WSU Develops Tin Anode-3x capacity and less expensive
Postby MitchJi » Sun Jun 03, 2012 4:45 pm
Hi,
Sounds promising. Within a year, 3x the capacity, better cycle life, higher charge rates and less expensive:
http://news.wsu.edu/pages/publications.asp?Action=Detail&PublicationID=31776&TypeID=1
PULLMAN, Wash. – Washington State University researchers have developed a new technology that could triple the capacity of lithium-ion batteries, which as anyone who owns a cell phone or laptop knows, can be frustratingly limiting.
Led by Grant Norton, professor in the School of Mechanical and Materials Engineering, the researchers have filed patents on the nanoscale-based technology, which also allows the batteries to re-charge many more times and more quickly than current models. They expect to bring it to the market within a year.
In particular, the researchers have developed an anode made of tin, rather than the carbon used currently. Rechargeable lithium ion batteries are made up of two electrodes, the cathode and an anode. During charging, the lithium ions move from the cathode to the anode. The anode holds the lithium ions and stores the battery’s energy. When the battery is used, the ions move from the anode to the cathode, discharging electrons and creating an electric circuit.
The new tin anode has the potential to store almost three times the energy of graphite.
Norton and postdoctoral researcher Uttara Sahaym developed the novel material a little over a year ago while working on a project to mitigate tin whiskers, which are literally tiny whiskers that grow on tin-plated electronics. The whiskers, which can sometimes grow as long as 10 millimeters, are a pesky problem in microelectronics because they create short circuits that can cause catastrophic damage. Yet, despite the fact that tin whiskers have been causing problems for more than 60 years, researchers have been unable to come up with ways to entirely avoid them.
Norton and his group decided to turn the problem on its head and see if they could control the growth of tin whiskers, instead of trying to get rid of them. They applied the work to developing a tin-based anode for batteries.
The researchers developed a method for growing tin nanoneedles directly onto copper foil using a standard electroplating process that is commonly used in industry. Electroplating means the tin-based anode costs less than regular graphite anodes with triple the energy storage capacity. The end product battery will look exactly the same as the current batteries, so that manufacturers don’t have to redesign their electronic devices to make room for a new battery.
With support from the WSU College of Engineering and Architecture’s Emerging Technology Fund, which is funded by private donations, the researchers have started building and testing the batteries.
Best Wishes!
Mitch
MitchJi
Re: WSU Develops Tin Anode-3x capacity and less expensive
Postby texaspyro » Sun Jun 03, 2012 6:54 pm
Should be entertaining if the tin whiskers grow whiskers that pierce the separator...
texaspyro
Postby Kirk » Sun Jun 03, 2012 11:49 pm
Its not a Nuclear battery but I'll take 18 6s 24000mAh cell pacs. Which should see me thru the day. Wonder how many cycles they will go.
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
Kirk
Postby bearing » Mon Jun 11, 2012 7:53 am
Looks promising. I wonder what the cycle life will be compared to the common battery with a carbon anode. Is it the anode or cathode that is most important for cycle life?
bearing
Postby SamTexas » Mon Jun 11, 2012 8:13 am
MitchJi wrote:Sounds promising. Within a year, 3x the capacity, better cycle life, higher charge rates and less expensive:
Agreed. Sounds promising. But I'm not holding my breath. Like most press releases, this sounds overly optimistic and overly vague. 3x compared to what? Better cycle compared to what? Same with higher charge rate. Why not be straight forward and say xxx energy density, yyy cycle life and zzz charge rate?
Brought to the market within 1 year? Not a single chance.
SamTexas
Postby deVries » Mon Jun 11, 2012 10:25 am
You're exactly right, imo. They'll be lucky to go to market within 3 years even on a small scale. They have a huge amount of unproven experiments to do proving results before getting to market beyond a micro-scale. Only way to ramp-up fast would be to license the technology to a battery company that won't bury it. :idea:
I have a topic thread that already covers these new battery findings. This article was already referenced in that thread. :D
Please post your findings here if it falls within this topic:
Attn Experts: When Will Battery Capacity Double ?
deVries
Return to Battery Technology
Users browsing this forum: Bing [Bot] and 8 guests
