The White Warrior - 40mph+ tadpole trike FINISHED!
Re: The White Warrior - tadpole trike [pics]
Postby Xanda2260 » Wed Mar 21, 2012 5:25 am
Ok, battery box is a fail. Comes far too close to the ground, and is too flimsy. Sooo, new build! Found a massive sheet of aluminium diamond plate in my gradads garden, so I'm using that. Had a redesign too to get it further away from the floor. Pics will follow, once I've taken some.
The ali is 6mm thick and damn, is it ever HARD ( thats what she said...).
I always thought ali was a nice soft metal, but I've gone through 4 cutting disks so far (versus 2 disks doing all the steel on the entire trike). Welding the ali has been problematic too. Tried Durafix rods but couldn't get the base metal to 390C, it just acted like a massive heatsink. So I cheated - two part epoxy putty for the win!
Also, progress has been slow cos Ive been caning around on it so much! Was pacing a 4x4 the other day at 40mph (wide cycle path at side of 40mph limit road). When he spotted me, I smiled, waved, and started pedalling. His face was a picture!
The White Warrior - viewtopic.php?f=6&t=33918
Homebuilt 40mph+ tadpole!
Xanda2260
Postby Xanda2260 » Fri Mar 23, 2012 3:55 pm
New battery box!
And installed ( bolts will be other way up ultimately).
Much better, still fouls the chain though. Now I gotta make up an idler...
Xanda2260
Postby Xanda2260 » Tue Mar 27, 2012 10:30 am
Epic Fail! Ok boys and girls, it seems that I am a complete idiot!
When I made the alu batt box, i used a 2 part putty to stick the edges together. This stuff sets like steel.
I stood on the box and it held beautifully, so I'm like 'that'll do fine. WRONG!
Of course, that was under compresssion, with my mounting, the box was under tension.
So, I'm out crusing last night, trying out the new battery position. Handles great. Join a nice long cycle track near my house, blast past an old guy on an invalid carriage, and open her up. 41mph GPS verified. Slowing down, thinking I should check my voltages (speedict still not showing speed - grr), then all of a sudden my battery box disintergrates :evil:
I look back to see my precious lipo strewn out on the floor behind me.
Had to do the walk of shame 2 miles home :-(
Soo, new design
Fugly as hell, but hopefully it wont come apart!
Xanda2260
Postby Xanda2260 » Wed Mar 28, 2012 11:08 am
After discussions with several people who know more about this stuff than me (cheers Dogman and AW), I have found that this box is destined for a rather messy end. Sooooo... On to attempt 4!
Xanda2260
Postby TopCat » Thu Mar 29, 2012 1:42 pm
Looking at your first batt box and your most recent, I see that you have a metal band around the wooden batt box. Couldn't you go back to your alumininum batt box and secure it a bit better with a couple of metal bands bolted around it to stop it disintegrating?
Regards
Tom
TopCat's Spoiler
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=19663
I started off with nothing and I still have most of it left.
TopCat
Postby Xanda2260 » Fri Mar 30, 2012 9:24 am
Could potentialy work, but this top mounted system is destined for failure...
So, I have just completed a test ride using this beauty.
Took it to the park cos the path is properly bumpy. Even at 10mph I was bouncing all over the place. At 20 the box was still perfectly secure, even though I wasn't!
Xanda2260
Postby Xanda2260 » Mon May 07, 2012 1:46 pm
Ok guys, sitrep.
Trike now has cargo capability, is hitting 5kw (60A battery, 150 phase, peaks of 70A plus), and flies!
Heres a pic of bro-in-law on it, and a vid of a 30mph driveby.
http://i75.photobucket.com/albums/i293/ ... EO0029.mp4
Xanda2260
Re: The White Warrior - 40mph+ tadpole trike (pics and vids!
Postby Xanda2260 » Mon Jul 09, 2012 4:08 pm
After several million years of rain, the weather finally got good enough for some paint!
All primered up. Painting the little bits while the primer hardens, then we'll get to the painting proper.
Xanda2260
Postby millzy555 » Tue Jul 10, 2012 3:45 am
Great build! What wind 9c are you using? Thanks
millzy555
Postby Xanda2260 » Tue Jul 10, 2012 5:45 am
millzy555 wrote:Great build! What wind 9c are you using? Thanks
Good question. I think it's a 2807, but not certain. It'll do 43mph in a 26" wheel at 73v and controller set for 120% if that helps ;-)
Xanda2260
Postby waynebergman » Tue Jul 10, 2012 9:27 am
Nice bike Xanda. I have purchased the plans from AZ for the Warrior myself and look forward to the project. Should be a winter project after I research a few things for it. I like your seat, did you make that or where did you get it and how much did it cost and weigh. I have some fiber glass experience but I do not like working with the stuff very much so if there was a store bought solution for a nice seat I would most likely go that route.
Wayne
Link to first build Giant DH-------- viewtopic.php?f=3&t=33849
Mid Drive work in progress--------- viewtopic.php?f=28&t=49467
waynebergman
Postby Xanda2260 » Tue Jul 10, 2012 9:41 am
waynebergman wrote:Nice bike Xanda. I have purchased the plans from AZ for the Warrior myself and look forward to the project. Should be a winter project after I research a few things for it. I like your seat, did you make that or where did you get it and how much did it cost and weigh. I have some fiber glass experience but I do not like working with the stuff very much so if there was a store bought solution for a nice seat I would most likely go that route.
Wayne
Hey Wayne, glad you like ;-)
I bought the seat from a company called Ocean Cycles based in Cornwall, UK. They are also on ebay (just search 'recumbent seat').
If you fancy a look at the build log, it's on the AZ forum for the Warrior.
If you haven't already, check out Spinners Warrior - absolutely top notch work!
Xanda2260
Postby Tpower » Tue Jul 10, 2012 3:32 pm
Very good job Xanda,please post pics whan painting job it's ok.
43mph it's good speed,and 5kw with 9c it's great result.
Tpower
Postby Xanda2260 » Wed Jul 11, 2012 4:44 am
Tpower wrote:Very good job Xanda,please post pics whan painting job it's ok.
Oh I will :wink:
I've dialled the power down a bit now. 5Kw was not noticibly quicker than 4KW, and the motor heated up much quicker. So I'm back at 50A battery, 125A phase. Peaks hit about 4KW (59A battery spike).
Oh yeah, and 43mph is a SCARY speed on UK cycle tracks! Those things are bumpy! Nice on the road though...
Xanda2260
Postby Xanda2260 » Thu Jul 12, 2012 1:25 pm
Frame painted!
Just need some retroreflective clear coat, and she'll be ready for reassembly! Yay!
Xanda2260
Postby Xanda2260 » Sun Jul 15, 2012 1:33 pm
Construction in progress
Sent using the might of the Android Army!
Xanda2260
Postby Xanda2260 » Sun Jul 15, 2012 1:34 pm
More construction pics...
Xanda2260
Postby jateureka » Sun Jul 15, 2012 7:33 pm
Nice work xanda.
Bafang; Mac; Ezee; Easy2Ride; PowerPed; Nope; Condor; Aprilia; eLation V2; Razor
jateureka
Postby Xanda2260 » Tue Jul 17, 2012 2:35 pm
Bang! And the trike is done!
Ladies and gentlemen, may I present...The White Warrior!
Even got regen working! Hell yeah!
Xanda2260
Postby Lessss » Tue Jul 17, 2012 2:52 pm
I always thought they should have a swing arm high enough for trucks to see that could normally be in line behind the back tire but could be swung out to the left to give trucks and cars a better visual of where you and your front tire is. Not to mention it could be used as a swatter to hit dumb fucks driving too close.
Give me nuclear batteries I say!! Ripped off by Joshua Goldberg to the tune of almost $900 re headway groupbuy for batteries, no $ no batteries
http://www.openoffice.org/ or https://www.libreoffice.org/
http://www.ubuntu.com/
Lessss
Postby Xanda2260 » Tue Jul 17, 2012 3:15 pm
Lessss wrote:I always thought they should have a swing arm high enough for trucks to see that could normally be in line behind the back tire but could be swung out to the left to give trucks and cars a better visual of where you and your front tire is. Not to mention it could be used as a swatter to hit dumb fucks driving too close.
Would be a cool idea, needs to swing out to the right over here though!
Xanda2260
Postby Tpower » Wed Jul 18, 2012 5:02 am
Xanda,very nice in black and white,i like it.
Tpower
Postby MagerPain » Wed Jul 18, 2012 5:37 am
That is a truly awesome build mate!
I'm currently in the process of scratch building a tadpole from my own designs based on hundreds of google images, youtube videos, manufacturer websites etc. This is certainly adding to the inspiration stream!
Based on your experience with the 9C motor, would you recommend getting one? I'm torn between getting either the 9C or going all out and getting the Crystalite HS3540.
Stay safe on your creation! :mrgreen:
Cheers,
Rob
"If you feel safe and in control, you're not going fast enough."
MagerPain
Postby Xanda2260 » Wed Jul 18, 2012 11:17 am
MagerPain wrote:That is a truly awesome build mate!
Cheers,
Rob
The 9c is cool, but I'd like better acceleration. This motor at 100v in a 20" rim would be lovely, in a 26" it's a bit sluggish to accelerate for my tastes.
Xanda2260
Postby honduran_kid » Wed Jul 18, 2012 1:26 pm
Rob
Great looking trike Xanda!
Ive also been working on building a Warrior trike, but i have modified alot the design to fit the setup that i want.
MagerPain
this website has a great blueprint for one, and the instructions are alot more precise then AZ
http://amidesign.ch/en_hpv-trike.htm
honduran_kid
PreviousNext
Users browsing this forum: Google [Bot], o00scorpion00o, powerfloe and 10 guests
