Answering Questions on the Wiki (Proposal)
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling. Guest may post replies to topics already here. All topics here will expire after 90 days of inactivity.
Postby amberwolf » Fri Jun 01, 2012 4:14 am
We get lots of the same questions over and over again, which mostly can be answered with the same exact answer, or very close, or which must be answered with a slew of questions because there isn't enough info.
So, for each person that normally answers such things, rather than using your time to answer a specific thread's question like this, in future, I propose that instead you spend your time writing the answer as a Wiki article, in the ES Wiki:
http://endless-sphere.com/w
and then post a link to your article in the thread asking the question, with a recommendation that they first read the article, then come back with specific questions not answered there.
Right now, lots of us could be writng up wiki articles based on various subjects we know, or garnering good info out of really long threads and making a concise article in the wiki about it. But there is not much time to do that after spending sometimes hours each day answering the same old quesitons over and over again.
How about it? Will you donate your time to the wiki and future help of everyone? Or just keep answering the same things over and over again. ;)
House Fire Updates Thread
DayGlo Avenger, MkII
amberwolf
Re: Answering Questions on the Wiki (Proposal)
Postby fechter » Fri Jun 01, 2012 1:40 pm
Excellent idea.
If you can find where you've answered it before, simply copy/paste into the wiki article.
fechter
Postby amberwolf » Fri Jun 01, 2012 3:26 pm
And...my first one:
http://www.endless-sphere.com/w/index.p ... ies_to_all)
(also added sections for switches, contactors, and relays, though I haven't had time to make them yet)
amberwolf
Postby NeilP » Fri Jun 01, 2012 4:12 pm
Funny you should say that.
I put a few very little, but non technical bits there the other day about Controller front end PSU's..only jottings really
http://www.endless-sphere.com/w/index.php/Brushless
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
10 GW
10 GW
Postby el_walto » Fri Jun 01, 2012 4:17 pm
I'd write some sections if my username and password would actually work for the wiki.
Login error
You have not specified a valid username.
el_walto
Postby Ypedal » Fri Jun 01, 2012 4:23 pm
el_walto wrote:I'd write some sections if my username and password would actually work for the wiki.
Login error
probably the underscore " _ " in you username.. this has come up before with other non A~Z 0~9 characters...
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby amberwolf » Sun Jun 03, 2012 10:06 pm
Hopefully MRVass will have a fix for that soon.
More wikied answers:
http://www.endless-sphere.com/w/index.p ... leshooting
amberwolf
Postby NeilP » Mon Sep 03, 2012 1:06 am
As I have found, I started to create a Google doc, that I would have transferred to the wiki, I posted to at least three people plus put up a link on a thread, asking for comments with regard to it..does it make sense, can you understand, etc etc not one response to help me improve it, so it is easy to see why people do not bother to upload stuff i was trying to but got no feedback, so it is difficult
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby amberwolf » Mon Sep 03, 2012 3:09 pm
I don't recall ever seeing the topic. :(
Best is just to post the wiki article, as it can be edited easily enough (easier to correct errors than writing it from scratch); commenting can be done right there in the wiki "talk" page, as that is how wikis are designed to be used. :)
If all discussion about the article has to be done on other sites than the wiki, it makes it harder to have to go to one site (ES Forum) to discuss it, another (GD or ES Wiki) to input it or edit it or read it, another (ES Forum/etc) to research it, etc. If it can all (or most) be done on one place (ES Wiki), it would be easier. It also keeps the revision history of the article all in one place, as sometimes there is very good information left out of the final article that may well be applicable to some other article, or good to create it's own, and that can simply be copied over from that revision history or wiki discussion to another Wiki article.
FWIW: I typically can't access Google docs or vids or whatever, as the latest browser versions that I can use on either of my systems (for various reasons) are too old to be compatible with all their features. Since Google doesn't want to deal with troubleshooting, they just give error messages that I need to upgrade my browser and disable the whole page, preventing even viewing it. Some of their pages, like Gmail, have a "nobrowsercheck" function that lets me at least access the page, even if all the features don't work the basic stuff still does. I doubt most poeple have this problem, but some others probably do.
(I used to have a laptop that I could use newer browsers on, but it has a power connector problem that requires complete disassembly to fix (an all day job), and with two other working computers it is not priority enough to deal with, vs everythign else I have to do.)
amberwolf
Postby NeilP » Tue Sep 04, 2012 4:05 am
amberwolf wrote:I don't recall ever seeing the topic. :(
I did not help myself in a way, but what I did, I did for a reason. I sent only to people that did not understand in the first place. My thinking being, that getting someone to try and read it, that already understands will 'fill in the blanks' them selves on what I wrote, where as someone that I am trying to explain to for the first time will have to ask if they do not understand.
AlanB then did a more brief version on the wiki...so I left it at that.
http://www.endless-sphere.com/w/index.p ... less_Motor
https://docs.google.com/document/d/1w8m ... edit?pli=1
180mm disks
100V 20Ah LiPo
NeilP
10 GW
10 GW
Postby amberwolf » Tue Sep 04, 2012 4:25 am
NeilP wrote:My thinking being, that getting someone to try and read it, that already understands will 'fill in the blanks' them selves on what I wrote, where as someone that I am trying to explain to for the first time will have to ask if they do not understand.
That is a very good point I hadn't thought of.
amberwolf
Postby Ricky_nz » Sun Jan 06, 2013 12:03 am
Login error
Any news on this this I can't login to the wiki yet
Latest Projects: High power vector controller for Turnigy 80-100, Keewe Stealth DJ bike with Turnigy 80-100 180.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Commuter bike with 1000W GM rear hub.
Ricky_nz
Postby Gregb » Mon Feb 18, 2013 6:23 am
yes but it wont hurt if someone else who knows the subject, checks your writings for accuracy......
Gregb
Return to Items for Sale - Used
Users browsing this forum: No registered users and 3 guests
