Chalo wrote:Glass is a lot stiffer than aluminum, for what it's worth.
John in CR wrote:Chalo wrote:Glass is a lot stiffer than aluminum, for what it's worth.
If that's the case, then it's definitely not a good idea, and I'll just source some carbon cloth for the outer layer. I don't know though, the stuff I look at says aluminum is significantly stiffer, and this seems like an idea way to put that to use since the core of the tube is solid. Fiberglass is pretty darn flexible in tube shape...thing fishing poles, pole vaulting poles, fiberglass antennae, etc.
Chalo wrote:Solid aluminum is stiffer than fiberglass/resin layup, but you're not talking about using solid aluminum. You're talking about using it in a layup, like the glass. I looked up the Young's moduli of aluminum and glass, and it turns out that because glass can consist of a whole lot of different materials, it varies from less stiff to more stiff than aluminum. The Young's modulus (inherent stiffness) of aluminum is 69 GPa. Glass ranges from 50-90 GPa depending on what's in it. Fused quartz (silica glass) has a Young's modulus of 72 GPa, or about the same as aluminum.
According to Wikipedia, the modulus of a 70/30% layup of glass and polyester resin, along the grain, is 40-45 GPa. That's probably starting with relatively high-modulus glass, so the construction cuts the stiffness of the bulk glass material by almost half. You can expect the same with sheet aluminum, depending a lot on how much resin you can squeeze out of the layup.
Aluminum may make stiff bike frames, but it's only 1/3 as stiff as steel. It makes stiff frames because you can make it into bigger tubes without a weight penalty, and bigger tubes are much stiffer. So maybe you should start with D cells.
Stone Meadow wrote:According to this table, the Young's modulus for 50/50 fiber/resin is 25. That's about as good a ratio a rank amateur can get with pure hand layup, and only then if it's post-cured above 100+ centigrade. One can hit 40 only with unidirectional fibers, which I suspect John will have a tough time getting hold of in Costa Rica. Fiberglass has many useful properties, but high Young's modulus is not among them...![]()
John in CR wrote:Just like I won't bond each aluminum layer to the next as I roll it up, I don't think a great bond to the aluminum is important.
Chalo wrote:What John is proposing to build here is an aluminum piñata. And that's fine, if it works. But it won't be an improvement over simple fiberglass.
Chalo
Chalo wrote:John in CR wrote:Just like I won't bond each aluminum layer to the next as I roll it up, I don't think a great bond to the aluminum is important.
I don't think you understand the problem you are trying to solve, then.
Chalo
Hillhater wrote:Unless each layer of foil is bonded to its partner layers with something that has the same properties as aluminium, the end "sandwich" will have only the strength of the bonding agent.
Aluminium foil has zero strength, other than in pure tension, and only then if you can avoid any / all minor imperfections.
.. Acid etching 0.024 mm foil would be an interesting project !
texaspyro wrote:Epoxy don't stick for shit to smooth surfaces... or aluminum for that matter.
John in CR wrote:Hillhater wrote:Unless each layer of foil is bonded to its partner layers with something that has the same properties as aluminium, the end "sandwich" will have only the strength of the bonding agent.
Not true. It will be like 20 perfectly fitting very thin aluminum tubes one slid over the next one and end up quite similar to a .5mm tube of AL over a 3.5" solid core. Now if you guys think .5mm isn't enough, then I'm listening.
Users browsing this forum: Byte and 12 guests
