Raphael wrote:Hi
We have 2 lyen mark II 9 fet regen controllers, they work very smooth, way better than the crystalyte we had before.
Now I'd like to enable regen. We do not have e-brakes (yet).
1. possibility: enable throttle regen. However, I am not able to make that work. I configured it with Lyens software (slip mode = true) but it doesn't work at all. It only brakes when I short the brake-wires, I would have expected it regens when I zero the throttle?
2. possibility: install these: http://www.aliexpress.com/store/product ... 67226.html But I have only a 2-pole connector, not a 3-pole. But I think it would be possible to take 5V from throttle and power that sensor
3. possiblity: install e-brakes (which?)
What is your opinion on that? What would you do?
Thank you
Raphael
Raphael wrote:I am not able to make that work. I configured it with Lyens software (slip mode = true) but it doesn't work at all. It only brakes when I short the brake-wires, I would have expected it regens when I zero the throttle?
Raphael wrote:What do you mean by "I'd figure it out myself"? I thought a forum was there to ask questions???
I already contacted Edward Lyen, and while he was helpful, he can't / doesn't tell me why throttle regen doesn't work.
Sacman wrote:How many volts are you running? I thought I saw somewhere that the regen on Lyen controllers won't work if you're running above 80 volts. And I've verified it for myself. I have an 18-FET Lyen mark 2 controller and the regen works when I'm running 12s LiPo but doesn't work when I'm running 24s LiPo.
itchynackers wrote:Is your "EBS Limit Voltage" set too low?
Jeremy Harris wrote:There is a stack of info on here as to how regen works on the Xiechang/"Infineon"/Keywin etc controllers that Lyen sells. Will Newton did a pretty good write up of the way the settings work, with some comments on the need to do things like mod the LVC to get regen to work over 75 V. Although much of the stuff in this thread is old, it's still useful and still generally applies to the Xiechang controllers that Ed Lyen sells: viewtopic.php?f=2&t=14807
Raphael wrote:I've read through the thread, nothing new in there to solve the problem
Yes Ypedal, that's what I experienced too, connect the white wire to enable regen generally and then make a switch somehow to on/off the regen on black/yellow. But Lyen told me it's possible to enable throttle-regen - and I can't get it to work so far...
Otherwise the controllers are great and Edward Lyen was always super-helpful...
Raphael wrote:1. possibility: enable throttle regen. However, I am not able to make that work. I configured it with Lyens software (slip mode = true) but it doesn't work at all. It only brakes when I short the brake-wires, I would have expected it regens when I zero the throttle?
Ypedal wrote:I need to go read that link above.. but just a quick bit of into from my personal KMX experience..
Regen only works for me by shorting the yellow/black ( ebrake ) wires.. as long as the white wire is hooked up.. if i disconnect the white wire, regen does not work.
I run 24S lipo. 100v, below 10kph i get no regen.
Users browsing this forum: Bing [Bot], biohazardman, Hyena, novatin and 16 guests
