by ProDigit » Sun May 20, 2012 9:00 pm
I don't know,
Just a suggestion, but,
It could be that the wrong system is applied for electric bikes.
These brushless engines have a high torq at low RPMs but at higher RPMs become less powerful. also the controller plays a big role in all of this.
I had done electro mechanics in school, it was not in English, but there exists some kind of engine like a brushless engine, with the axis just being a cage, no magnets, no coils, no burshes.
My teacher explained it was a 'series engine' literally translated from my mother tongue.
The difference is that current technology is a parallel engine, which means the higher the voltage the more powerful the engine, but the RPM's are pretty much limited to the controller or phase frequency on an AC network.
In a series engine, the torq is lower, but constant. Even with a low voltage, on a zero ballast, the engine will spin out of control.
These types of engines just provide a constant, low Torq, force, regardless of RPM. If the torq is big enough to get a driver riding, they could accelerate indefinitely if they did not have the wind resistance. These types of engines might be better suited for this job, perhaps, as they're not into precision, but acceleration.
Technically if you find such an engine that can drive you 30mph (when wind resistance nullifies the force the motor is pushing the bike), when wind direction changes, speed can change too. These type of engines are also lousy performers on a hill, but could reach ridiculous speeds downhill without breaking a sweat or even overheating!
@Hillhater: It all depends, the controller limits some engines more than an engine itself limits the bike. It might be possible to go faster with a 500W engine.
Since I don't have the name of the engine I described above, best thing you can do is test a 500W brush motor, apply 48V onto it, and accelerate until the bike accelerates no more. Then you know how fast on average a 500W engine can accelerate.
When the engine has enough torq, try getting a 500W engine with a lower voltage rating, like eg,one that needs 36V to operate if that exists. Plug it on 48V, and see how fast you can go!
