HK Cell-Log Cell Voltage Monitor 2-8S Lipo?
Postby SamTexas » Tue Jun 26, 2012 10:11 am
http://www.hobbyking.com/hobbyking/stor ... _Lipo.html
I am very dissatisfied with HK Battery Monitor 2-6S (http://www.hobbyking.com/hobbyking/stor ... _2_6S.html). They are extremely inaccurate. I'm now looking for something better with the data logging ability.
Questions:
1) Are you satisfied with the voltage accuracy of the above Cell-Log?
2) What (if any) features/functions you like the least?
3) Would you buy it again?
4) Is there a better product in that price range (around $30)?
Thanks.
SamTexas
Re: HK Cell-Log Cell Voltage Monitor 2-8S Lipo?
Postby Ykick » Tue Jun 26, 2012 10:24 am
Great device, I started with M versions but this year went with S version from EPBuddy and it's awesome to record cell voltage curves during rides. Accurate enough for me and will read 1S up to around 40V I believe? Built a simple test lead and often use it as a handy pocket volt meter.
Ykick
Postby docnjoj » Tue Jun 26, 2012 10:29 am
Yep Cell logs are cheap and mine seem to be accurate. I fried one with reverse polarity on a single cell reading. Oops! Otherwise great.
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby 999zip999 » Tue Jun 26, 2012 1:15 pm
I got the hyperion pack sentry. It shows the cell voltage one by one total pack voltage to 7s and % of difference of high and low cell. It was 13usd. but would like to see all cells voltage at same time. It's O.K. Needed something.
999zip999
Postby Gregb » Tue Jun 26, 2012 6:44 pm
I have 2. (8s) wouldn't be without them. voltages readings agree with my DMM. Use the LV alarm facility attached to a flashing red taillight to provide me with discharge protection.
Gregb
Postby Ricky_nz » Tue Jun 26, 2012 7:39 pm
Yep celllogs work fine. They don't take kindly to being thrown in a bag with heavy items as the display is quite easy to break though.
Latest Projects: High power vector controller for Turnigy 80-100, Keewe Stealth DJ bike with Turnigy 80-100 180.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Commuter bike with 1000W GM rear hub.
Ricky_nz
Postby elmannen » Wed Jun 27, 2012 6:11 am
I like them to. I have 5 cellogs and everyone is working as excpected so far.
And you can adjust them to bee more accurate so that is no problem either.
/Lasse
elmannen
100 µW
100 µW
Postby dogman » Wed Jun 27, 2012 6:26 am
I have found the single cellog 8 that i have to be more accurate than my cheap chargers. So it's good for me.
As I've said many times though, I don't care about accuracy to .01v. I'm happy enough that however much my cellog is off, all 8 channels read the same compared to each other. So for my purposes, noticing if a cell is .05 off and doing something about one when it gets near .1 off, the cellog has been my tool to have.
Next time I have an order off to a place that sells em, I plan to buy several more.
One feature I really like, is that while bulk charging a pile of paralelled packs, you can put a cellog on the balance wires, and it will start beeping if a cell is overcharging. 8) So I want more of em, so I can put one on each pack as I charge 4 packs at a time.
dogman
Postby SamTexas » Wed Jun 27, 2012 10:20 pm
Thank you all for sharing your experience. This is great, no complaint at all (except for the easily broken display).
SamTexas
Postby deVries » Wed Jun 27, 2012 11:30 pm
I highly recommend the Celllog that will also log data while actually riding your ebike. I plan to post my data graphs using the A123 20Ah cells & also with my LiPo too. We need more actual in-use data from the field, and this is "the man" the celllog man for that job we need the data from. :idea: :twisted:
Another very cool feature using the Celllogs is it will work with Fechter's current limiter to shutdown the bulk charger if the Celllog detects a weak-high cell going "hot" at HVC. 8)
deVries
Return to Battery Technology
Users browsing this forum: e-beach, silviasol, zerogee and 8 guests
