Was that frame built to have a suspension fork? Or is it's geometery intended for a rigid fork that is much shorter?
When I had a similar problem, the cause was obvious.
- Mongoose blackcomb commuter.JPG (100.67 KiB) Viewed 115 times
But not as obvious as you might think. I had slop in the braces that support the rear rack. When I tightened that up, I could resume riding this bike no hands. Still has horrible balance, but the shimmy went away.
So look for anything moving around. How tight is everything inside that battery box?
