Jeremy Harris
As this has come up a couple of times, I thought I'd sum up the mods needed to run the baby 6 FET 116 controllers on low voltages. I'm indebted to Stator for reverse engineering the wiring diagram, it helped a lot.
The photos show the mods on a new bare board (Keywin Ge will sell these if you ask). My application is for low power on electric boats, so I wanted to be able to get the controllers to work well on a 12V supply. With the mods shown, the maximum voltage is about 18V (any more risks blowing the FET gates) and the minimum voltage is about 9.35V (set by the lowest LVC programmable after the mods).
The first mod is to mod the power supply section. The stock controller has a power resistor (R1) to reduce the voltage to the 12V regulator, which needs to be removed and replaced with a shorting link. The 12V regulator (U2) needs to be removed and the input and output pads shorted. These two mods allow the full supply voltage to be applied to the 12V parts of the circuit.
The next mod is to change the LVC sense circuit, to lower the minimum limit from 20.1V (the lowest value that the "Parameter Designer" software allows). R10 is removed and replaced with a shorting link. This makes any value of LVC programmed to be about 46% of the set value, so a setting of 20.1V will really be 9.35V.
The FETs I'm using on this particular board (which is not the final high power unit) are IRLB3034s, which have a package current limit of 195A, a silicon limit of 343A and typical Rdson of 1.4mohm. The downside to this spec is that Vds is only 40V.
View attachment irlb3034pbf.pdf
I'm not sure that these mods will be of much interest to many, but I guess it adds to the knowledge base on here.
Jeremy
Jeremy
