing so will reveal any bad cells.
From what I've read, it isn't worth the hassle, or the return shipping cost, to exchange lipo from HK.
psycholist
Postby neptronix » Sun Apr 29, 2012 1:43 am
BTW i just got my hyperion 1420i in the mail today. no server power supplies yet, so i haven't charged..
I noticed that the TVC ( total voltage per cell ) can be dialed down to 4.15v, woohoo! Must be new firmware, because i remember hearing that this unit only went down to 4.18v, which sucks if you are bulk charging.
If you dive deep into the menu, there is a display of the serial number. Mine is blank / just a bunch of black squares. Is this normal?
neptronix
Postby psycholist » Sun Apr 29, 2012 2:53 am
neptronix, I remember reading about issues when using TVC but can't remember what they are off-hand, so I simply avoid it and use TCS instead. TCS 95% will get you ~4.13v - 4.14v. I believe you can set in 1% increments via software only. Otherwise 5% increments via the charger. Also don't use the store mode if you expect to store near 3.85v. I use 40% TCS.
Sorry, Can't help you with the serial# as my wife is asleep and the hyperion is under my pillow. :mrgreen:
psycholist
Postby whereswally606 » Sun Apr 29, 2012 11:16 am
Neptronix, I checked the menu for a serial on mine, got the same things as you, empty boxes, anyway either we both got grey market ones or its normal. Im betting its normal
Buy a 400W 12Volt 32a server supply fitted to connect typical 4mm bullet plugs £25.30 to the UK, will ship WW. IM me for details
Ebikes: Scott Ransom & Magie Pie 48V limno2,Norco Team Race & Hub motor 12s4p lico zippy 40C
Norco Savage to receive an 80/100 motor with opticals Not halls Thanks Burtie.
Car: Honda Insight gen 1 hybrid
whereswally606
Postby Sacman » Tue May 01, 2012 2:50 am
visuthdy wrote:For those that purchased Hyperion with 1420i ttpack lvc board kit. Does any know if I can cut this board in half? I would like to cut it so I can put the batteries in the hammond case. I'm planning to do 12S2P. thanks.
Yes you can cut the boards in half. That's how I did mine. But notice when you do you'll be cutting the traces (on the back side of the board) for the black and red wires. So just add jumper wires between the two halves of the board at those locations to keep continuity and you'll be fine.
Sacman
Postby hillzofvalp » Wed May 02, 2012 10:56 pm
WEird thing happened today. I have been charging 10S on one of my hyperions with no problems for a long time. Today I connected a 4S pack, started charge, then it says "output voltage too high" (roughly). The weird thing is that the main charge leads got hot enough to melt the insulation (18-20AWG) within that short timeframe from hitting start and it alarming out (1-2 seconds). I'm going to try the 10S pack again with caution. it appears that at that high of a current the battery must have been dumping energy into the charger.
why am I just learning of logview?!?
hillzofvalp
Postby wojtek » Sat May 05, 2012 9:49 am
i am trying to charge 3s battery pack, also getting "output voltage too high"
the battery is 11.1v lipo 5000ah, settings in charger for 3s 5000ah so all fine. not sure why is this doing to me? i tried other 3s batteries with same result :(
EDIT: I tried to balance charge the battery [they are now around 3.95v per cell], plugged to the laptop to get more info..
the voltage of cells started to show 4.3v and more and the charger died soon after!
I opened it. Is it a 40a fuse went, it doesnt seem to be easily removable. is it soldered to the board? strange
thanks
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby wojtek » Sat May 05, 2012 10:38 am
to change the fuse i need to "unsolder" the legs from the bottom of the board right? cheers
wojtek
Postby wojtek » Sat May 05, 2012 11:59 am
ok i replaced the fuse and it is back alive but still getting this ridiculous error message- why output voltage too high ?
anyone similar issue?
wojtek
Postby hillzofvalp » Sat May 05, 2012 7:41 pm
someone right before you posted a similar issue... :wink:
hillzofvalp
Postby EBJ » Mon May 07, 2012 7:00 pm
ok, I know somewhere in this mile-long post is my answer...
but I just spent 30 min looking to no avail.
Question:
When wiring up the balance-wires coming from the Hyperion to go to a DB-25 Connector,
I first just wired my balance wires as if I were plugging in my 2 5S batteries to the hyperion balance port plugs. (one battery to ports 1-6 of 16, then the other battery to ports 9-14 of 16)
It worked well, but I realized after I wired it that way, that when I cycle through the "ports", the Hyperion shows a "blank" voltage for ports 6 and 7...
(because I had skipped over those two and jumped into port 8 to continue w/ wiring the other 5S)
So I have a few questions:
1. What is the best way to wire in 10S to the Hyperion ? (as far as port-use)
2. If I wanted the Hyperion to register 1-10 ports for my 10S pack, then how would I wire in the second 5S balance wires to the Hyperion ?
-examples: first 5s balance wiring is pretty clear... wire "ground", 1, 2, 3, 4, 5.... but then the second 5S pack is a little confusing to me since "ground" voltage is actually the same as (port 6 ... or cell "5" voltage)... in which case, do I wire "ground" w/ the second pack to port 6 w/ "cell 5" ? or do I skip it all together and start wiring "6" to port 7 ? Then what do I do with "port 9" when the Hyperion is wanting "ground" of the high-pack to go there ? arg!.
I'm sorry if no one can follow the above. I find it challenging to explain.
EBJ
Postby FastDemise » Mon May 07, 2012 8:02 pm
EBJ wrote:ok, I know somewhere in this mile-long post is my answer...
Question:
Just use 1-6 then 9-14 and it's work out. I've tried just using all 1-11 to try 10s but it freaks out and beeps alot. The charger is happy to charge any number of cells as long as it's in pairs or up to 7s single. Not sure how cells with a odd number of cells aka 13s can be charged and if you can charge it up using the 7s balance connector then the 6s balance would be my guess.
21" Hardtail, Docs Torque Arm, Lipo 20s2p, ebikes.ca 9C 8x8 and Lyen 6fet (both Mineral Oil cooled)
FastDemise
Postby kfong » Tue May 08, 2012 11:00 am
Here is a picture of how I do it. viewtopic.php?f=31&t=39291
The last picture shows how it's done. You need to use their battery balance port connectors since it's not a one to one pattern unless you want to rewire.
Question:
kfong
Postby docnjoj » Tue May 08, 2012 11:51 am
OK so here is a dummy question. I will have 2 6S lifepo4's A123 in series to make 12 S How should I wire the balance leads so the Hyperion will recognise all of the cells. I would buy Kin's system if I needed it, but how do you plug the 2 6S connectors into Hyperion. Cells 1-6 starting with ground in Port A and cells 7-12/ground in Port B? I'm confused!
otherDoc
Edit: Yes the pack will be a split one with 6S cells on each side of the trike. Much better balance for handling just like my old Ping is doing now.
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
PreviousNext
Return to Battery Technology
Users browsing this forum: Google [Bot], steveo, whereswally606 and 9 guests
