LightningRods
Upgrading to the Big Block should be pretty straightforward. Despite being more than twice as powerful the Big Block is actually slightly smaller and lighter than the Cyclone 3kW. Half of the Cyclone motor is planetary gearbox, which is only useful for syncing human pedaling cadence with the motor rpm. Once the power level gets above 2kW all of that reduction starts to break driveline parts. We never want to have to overdrive the final drive to get back rpm lost in too much motor reduction. At 250-500 watts you can get away with it because the bicycle driveline was designed to deal with that power level. 3000 watts with it's torque multiplied 15x or more is way too much stress. I noticed that you installed small chainrings on your Cyclone to reduce the reduction/overdrive issue. That really helps.
Let me know if I can answer any questions.
