BladeScraper
- Joined
- Nov 7, 2014
- Messages
- 39
I converted my Razor E100 to Brushless using a Scorpion HK4025-740Kv and am currently running 3s 7200mAh. I put my watt meter on and it read a peak of 1048W. It has tons of acceleration and can hit 20MPH, but the problem is that the motor gets very hot (180F+) after a 1 mile drive, and the ESC gets quite warm. Also the battery doesn't last very long. (1-1.5 miles only) The meter said I got a peak of 85A, most likely when climbing a hill.
One thing I love about this setup I have, is that I have the HobbyWing Platinum Pro 100A V3 ESC, and man what a good governor that thing has. I set it to about 60-70% and the speed when riding is absolutely constant. And if I want to go up a hill, I can either leave it at 60-70% and it keeps on going, or, I just go full throttle and is HAULS up the hill like you wouldn't believe. Motor just gets hot.
I want to convert to 12s (48v) LiPo and plan on using the Turnigy 6374 149Kv motor. I am gonna gear it to get a top speed of 20-25MPH and have a MASSIVE amount of haul-ass behind it. I'm not that heavy (about 125lbs) so weight really isn't a big concern to me. I plan to use 16,000mAh 12s (two sets of 6s 8000mAh in series, in parallel), and maybe eventually 32,000mAh 12s. About how much range will this probably get me, if its possible to estimate?
Has anyone used this motor, and if so, how is it? Power, amperage, heat, etc.? What ESC are you using for it?
Also, is there some sort of battery meter that I can use that will reach all the way to the handle bars and tell me what voltage my battery is at? Needs to be good up to 50.4v which is a fully charged 12s LiPo.
Also, is there a throttle you can buy that is spring loaded and will work with a RC ESC? (1000-2000ms pulse width)
Thanks
Thanks
