Miles' Project 1 [eMoulton]
Postby Miles » Sat Jul 12, 2008 5:47 am
Moulton TSR conversion
Miles
Re: Miles' Project 1 [eMoulton]
Moulton TSR27 bike
-Planet Ryder brushless motor.
-Dual-Drive hub gear (4 derailleur sprockets retained).
-Freewheeling crankset.
-Gates Powergrip 8M GT3 belt transmission (16t to 100t).
-Sprague clutch in hub of rear pulley
-NiCad power tool batteries 36V 4Ah (provisional), in backpack.
-Weight (without battery) 16.5 kg (36 pounds)
Antecedents:
http://www.solarnavigator.net/electric_cycles.htm (Aloha Randy!)
http://v3.espacenet.com/origdoc?DB=EPOD ... =US3280932
http://www.electric-bikes.com/bikes/charger.html
Miles
Here's a pic of the inside of the motor:
Published spec.
Motor
Ke = 17 V/kRPM
Kt = 0.17 Nm/A
Resistance 0.25 Ohms
Inductance (approx.) 200 uH
12 Poles
Controller
Nominal input voltage 16-48V (max. 55V)
Continuous output current 20A
Peak output current 35A
Output power (max.) 1 kW
Measured no-load current of motor
0.8 A @ 38V
3D model PDF:
E-bike motor.pdf
(1.26 MiB) Downloaded 1199 times
Miles
Postby TylerDurden » Sat Jul 12, 2008 8:06 am
HUB-BA!
Drool.
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Postby dirty_d » Sat Jul 12, 2008 9:06 am
wait did you make this?
dirty_d
Postby Miles » Sat Jul 12, 2008 9:18 am
Tyler - hehe.... Thanks.
dirty_d - I didn't make the bike itself, I just did the conversion to an ebike.
http://www.tsr.uk.com/bikes/
Miles
Postby Malcolm » Sat Jul 12, 2008 10:53 am
It was worth waiting for Miles. Tis a thing of beauty.
Is the rear belt sprocket custom made?
Malcolm
Postby EMF » Sat Jul 12, 2008 10:59 am
WoW! :shock: Well done! That is one of the best conversions I have ever seen. Love the belt drive. It must have taken a lot of thought and pre-preparation to have this bike come out so nicely. The way the belt slips inside the frame, yet misses the tire and the brake is a fantastic fit. Very clean design all the way around. Kudos! 8)
EMF
Location: Curious about The Bikers Bar? Become a member to visit!
Postby Miles » Sat Jul 12, 2008 11:00 am
Hi Malcom.
Thanks.
The pulley itself is from the Strida 5 :wink:
I had to re-machine it a bit, though.
The pulley hub, which contains the clutch, I had to make myself.
Miles
Postby Miles » Sat Jul 12, 2008 11:03 am
Thanks EMF,
Yes, there wasn't much clearance for the drive in any direction :)
Miles
Postby paultrafalgar » Sat Jul 12, 2008 12:31 pm
Awesome, Miles! So that's what you meant, here:
viewtopic.php?f=2&t=953&p=65808&hilit=+working+on+it+#p65808
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
paultrafalgar
Postby paultrafalgar » Sat Jul 12, 2008 12:38 pm
Give us references for those parts, please, particularly the motor. Googling for it don't find anything. Thanks.
paultrafalgar
Postby Lessss » Sat Jul 12, 2008 1:19 pm
Awsome. It just needs fenders to keep the road rain off the motor controller and your set.
Interested to see how and where you decide on battery placement.
Give me nuclear batteries I say!! Ripped off by Joshua Goldberg to the tune of almost $900 re headway groupbuy for batteries, no $ no batteries
http://www.openoffice.org/ or https://www.libreoffice.org/
http://www.ubuntu.com/
Lessss
Postby scottclarke » Sat Jul 12, 2008 1:24 pm
First class Miles - very very neat. Reckon you had as much fun as I with clearances!
The motor - you mention Randy - is that the troublesome fella from Hawaii? If so - has he commercialised his motor? This looks a lot bigger than the one he was using???
Scott
1 off 48V 1KW/380WH suspended mtb
1 off 48V 1.2KW/380WH 'jump bike' - deceased.
1 off 2.8KW Marin Trail full susser + all RC gear - very light!
scottclarke
Postby Miles » Sat Jul 12, 2008 1:39 pm
Hi Paul,
The motor was made in a small batch only, a few years ago. It never went into production, I'm afraid.
The 16t 8M motor pulley was a custom job, the smallest commercially available is 22t and the smallest recommended size is 18t, but it works fine..
The 100t rear pulley is from the crankset of the Strida 5 bicycle - you can buy the whole crankset as a spare part.
16t to 100t is only 6.25:1, though...
To get a greater reduction ratio, in a single leap, you have to move to 5M size belt, but this means a completely custom large pulley.... 5M pulleys are available down to 12t but 16t is probably the smallest of any use in a one step drive.
Probably a good compromise between torque transfer, reduction ratio and size would be to use 18t to 180t 5M (10:1)
An alternative for less powerful drives might be to use a 100t belt as a tyre on the Strida pulley and run it as a toothless pulley with a 5M belt. This would give 18t to approx 162t (9:1). I've only tested this on the workbench so far, though....
So, there are various possibilities in terms of pulleys.
It would be fun to put together a kit of parts if there was some kind of concensus as to what people want....
Miles
Postby deecanio » Sat Jul 12, 2008 1:54 pm
Hi Miles,
beautiful work :)
cant wait to see this bike in action, instantly in my top 3 at the mo with recumbants and scotts.
Cheers
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby Miles » Sat Jul 12, 2008 1:55 pm
Less,
Yes, need to make some mudguards, for sure.
I'm quite happy having the batteries in a backpack, for now. It keeps the bike weight down to within the range of normal bikes, so I can easily carry it up the steps to my house. Also, it handles pretty much as it did before I converted it.
The obvious place for the battery, if you moved it to the bike, would be to hang it behind the rear seatpost. You could have an auxiliary battery on the steerer tube. Adding batteries to the central framing would kind of detract from the elegance.....
Miles
Postby Miles » Sat Jul 12, 2008 2:01 pm
scottclarke wrote:First class Miles - very very neat. Reckon you had as much fun as I with clearances!
Scott
Hi Scott,
Yes they don't make bike frames with us in mind :lol:
Southwestern Windpower made a small batch of motors, supposedly to Randy's spec. It never got any further than that...
Maybe the motor looks bigger because my bike has smaller wheels :)
Miles
Postby Miles » Sat Jul 12, 2008 2:09 pm
Thanks D
I'll see what I can do re. video.
Feel free to call in, if you're ever around SE London.
Wait until I've got a decent battery, though.....
Miles
Postby Miles » Sun Jul 13, 2008 3:25 am
Last shot of the session:
(222.61 KiB) Downloaded 1362 times
Miles
Postby docnjoj » Sun Jul 13, 2008 2:52 pm
Wow Miles!!!!!That is simply gorgeous! The workmanship is superb! I'm speechless, especially after my bodging! :mrgreen:
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby tropmonky » Sun Jul 13, 2008 6:40 pm
docnjoj wrote:Wow Miles!!!!!That is simply gorgeous! The workmanship is superb! I'm speechless,
I second this! Wow, very very clean! I bet this will last a long time to!
Kyle
tropmonky
Postby Miles » Mon Jul 14, 2008 12:59 am
Thanks guys,
It just wouldn't look right to use "duct tape style" on a Moulton :mrgreen:
Miles
Postby Miles » Mon Jul 14, 2008 5:17 am
Battery pack:
(227.83 KiB) Downloaded 1182 times
Miles
Postby deecanio » Mon Jul 14, 2008 6:38 am
Hi Miles,
yes, very very nice indeed - im with you to have the packs onboard would detract slightly from the bikes elegance.
If im in and around s London i'll give you a bell - likewise let me know if your in Loughton area and we'll hook up - to be honest with you in se london me in essex, knoxie in oxford and Joz in brighton i figure we could all meet before the season is out?
Im just waiting ( and not hassleing at all ;) ) for Joz to make up my custom packs - he should be done soon but i will probably be away when it's ready :( so it's looking like i wont be able to go get it until the 2nd August.i dont know if we have missed the forest of dean meet but i'm sure we could all get together at some point?
Again, lovely job miles, she's a minter!!!!
Cheers
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Next
Users browsing this forum: Brute, SkyknightJohn and 14 guests
