Pete1961
I am looking for a 5A charger with a variable voltage adjustment. I need to take 22s 1p of Ni Zn cells to 1.96V each, Thus 43.1V. I have been offered this charger @ 4.5A with the ability to have set the voltage as I wish but not then change it. Also it is available to order with or without a cut off at a particular voltage
http://www.ebay.co.uk/itm/36V-1-8A-2-5A-4-5A-Scooter-Lithium-Battery-Charger-8AH-18AH-Lifepo4-Li-ion-Ebike-/321438597401?pt=UK_Sound_Visi
My questions are 1) should I specify the pack max voltage I need or should this be a little above the desired pack voltage (Ni Zn needs to be charged at 0.5C as much as possible). I will have a Hi voltage alarm on the pack to tell me when the desired voltage is reached.
2) Should I go for the cut off or not (this sort of hinges on Q1, again there is the alarm)
I also found the Gaozhao charger http://endless-sphere.com/forums/viewtopic.php?f=14&t=59549 The 48V model is discussed here, pic seem,s to show a voltage adjustment pot. There is a 36V nominal version, I think sold by sun thing
http://www.ebay.co.uk/itm/36V-5A-LiFePO4-Battery-Charger-Electric-Bike-Kit-110V-or-220V-Scooters-Outdoor/141128189969?_trksid=p2045573.c100033
I contacted sun thing, he says the charger is not adjustable (& said to be 45V) - this may have been a mis understanding with him thinking I wanted to charge different nominal voltages rather than make a slight adjustment. Does anyone have a 36V Gaozhao?
I have an option of 8Ah or 10Ah batts, as they need 0.5C charging, the charger availability will denote which battery I get, need a bit of advice here. Pete
