Fallingwater
- Joined
- Sep 19, 2020
- Messages
- 18
Given my proclivity to experiment with battery packs of various configurations on my e-scooters (and just wait till I get into e-bikes...) I'm wondering if it makes sense not to bother with internal BMS installs.
I've been into FPV quadcopters for a while now, and have a bank of four ISDT SC-608 balancing chargers each capable of 6S and 8A. I could wire my scooter batteries as multiple series of 6 with suitable balancing plugs; to charge I'd disconnect the sections, plug each into a separate charger, charge them up, then reconnect it all up and use the scooter. It'd be mildly annoying to have to fiddle with the plugs, but the advantages would be significant - aside from simple balancing I'd be able to check each cell for capacity and health. I could also charge at 8A, which is a significant step-up from the 2A or 3A that most scooter chargers do.
My one doubt, and the reason I'm writing this post, is that such a system would only check battery balance and health upon charging; the battery would be left to its own devices while being used inside the scooter, with only a fuse in series to protect it in case of shorts. Undervoltage wouldn't be a problem as my scooters' controllers have built-in protection for that, but I'm worried about in-use imbalances.
This doesn't seem to be an issue for my drones; I fly them, recharge the batteries, and notice while recharging if one of the cells has something weird going on and if I should take action. However, I'm being told in various scooter groups that not having constant balancing while in use in a scooter is a problem.
Is it?
Is it?
