hi there. i hope some one might be able to shed some light on this issue i have.. i bought an X-treme XB-300l1 bike 4 months ago.. can with a 3 month warranty. i have used the bike maybe 15 times just on weekend basically on straight terrane.. the bike cost me about $1100 bucks and it is already not working.. what the issue is when the bike is cool i can get about 1 mile and then it must be over heating because it will power off.. i can turn it off and right back on and it will work but any type of throttle it will just die again.. i can peddle with it and it might work but hit any incline and it will die even pedaling.. the battery is fine.. if i let the bike sit for 5 minutes it is work perfect again until it heats up and die close to a mile.. my buddy took the controller box apart and the board doesn't really look fried by looking at it.. he tried to find out what type of mosfets they were but the logo on them were impossable to match with anything online.. i ordered a new control unit for extreme scooters and they emailed me saying thry don't have the part and won't give any eta's.. in fact i can't get a hold of a human being at that company.. i live in humtington beach california and want to fix this.. is there a certain moset that i can buy local that works in a 24v 250w controller? is there anything else that could cause it to over heat possibly? any help would be greatly appreated... castle
HOT NEW ITEM!!
$1,199.00 Reg.
$1,099.00 SALE
The XB-300Li is a Lithium Battery powered Electric Bicycle, running on a 300 Watt rear hub motor. Made with all top of the line components this model includes a 7 Speed Shimano Tourney® Gears & Shifter System, 7 Lightweight Lithium Ion Batteries, a 100% Aluminum Alloy Frame, fully Adjustable Seat, and an RST Capa® T7 front fork.
This model is in Stock & Ships immediately!!
This model is available in Men's or Womans 26" frame & comes in natural polished aluminum or black.
Item ships by a trucking company. Shipping is free if you will pick it up at the nearest terminal or $70 to have it delivered to your door.
Product Specifications:
Power: Electric
Watts: 300 Watt
Motor Type: Brushless Hub Motor - Motor is in center of rear wheel
Gears & Speed's: 7 Speed Shimano Tourney® Gears & Shifter
Amps: 56 AMP Circuit (7 Batteries at 8 AMP's each)
Volts: 24 Volts (Each Battery Is 3.6 Volts)
Batteries: 7 - Lightweight Lithium Batteries In A Sealed Removable Pack
Tire Size: 26" x 1.95" on Aluminum Wheels
Charger: Smart Charger Included
Tool Kit: Included
Speed: 20 MPH* using motor power only - faster if you also pedal
Distance: Up to 20 - 25 miles per charge - can still pedal if charge is lost
Throttle Type: Variable Speed Control - Twist Throttle - or - Pedal & Power Assisted
Key Start: Yes
Frame Type: 100% Aluminum - Very Light Weight
Forks: RST Capa® T7 Front Hydraulic Forks Made (Top Name Brand)
Braking System: Front and Rear Brakes
Drive System: Rear Hub Motor (Motor is in rear rim) + Pedal Power
Head Light: Yes
Measurements: Wheel to Wheel 72" - Width 25" - To Bars 37"
Adjustable Seat Height: 37 3/4" to 45 3/4"
Carton Size (LxWxH): 58 x 11 x 30 inches
Scooter In Box Weight: 60 Lbs (Not including weight of the pallet it ships on)
Scooter Weight: 51 Lbs (Including the light weight battery pack)
Maximum Rider Weight: 350 Lbs
Horn/Bell Included: Yes
Battery Indicator: Yes
Cargo Rack: Included
Warranty: 90 Day X-Treme Warranty
6 Month Battery Warranty *depends on rider weight & terrain This item can be shipped to Canada for $100 extra.
HOT NEW ITEM!!
$1,199.00 Reg.
$1,099.00 SALE
Power: Electric
Watts: 300 Watt
Tool Kit: Included
Key Start: Yes
Head Light: Yes
