Group Buy? Dr.Bass Steveo found 7s3p Module! Awesome Price!!
Re: Group Buy? Dr.Bass Steveo found 7s3p Module! Awesome Pri
Postby deVries » Wed May 16, 2012 3:16 am
zaxxon wrote:In my case Xin wrote me before the sale that they would replace defective module if bad. When I said I wanted to return the bad module for replacement. Xin told me her Company did not want me to send back module because of concerns around shipping, custom, and clearance fees. So I said if I can’t return for replacement then only options where to return money or send a replacement. Xin agreed to send replacement unit if I paid full shipping costs. I agreed and she sent invoice, I sent money. Next day Xin, said she misunderstood her superior and now I must also send bad module back to get replacement. AND I would alsol have to pay shipment on return unit.
My cost to ship back in a reasonable time would be $885. The total costs for replacing module would be $2,804 ($1060 item + $450 original shipping + $885 shipping cost to return + $439 replacement shipping). Victpower would not work with me. Their final offer was to sell me another module at 10% off original price and I still pay shipment.
I wish we had someone that had real connections with this company, or was on the ground where they are located, so we could maybe resolve this sheeit from ever happening. Until then, I hoping someone will invest the time with a defective module to do a cell repair & document it here in this thread. Please search on dremel in this thread if you want to read my ideas about how to do this.
Speaking of cell repairs, that reminds me, :lol: would you have any interest in doing a cell repair for us? :D
deVries
Postby Sutho » Wed May 16, 2012 4:23 am
zaxxon wrote:Sorry you are correct nothing new. I was so worked up over their final offer last night, I had forgotten they changed the terms from when I ordered.
Going through the same f'n sh!t with Xin and Co. I am now at the point where I am keeping the bad units and buying 10 replacement units at a slightly lower price than before. They won't do anything until I cancel the PayPal claim, blah, blah, blah....and on it goes. :?
I will use the bad units I retain for experimentation on methods to disassemble or repair these types of modules.
On the bright side.....I almost have the 12 module bank assembled ready for testing. :)
Sutho
Postby bigmoose » Wed May 16, 2012 7:24 am
Have you guys thought about keeping the transactions separate, and going forward with the paypal claim. Then purchasing your make up modules through a friend/mate/relative as a separate transaction? That way this sketchy vendor bears some responsibility for it's actions.
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby peterperkins » Wed May 16, 2012 9:20 am
The A123 pcb white BMS connector is
JST part number
S22B-AIT2G-2FS
https://www.jst.co.uk/productSeries.php?pid=15175
I have requested 6 samples which is enough to make six test BMS boards for my A123 packs.
Strangely the datasheet says it's only rated at 14V :?
Honda Insight MK1 lmpg 131mpg Imp
Lifepo4 40ah HiPower IMA Pack & 20ah A123 IMA Pack
BCM Fooler, BCM Interceptor, BCM Gauge, Li-Ion BMS System, OBDIIC&C, IMAC&C
http://www.150mpg.co.uk
peterperkins
Postby Ypedal » Wed May 16, 2012 11:17 am
I just went ahead and orderd 10 hobby king packs.. :lol:
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby deVries » Wed May 16, 2012 11:29 am
Ypedal wrote:I just went ahead and orderd 10 hobby king packs.. :lol:
Dude, why didn't you just buy the A123 cells & do a build thread. You know you want to. :twisted:
Sutho, now that you decided to keep those defective modules we look forward to a cell repair & disassembling the 7s module, etc. Hey, take your time, though I'm sure some folks here just cringed in extreme patience. :mrgreen:
deVries
Postby oatnet » Wed May 16, 2012 12:05 pm
peterperkins wrote:The A123 pcb white BMS connector is
JST part number
S22B-AIT2G-2FS
Thanks Peter, you helped me by finding these, I'm gonna get some. :D This are for the 28s packs, right?
I usually worry about amps going through the connectors, not volts... each pin should see 3.65v (or 7.3v if you are counting both cells using each pin) so wouldn't that be under the 14v rating?
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
oatnet
Postby miro13car » Wed May 16, 2012 1:13 pm
Zaxxon
Are they for real
Victpower accepted your money and changed rules right after that?
Disguisting I must say
miro13car
Postby zaxxon » Wed May 16, 2012 7:31 pm
If I can’t get the Mini to run reasonably well on two packs for trips to work (if other two packs are any good), I will likely try to salvage the bad pack if enough cells take and hold any charge. All the cells except the shorted one were down around 0.6 volts Right now I can only attempt to bypass bad banks rather than attempt a cell replacements because I don’t own any replacement cells. And now my EV battery fund allocation has been more than depleted.
zaxxon
Postby zaxxon » Wed May 16, 2012 7:44 pm
Based on prior experience on a Prius pack, Paypal will require you to send back the modules. If you are willing to send back on slow boat at a lower cost, and wait to get additional module or through other methods as was just suggested, I would NOT drop dispute and continue to keep Paypal on to help to get replacement modules or your material costs back. I wish now I had used Paypal instead of T/T payment. Without Paypal, once you drop the dispute Xin may come back and say, Sorry my superior says I can’t sell modules to you at that price now, or modules are no longer available (to you).
zaxxon
Postby zaxxon » Wed May 16, 2012 7:58 pm
miro13car wrote:Zaxxon
Are they for real
Yes, I have the Proforma Invioce to prove it and the bank T/T payment.
zaxxon
Postby SlyCayer » Wed May 16, 2012 8:01 pm
zaxxon wrote:or modules are no longer available (to you).
Yep! Do not drop the dispute in my opinion...
http://www.JCCayer.com Where you can find tools and Dewalt(A123) batteries.
SlyCayer
Postby zaxxon » Wed May 16, 2012 10:57 pm
peterperkins wrote:My three A123 28S3P modules have safely arrived at my address in the UK.
The packing is the fairly horrible but reasonably well fitted wooden crates with a few bits of foam.
Mine seemed to have survived the trip well. A few aluminium fins are dented but nothing structural or broken. Probably old damage.
Only slight bowing on one module, fixed by flipping onto it's side.
All showing around 93V and no sign of any dead groups.
Will capacity test in due course.
Also made it through customs unmolested 8)
Total cost to me $4531 or £2822 or £940 each. ~£12 per cell. I paid via bank transfer.
Two in series will make a very nice 60ah pack for my original phev insight or a stiff test pack for my EV conversion.
So I have a spare pack for someones high powered recumbent project/rickshaw in the UK.
Buyer collects £1000 cash. Perhaps I should have bought 4 :roll:
One pic FYI
Given your modules look square and nice. Did yours come with wood feet added in middle and a thicker bottom board as I suggested to Xin they needed to do? If yes, I am glad someone benefited from my input.
Attached pictures shows the fine care and quality of packaging Victpower used on my modules that resulted in very warped module and bent fins.
The other pictures show what happens when one of the cell shorts. Shorted in this case, from some impact damage before item was shipped. Rusty screw indicates this was damaged some time ago. Damage had to be obvious to Victpower. Yet they shipped it to me. This is the bad module VictPower would not reasonably compensate me for.
You can see fins and bus discolorization and paint bubbling from the heat caused by others cells dumping into the shorted cell. This high heat and the possibility of ignition of adjacent materials is probably why A123 is replacing modules.
Shipment Package
Shipment Package
Shipment Package
Damaged Module
Damaged Module
zaxxon
Postby peterperkins » Wed May 16, 2012 11:20 pm
oatnet wrote:Thanks Peter, you helped me by finding these, I'm gonna get some. :D This are for the 28s packs, right?
-JD
They are fitted on my 28S packs. Note there is a BMS board at each end of the pack and each pcb serves 14 cells.
I suspect the connector is the same type on each different size (smaller) module but just uses less pins.
Or is a smaller number of pins connector from the same range.
The 42S pack may use three BMS boards 14 x 3?
As for the packing it was minimal and basically a close fitting wooden box with a few odd bits of foam.
It didn't have any feet on the wooden case so it didn't matter which way it was up, which was probably better as it least it laid flat in any orientation.
peterperkins
Postby Sutho » Thu May 17, 2012 2:48 am
First 12 modules assembled as a pack giving just under 280V 60Ah.
When I manage to obtain or salvage another 6 modules, they will connect in with these to provide 420V 60Ah.
A123 Battery Pack 1.jpg (165 KiB) Viewed 736 times
A123 Battery Pack 2.jpg (149.93 KiB) Viewed 736 times
Sutho
Postby peterperkins » Thu May 17, 2012 4:44 am
A123 BMS Testing
I plugged one of my packs into my CC/CV 2A charger today and topped it up.
I have found the A123 BMS is active and it has started to bleed off current. I'll check the load switch on voltages etc as we go.
The pack must have been full when it arrived. It also means if your packs are very low you should probably disconnect the bms parasitic load.
The load for each channel is made up of 8 x 91R (910) marked smd resistors in parallel = 11.375R effective resistance.
At 3.65v that gives a balancing current of ~320ma at 1.1w which seems reasonable.
The BMS pcb has two active leds I can see. I will watch to see when they go on and off.
They are on at the moment but the cells had reached ~3.90v and the pcb is now quite hot as it is disipating ~15w from the 14 channels.
All the channels/cell groups seemed very well in balance in this first pack.
I'll try and identify the other black BMS connector as it may be possible is is now also active and sending data or warnings.
At a pinch it might be possible to use the led/s to drive an external circuit by connecting directly to the pcb or by hot gluing an opto transistor on top of it :shock:
Edit. The leds on the bms pcb have turned off and the bleeding of current has stopped now cell groups are below 3.85v.
peterperkins
Postby texaspyro » Thu May 17, 2012 10:11 am
Sutho wrote:When I manage to obtain or salvage another 6 modules, they will connect in with these to provide 420V 60Ah.
That should make for a SWEEEEET big red wire to black wire test... :twisted: We eagerly await the video...
texaspyro
Postby oatnet » Thu May 17, 2012 11:27 am
-JD
You must have missed earlier in this thread, where I documented both of these features in text and pictures.
Did your 28s BMS not have the strong, terrible smell I noticed on mine?
Did you charge your cells all the way up to 3.90v by accident, or are you testing something I haven't thought about?
-JD
Image大鸡巴 Motors
oatnet
Postby oatnet » Thu May 17, 2012 11:35 am
Sutho wrote:First 12 modules assembled as a pack giving just under 280V 60Ah.
Impressive pack Sutho. I'm suprised you are using the 7s format, instead of the 28s format, since the 28s module weighs 107lb, and 4x7s=28s modules weigh 120lb. Your 420v pack will weigh an extra 52lbs, be 24" longer, and you add the weight and points of failure from (11) additional module-to-module power connections. I'm guessing you had a need to distribute the modules?
-JD
Image大鸡巴 Motors
oatnet
Postby SlyCayer » Thu May 17, 2012 6:10 pm
texaspyro wrote:That should make for a SWEEEEET big red wire to black wire test... :twisted: We eagerly await the video...
Addicted to fireworks?
SlyCayer
Postby Sutho » Thu May 17, 2012 6:15 pm
oatnet wrote:Impressive pack Sutho. I'm suprised you are using the 7s format, instead of the 28s format, since the 28s module weighs 107lb, and 4x7s=28s modules weigh 120lb. Your 420v pack will weigh an extra 52lbs, be 24" longer, and you add the weight and points of failure from (11) additional module-to-module power connections. I'm guessing you had a need to distribute the modules?
-JD
Yeah......was all to do with space restrictions. The modules pictured go in a box in the rear of the vehicle and another 6 modules will go in the front. The 28s is definitely too long for the front area.....and I guesstimated it to be too long for the rear.....but would now appear that they may not be? What is the actual length of the 28s?
Based on reports in this thread.....what are the chances of getting 4+ 28s modules from Victpower that were in good condition and usable? :(
Sutho
Postby SlyCayer » Thu May 17, 2012 7:07 pm
Sutho wrote:what are the chances of getting 4+ 28s modules from Victpower that were in good condition and usable? :(
0 to none?
SlyCayer
Postby oatnet » Thu May 17, 2012 9:06 pm
The 28s is about 28", I laid a yardstick over one in these pics: viewtopic.php?f=14&t=38901&start=255#p575214
Yours should be an interesting pack! Did you fabricate the power leads yourself? They are really clean work.
-JD
Image大鸡巴 Motors
oatnet
Postby Sutho » Thu May 17, 2012 10:06 pm
oatnet wrote:The 28s is about 28", I laid a yardstick over one in these pics: viewtopic.php?f=14&t=38901&start=255#p575214
-JD
Looks like they would have fit.....but would I would have had to combine them with a smaller pack to get the right voltage. My controller/inverter supports 450Vdc max.
4 x 28s = 370Vnom 409Vpk (too low)
5 x 28s = 462Vnom 511Vpk (too high)
18 x 7s = 416Vnom 460Vpk (about right)
Yes...power leads were made using palm lugs which we cut down and drilled. This enables maximum contact area on the terminal plates.
Sutho
Postby deVries » Fri May 18, 2012 2:33 am
:D User name could be a clue! :lol:
Texaspyro posted a huge fireworks "rocket" explosion in the desert at night with him running very fast hopefully in the opposite direction! :twisted:
:lol: :wink:
deVries
PreviousNext
Return to Battery Technology
Users browsing this forum: dogman, Tommy L and 7 guests
