Greetings.
About two years ago I converted my regular mountainbike into an ebike with a front wheel motor (36 volt, 250 watt), controller, pedal assist and thumb throttle and ran it for abu5 1,5 years without any hassle.
However a few months ago it developed a fault where the motor essentially began to "seize" and resist whenever power was applied to it, either via the pedal assist or thumb throttle.
This week I've been trying to find out if the problem is either with the motor itself or the controller. I used the controller to connect a week I borrowed from someone to fine that it had similar issues of seeming to resist when switched on. Which would indicate there an issue with the controller.
The problem is that I can't find a replacement for it. Googling the model number gets me many options of controller that are similar, but not identical.
I have another controller, however that has a hall sensor that consists of 6 wires, while the wheel I have only has 5 wires. So I don't know if they aye compatible.
Both hall sensors have yellow/green/black/red/blue wires. My spare controller also has a white wire.
My questions.
Is there any way to use my spare controller despite the hall sensor mismatch?
If not, is can anyone help me to determine what a suitable replacement controller would be?
Thanks in advance.
Stefan
My questions.
Thanks in advance.
Stefan
