amberwolf wrote:Easy way to tell if the bearing was damaged is to spin it with your finger thru it. If turning the outer race it feels grindy it's probably done. If you flick it, it really ought to spin freely by itself at least several rotations if it's a *good* bearing, but many cheap ones stop after you remove the drive source, even when they are new. :/
Joe Perez wrote:the whole chicken / duck / goose concept virtually became a meme within the forum community. And at the suggestion of a user at MiataTurbo.net, I decided to adopt a poultry theme for my avatars, as both an inside joke and a persistent jab.
auraslip wrote:I'm using the hkvt though - http://www.hobbyking.com/hobbyking/stor ... oduct=9744
Does anyone know which lm35 I should order since mouser has 43 of them?
http://www.mouser.com/Sensors/Temperatu ... 35&FS=True
amberwolf wrote:And many of those listings are for large multiple quantities, if you look in the Quantity column. Like whole tape-reels of them in some cases.
mvly wrote:So anyone able to get this to work with off the shelf LCD display?
Users browsing this forum: bigturk, Bing [Bot], DAND214, RAPHZ400, rscamp and 7 guests
