Cyb0rg d3ck3r
100 µW
I'll absolutely be doing a full build thread with tons of pictures here soon. But I'm not 100% sure about some parts, and I was hoping some more experienced riders might steer me in the right direction. Thanks in advance!
Kinda Light vs Kinda Heavy? I don't want to go 40mph, but do I want range and nimbleness? Or heavy duty with more float?
Priorities: I'm building a commuter that will spend most of its time on gravel or pavement, with the occasional singletrack/cornfield in mind. Deep snow maybe once or twice a year if I'm ahead of the plow trucks somehow, but not a backcountry trailblazer per se, nor a downhill bomber. I don't want to buy a bunch of parts and then upgrade them, and no current models really check all my boxes, so I'm starting from frame. I have a lifetime of experience on rigid MTBs and I love them, and fat tires alone are such an improvement in ride, I don't want suspension (if I find out I was wrong about that I can maybe add a suspension seat post, MAYBE suspension stem, most likely neither).
Motor/Battery: 100% going with a BBSHD, probably with a half-grip throttle and a 500c or Eggrider display, and Ludicrous controller. For battery, I will probably either try to cram in the biggest one possible, or keep 2 small ones. Probably Luna.
Rigid Frameset: Probably going with a BikesDirect level frame for cost. I was looking at a Gravity Bullseye Monster frameset, or a Motobecane Boris frameset, both $200 on Amazon (pictured). At 5'10" 170lbs, I can run either medium size (16-17") for handling or large size (18-19") for stability, both comfortably. However, the Boris has a modern geometry that might require a large's triangle for a battery. I have no idea which frame is lighter, but the Monster has hub spacing of 135mm/170mm (4" tires max, = lighter?) and the Boris has 150mm/190mm (5" tires max, = optionally heavier). I wish they were thru-axle rear, due to power level. ALMOST CONSIDERING a Surly Wednesday/Ice Cream Truck frameset for the steel construction and TA spacing, but it's another $600-800 so that's quite a choice. Any experience with either? SUPER OPEN to other suggestions too!
Wheelset: I consider "default" to be like an 80mm Mulefut with 4" Maxxis Minions. The "light" option, maybe Alex Blizzerk 70mm with 4" Kenda Juggernaut Pro? The "heavy" option might look like 100mm HED Big Aluminum Deal with 5" Snowshoes/Cake Eaters or some such? Haven't decided between tubeless or ultralight tubes yet. Definitely interested in any notable options here!
Freehub/Cassette: I want inexpensive all-steel stuff to handle the BBSHD torque confidently. Might get a wheelset through Bikesmiths with the Novatec D101SB/D102SB hubs. Cassette somewhere in the 8-9-10 speed range.
Brakes/Rotors: Noticed everyone suggests nice big/strong hydraulic disc brakes, but I've also heard only hydraulics can fail at high (ebike) temps. I was unwilling to accept "Powerful Hydraulic Disc Brakes" from BikesDirect lol. Not sure how "nice" these need to be, but I DO like the low maintenance of mechanical discs, if they'd be enough with huge rotors, maybe 200mm front/180mm rear, maybe Ice Tech? Wildly open to suggestions here, but will probably go with bb7 and metallic pads unless/until I NEED hydraulic.
Chainring/Crank Arms: We'll see. I want to see how the stock Bafang stuff lines up before I choose a Lekkie or Luna ring. I like the idea of longer crank arms but I'm concerned about pedal strike so who knows. Any input appreciated!
Derailleur/Shifter: We'll see. Not too picky here, I'll go with something serviceable. Suggestions welcome.
Stem/Handlebar/Seatpost/Saddle/Pedals: I'll basically pick this stuff up last, when the rest of the bike is pretty much done. Not sure how I want to set up a cockpit until I can see my frame size choice in real life.
Thanks for reading, I GREATLY appreciate any advice/experience/input! Once these decisions are made, I'll be starting. This will be posted on a couple different forums, feel free to chime in wherever! I can't wait to get this daily driver started!
