recumpence wrote:Thanks for the link.
Hmm, $400 for the caps I would need. I will have to think about that. Heck, for that amount of money I can double my AH lipo pack.
recumpence wrote:Bummer. Man, I would really love a set of these, though. I have read alot about using large ultracaps in electric cars for accelleration. They keep the voltage from dropping. My pack is 49 volts when fully charged (settles to 48 volts shortly into the run). Under hard accelleration, it can drop to 44 or even touch 43 volts. I am sure it drops further than that in tiny dips too short for my display to read. Ultracaps would keep the voltage up at 48 volts constant unless I was pulling huge amperage for a relatively long time (8 seconds or longer).
recumpence wrote:But, typically, if I am really hammering my bike, I pull large current for 4 to 5 seconds to accellerate. That means I would have 10% more power on tap. Of course, I already have tons of power.
But, like I said, I could double my AH with more lipos for that price.![]()
recumpence wrote:I don't mean to argue with you, but it would not be $2000. It would be $400 for the caps I would use (the C size cells). You are looking at the wrong cells. Also, you are calculating voltage drop of the caps without any battery at all, merely capacitors alone. All I am looking for is a helping boost, not to power the whole bike. They are also very light weight for their size.
My lipo pack would still be putting out the majority of the current the motor would be pulling. The caps would merely help out with the peaks.
Again, I am not married to the ideA. I am just intrigued by it. Lastly, I cannot run 50% more voltage. My controller won't hanle it, nor would my motor. My efficiency is decent for the power output I have and the weight. I am just sort of thinkihng out loud with this. I have seen these used in car and motorcycle applications as an added boost to eliminate voltage drop under load with great success.
Matt
recumpence wrote:Also, you are calculating voltage drop of the caps without any battery at all, merely capacitors alone. All I am looking for is a helping boost, not to power the whole bike. They are also very light weight for their size.
recumpence wrote:My lipo pack would still be putting out the majority of the current the motor would be pulling. The caps would merely help out with the peaks.
recumpence wrote:Again, I am not married to the ideA. I am just intrigued by it. Lastly, I cannot run 50% more voltage. My controller won't hanle it, nor would my motor. My efficiency is decent for the power output I have and the weight. I am just sort of thinkihng out loud with this. I have seen these used in car and motorcycle applications as an added boost to eliminate voltage drop under load with great success.
Matt
tostino wrote:recumpence wrote:I don't mean to argue with you, but it would not be $2000. It would be $400 for the caps I would use (the C size cells). You are looking at the wrong cells. Also, you are calculating voltage drop of the caps without any battery at all, merely capacitors alone. All I am looking for is a helping boost, not to power the whole bike. They are also very light weight for their size.
Matt
I'm really not too sure how this would work, so would you mind explaining it?
With my limited understanding, do you plan to wire the cap bank up in parallel with your batteries?
If that's the case, would the batteries keep the cap bank charged at all times, and then just share the load with it?
How efficient is charging up a cap? If you lose a lot of power doing that, wouldn't it just cancel out any gains you may get?
-Adam
eP wrote:recumpence wrote:I don't mean to argue with you, but it would not be $2000. It would be $400 for the caps I would use (the C size cells). You are looking at the wrong cells.
Don't hesitate to argue with me Matt- i like your opinions.
But i'm sure i'm looking at the right cells for your needs.
Once again i'm sure you are wrong. 80 A load is a mean value. It is 160 at begining and zero at the end (8 seconds later).
You now have heavy load 120+ A at accelerations, so i'm sure after such pricy upgrade you should have 160 A available at least.
But if you still sure i'm wrong, so show us your calculations - and related explanations - Matt.recumpence wrote:My lipo pack would still be putting out the majority of the current the motor would be pulling. The caps would merely help out with the peaks.
If this would be the case, than ESC would see majority of the voltage sag.
If you want eliminate majority of the sag at peaks than supercaps cannot merely help out - they should help out as much as they can. This is what you paying for at least.recumpence wrote:Again, I am not married to the ideA. I am just intrigued by it. Lastly, I cannot run 50% more voltage. My controller won't hanle it, nor would my motor. My efficiency is decent for the power output I have and the weight. I am just sort of thinkihng out loud with this. I have seen these used in car and motorcycle applications as an added boost to eliminate voltage drop under load with great success.
Matt
I'm also not married with ideas. But i'm sure you need much more than 40V (at ESC) if you need 6kW power out or even more .
If your controller won't handle 50% more so try 35% more.
If your motor won't handle 50% at heavy load than you should consider to use another one.
High efficiency and high rpm limit is what you paying for.
If motor Rm hot is close to 80 mohm than you need much more than 40V at 200 A load if you need 6 kW power out.
Best regards
dirty_d wrote:charging a cap from a constant voltage is only 50% efficient average from start to end if the cap starts at 0V. if you have a capacitor that starts at 24V and charge it with a constant voltage source(like a battery) to 48V, then the instantaneous charge efficiency is 24.0/48.0=0.5(50%). you can easily prove this, you have a 48V source, and a cap already charged to 24V, say the capacitor ESR plus all the other resistance is 0.5ohms, the current will be (48.0 - 24.0) / 0.5 = 48A, the losses from resistance are then 48^2 * 0.5 = 1152W, the total power going into the capacitor and resistance is 48V * 48A = 2304W, so that means that out of the total 2304W, 2304-1152 = 1152W is being stored in the capacitor, 1152/2304=0.5. that means when the cap is already charged to 24V and the applied voltage across the cap is 48V the instantaneous efficiency is 50%. thats only the instantaneous efficiency though, what you really want to know is the average efficiency going from 24V to fully charge at 48V, when the cap is at 48V and the applied voltage is also 48V the efficiency is 100%, so for that case the average efficiency is (24.0/48.0 + 48.0/48.0) / 2.0 = 0.75(75%).
so if you make this deal and it only drops 4V under a heavy load or something, then when you back off the throttle and let it charge back up the efficiency will be (44.0/48.0 + 1.0) / 2.0 = 0.96(96%).
Users browsing this forum: bowlofsalad, e-beach, flexy and 8 guests
