Chalo
100 TW
The Stig said:Yeah I definately want to keep it pedalable. One of my bikes has a 150mm bb and that works fine...
Now if I could just find a SYMetrical 150mm BB, or 130mm BB with wide cranks.
The 132.5mm BB from Sick Bike Parts is symmetrical. I used it to fix up a bike for a big guy not too long ago.
The threaded spindle BB you found is for bikes that take a one-piece crank, like old cruisers. A threaded BB shell can't be made to work with them.
There is a kind of cheap crank I sometimes get for economical repairs. It has a strange combination of highly flared arms and an inboard-mounted single ring. I don't know if that would buy you enough room for your battery box, but it's pretty wide pedal spacing you can get with relatively normal chainline from the ring.
On one of my bikes that uses a three-piece BMX crank, I put spacing washers between the chainwheel and the crankarm to increase the tread width without changing the chainline. If you wanted to do something like that, you could accomplish it by using Profile cranks which have a 175mm spindle available, and which use a bolt rather than a pin to transmit torque. My bike which is set up that way has 160mm of clear space between the insides of the crank ends. It sounds like that's not as much room as you need.
I really doubt you'll be able to pedal effectively around a battery box 7-1/2" wide, even if you can make the cranks work. I know I would not be able to do it. You need that space for your legs, which have priority over batteries. When I mount a frame bag 2" wide, my knees brush against it when I pedal normally.
