For those who would like to see the test results I received from the manufacturer I have attached them to the post. From my perspective the results look reasonable but I don't have much experience purchasing NMC cells. Variation in capacity of 1.3Ah/1.8% and IR of 0.02mOhm/4.3%. Keen to hear from the group if these match people's expectations for A grade cells.
Deligreen (TC Elcon) 2kW charger has also arrived. Has an additional 12V supply and output contacts but I haven't figured out the exact use for them yet. I may use the 12V supply and contacts as part of the fail safe circuit for if the CANBUS locks up and the BMS needs to disconnect the charger. Max charger voltage is set to 117.6v.
