Removing chinese freewheel?
Postby ian.mich » Fri Jun 01, 2012 6:06 pm
I was wondering what tool(s) i need to remove the freewheel on a chinese 1000w hub motor
Picture: http://tinypic.com/r/4p3jc/6
I don't see where i could put in something like this:
http://www.ebay.com/itm/Park-Freewheel- ... _649wt_874
http://www.AtypicalEV.com
Avalanche 3.0
Front and back Weinmann DH39s in 12G,
Motor laced using custom Sapim 12G with linseed oil
24s3p 5ah hardcase LiPo in a FalconEV frame bag, 8A bulk charge
Batt medics
18x4110 controller at 60A
DD hub with 12g inside and 10g outside
Doc's torque arms
ian.mich
Re: Removing chinese freewheel?
Postby Kirk » Fri Jun 01, 2012 6:23 pm
Normally the wires come out of the other side of the motor and your freewheel removal tool wood go over the axle and engage the freewheel. I think you'll need to ask the company who made that hubmotor for their freewheel removal tool.
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
Kirk
Postby TylerDurden » Fri Jun 01, 2012 6:38 pm
Hmmm... looks like you'll need to take the freewheel apart to remove it.
A pin-wrench should be able to get the outboard race removed - all the outboard bearings will fall out and the housing/sprocket can pull off, letting all the inboard bearings fall out - leaving the inner races attached to the hub. A large pair of channel-pliers or pipe wrench should get it. Pay attention to LH or RH threading.
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Postby SamTexas » Fri Jun 01, 2012 6:50 pm
Can you use a Dremel to make one or two deep notches? Then use a big flat screw driver and a hammer to unscrew it? That's how I would do it.
SamTexas
Postby ian.mich » Fri Jun 01, 2012 6:58 pm
SamTexas wrote:Can you use a Dremel to make one or two deep notches? Then use a big flat screw driver and a hammer to unscrew it? That's how I would do it.
sorry notches into what? the threading?
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby TylerDurden » Fri Jun 01, 2012 7:02 pm
Those threads are probably hardened.
Have a Nice Day,
TD
TylerDurden
Postby SamTexas » Fri Jun 01, 2012 7:05 pm
See the two notches at 1 and 7 o'clock? I would make them a little deeper. Then insert the tip of big flat screw driver into one of them in the UNscrewing direction and tap the screwdriver with a hammer. Does that make sense?
SamTexas
Postby TylerDurden » Fri Jun 01, 2012 7:16 pm
Cutting into those threads could be a chore. A diamond or cutoff wheel might do it.
But the freewheel is too cheap to bother saving. I'd take it apart, take it off, throw it away and get a better one.
Plus, if it's been on there for very long, the aluminum and steel may have bonded and even the pipe wrench might be a chore.
Have a Nice Day,
TD
TylerDurden
Postby SamTexas » Fri Jun 01, 2012 7:20 pm
How do you take it apart?
SamTexas
Postby TylerDurden » Fri Jun 01, 2012 7:26 pm
SamTexas wrote:How do you take it apart?
viewtopic.php?f=30&t=40351&p=589626#p589626
Have a Nice Day,
TD
TylerDurden
Postby SamTexas » Fri Jun 01, 2012 7:36 pm
OK. OP take your pick.
SamTexas
Postby Joseph C. » Fri Jun 01, 2012 8:04 pm
I must say I love your work.
Yellow Magpie - Home Of The Talented And The Interesting
http://yellowmagpie.com
Joseph C.
Postby ian.mich » Fri Jun 01, 2012 9:01 pm
Yeah im gonna order a pin wrench asap. thanks everyone.
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby salty9 » Fri Jun 01, 2012 10:52 pm
ian.mich wrote:Yeah im gonna order a pin wrench asap. thanks everyone.
Also called spanner wrenches. Some examples:
http://www.nextag.com/spanner-wrench/stores-html
salty9
Postby amberwolf » Sat Jun 02, 2012 3:48 am
I wonder if they put it on backwards? If they did, then the notches used for the removal tool are on the motor side.... :(
But the good news is, if it's on backwards, you can just use whatever will grab the sprocket teeth and turn counterclockwise, and it'll take it off, becuase it will freewheel in the other direction.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby chvidgov.bc.ca » Sun Jun 03, 2012 9:07 am
One can often remove a freewheel by putting the freewheelin a vice and then turning the wheel itself the correct direction. The leverage does it.
CatrikeRoad Rear9C 2805 KU123Sensorless CA
DevinciVancouver Front9C Disk
Rebike 20"R/16"F Bent C404 Front 48V 20A Crystalyte Pedal First
CCM 26" Cruiser Nexus 7 C406Front 48V 35Amp Crystalyte Start Imm
Sun EZSport CX 26R/20F LWBent C405 Front 48V 35Amp Crystalyte Start Imm
Giant Revive DX 20" Nexus 7 RearSusp with 9C Front 48V KU123
Actionbent T1 trike with Rear9C2806 KU123Sensorless CA
Vision R40 Recum USS SWB EZEE
CannondaleHooligan Cute100 48VHead 60T ring KU63
chvidgov.bc.ca
Postby SamTexas » Sun Jun 03, 2012 10:22 am
chvidgov.bc.ca wrote:One can often remove a freewheel by putting the freewheelin a vice and then turning the wheel itself the correct direction. The leverage does it.
Sounds like a good idea. Are the freewheel teeth damaged by the vice's clamping force?
SamTexas
Postby mr.electric » Sun Jun 03, 2012 11:46 am
I put a chisel against the notch meant for the spanner and knock it with good force using a hammer. Works every time.
A cold chisel is better. A regular wood chisel will get ruined. It does cut a bit of a groove in the edge of the notch but that does not matter much.
-Fat Sand Bike with 9c and 29ah pack
-Giants mascot scooter
mr.electric
Postby ian.mich » Sun Jun 03, 2012 11:49 am
amberwolf wrote:I wonder if they put it on backwards? If they did, then the notches used for the removal tool are on the motor side.... :(
Nope, its on right way around. pin wrench is on its way.
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby TylerDurden » Sun Jun 03, 2012 10:24 pm
That technique is generally used with the freewheel tool:
Tool facing up in the vise, set wheel onto tool, grab rim and turn normal rolling direction.
Have a Nice Day,
TD
TylerDurden
Postby ian.mich » Mon Jun 04, 2012 4:41 am
yeah lol i was wondering what he was talking about
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Return to Motor Technology
Users browsing this forum: EdwardNY and 5 guests
