front hub wheel shake
Re: front hub wheel shake
Postby auraslip » Thu Jun 28, 2012 2:17 pm
I let all the air out of the fork and now it handles fine with no wheel shake.
WTF. I thought more travel = more trail = more stability.
auraslip
1.21 GW
1.21 GW
Postby dogman » Thu Jun 28, 2012 2:50 pm
Was that frame built to have a suspension fork? Or is it's geometery intended for a rigid fork that is much shorter?
When I had a similar problem, the cause was obvious.
Mongoose blackcomb commuter.JPG (100.67 KiB) Viewed 112 times
But not as obvious as you might think. I had slop in the braces that support the rear rack. When I tightened that up, I could resume riding this bike no hands. Still has horrible balance, but the shimmy went away.
So look for anything moving around. How tight is everything inside that battery box?
dogman
Postby auraslip » Thu Jun 28, 2012 4:52 pm
80mm travel or 100mm travel and the suspension is 120mm travel so that right there is a problem.
The zip ties holding everything down are cranked hard enough to eat into the balsa wood, but that's actually something I haven't thought of. I'll check everything to make sure it's all tight.
auraslip
1.21 GW
1.21 GW
Postby D-Man » Thu Jun 28, 2012 8:52 pm
I have a 100mm aftermarket fork which seems too long. The frame was too small anyway so it ended up right with a longer reach stem. Never did solve the ebike headshake thing. Its a geometry thing that only the bike designers know. Got to hold the throttle anyway so why let go of the handlebars? Maybe to give someone the double finger?
408 front hub
11000+ miles on sla's.
Michelin pilot sport 2.3
Miles 13
Flats 0
Quality posts will not be sold.
D-Man
Postby auraslip » Thu Jun 28, 2012 10:07 pm
So you can ride with your arms crossed while sipping on your eciggerette like some space edged Buddha floating over the texas prairies. duh. :D
I used to do that while towing my trailer home on my old bike.
auraslip
1.21 GW
1.21 GW
Previous
Users browsing this forum: bionicdan, melodious and 13 guests
