I searched the forum but I could not find any thread where I can find an answer.
I have built a 36v 24ah (10s12p) li-ion battery for my ebike using 18650 cells from laptop batteries. The typical power usage is between 300-500w when travelling at full throttle and not pedalling. But during stop & go the current draw is up to 32A/1200w. This causes some of the cells to go under 3.2v, which I want to avoid.
I tried smoothing the throttle adding a variable resistor to the ground wire of the throttle and things have improved a bit but sometimes I still draw too many Amps during stop & go.
I would like to avoid that "stress" to the battery adding some capacitors in parallel to the battery. I read a discussion here and people have different opinions. Moreover I cannot find any real data about the use of the capacitors in parallel with the battery.
I want to make it clear the I do not intend to use capacitors instead of the battery, I already know it's not worth it, I am just wondering if they would avoid some stress to the battery during stop & go.
I was thinking to use some capacitors of pc's atx power supply as I could have access to those for free. Since I don't have to pay for them maybe it's worth a try?
I appreciate any opinion on this subject.
