How was your holiday?
And I'm interested to see how the Bafang goes at 72v 28amps
Mark_A_W wrote:You can get a Cycle Analyst from Getadirtbike (and batteries), and you can also get a CA from http://www.ev-power.com.au/-Bike-hub-motors-.html
And I'm interested to see how the Bafang goes at 72v 28ampsKnuckles turned his gears to peanut butter
Ben wrote:I'm also very interested. I'm thinking about getting a front wheel Bafang and running it on 48V 28A.
You get the option of choosing which speed/rim size hub you want, right?
Also, if you're still thinking about the 10Ah Headway cells, there appears to be some quality control issues and overall badness (not sure about Getadirtbike's as they are different cells).
Mark_A_W wrote:Yes, Getadirtbike's packs are headway cells.
No, mine hasn't arrived yet.
The group buy reads like a total disaster area to me....
voicecoils wrote:I plan to stay a cyclist first, ebiker second. I suspect your in a similar situation. I don't understand $100 bikes with $3k of ebike kit on them. Nice to see a few decent bikes around.
Mark_A_W wrote:Where from and how much were the single cell chargers?
nomad85 wrote:voicecoils wrote: I get 28-30mph on flats with my motor(407) and 32 if I pedal pretty hard. I get about 24-26 mph up most hills, 18-22 mph(depending on length of the hill) up the larger 10-11% grades with pedalling. I just got some torque arms and but I havent installed them yet. I have an 11t high gear that lets me pedal at top speed.
Mark_A_W wrote:You could try filing the eyelets a tiny bit to allow the nipples to rotate more.
Mark
Ypedal wrote:It's ok if the spokes stick out the nipples a bit ( You will have to cover this with many layers of tape, or in my case, a bead of hot glue, covered in tape, and more tape, gulp.. but the spokes have to be tight or you will have problems ) with a 1 cross it must be some close to hitting the point that the spokes are tight, once you get there 1 or 2 mm of threads goes a long way.
voicecoils wrote:
Cheers, I was hoping they'd start to firm up fast at the end. I'll have another go at lacing it up tonight after I pick up some #6 nipple washers and use knuckles lacing suggestions. Maybe http://veloplug.com/ are the trick?
What do you think of battery placements?
Ypedal wrote:Gravity will want to bring the boxes down, so it's usually better to build a tray or some reinforcement for the frame tubes, then let the packs rest into them
Zoot Katz wrote: I think you should keep the wires long until you've tried the various configurations on the road with real batteries
Mark_A_W wrote:Yes, please mount the magnet. I'm dead keen to know the freewheel speed at 48v.
You won't need to adjust the CA wheel diameter, at least for this test, it's close enough to a standard 26" wheel+tyre. My CA read the same as my other speedo with the default settings.
Mark
Users browsing this forum: DunkenKBliths, keokio, Rodney64 and 5 guests
