Rahlo12 wrote:I'd like to use my own rim and wheel on my e-bike, and don't really want to purchace a motor with a rim, however I will certainly buy some washers now and when I lace the motor, everything concerning the spokes should be fine. Thank you.
Tench wrote:If you buy an HS3540 from Crystalyte europe it will not have Halls fitted, getting one from Methods or ebike.ca may be a little more expensive but the motor will have been fitted with halls and have had the wiring exit improved. Personaly i would always go for a motor fitted with hall sensors, i only mentioned this as it has not been mentioned above and i didnt know if your where aware of this. I am in the uk, the last one i bought i got from ebikes.ca along with a controller and CA, the CA came with the controllers r-shunt value pre-programmed in. There are advantages to paying to that bit extra, it depends what your priorities are though.
kudos wrote:Tench wrote:If you buy an HS3540 from Crystalyte europe it will not have Halls fitted, getting one from Methods or ebike.ca may be a little more expensive but the motor will have been fitted with halls and have had the wiring exit improved. Personaly i would always go for a motor fitted with hall sensors, i only mentioned this as it has not been mentioned above and i didnt know if your where aware of this. I am in the uk, the last one i bought i got from ebikes.ca along with a controller and CA, the CA came with the controllers r-shunt value pre-programmed in. There are advantages to paying to that bit extra, it depends what your priorities are though.
Tench, xlyte euro do offer halls fitted if you want:
http://shop.crystalyte-europe.com/produ ... 295&page=1
Rahlo12 wrote:Hi,
I'm new to the world of e-bikes and endless sphere, but after a month of small scale researching I think I have got the basics and am ready to start building my bike.
I've read a lot about the HS3540 and it seems like a good high performance motor, and I think its the successor of the 5304 crystatyle motor which was apparently very widely used.
Anyway, as I said I am new, and therefore don't know where exactly to buy the motor for the best price possible.
http://www.ebikedeal.com/crystalyte.htm
So far this is the best price and website I have seen that sells the HS3540, but I'm not sure whether its reliable and the cheapest place to get it etc.
I'd be very thankful if someone where to help me on this and possible confirm the website, or maybe suggest a better option.
thanks.
spiritxxx733t wrote:hi man,
have you any updates on your it? how was the service and quality of the goods from ebikedeal.com
what kind of battery are you using and what kind of speeds and range are you getting?
I live in england too and thinking of buying from ebikedeal.com for the hs3540 kit.
many thanks
Users browsing this forum: Deadmul3, gmaiella, migueralliart and 10 guests
